This is a sketch that uses the RF24 library on my desktop version. It compiles fine. I just tried to load the same sketch into Web Editor and it wont compile The same libraries are installed on each, though im not sure of the version. Here is the compile notes from the IDE. Thank You.
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\bigda\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\bigda\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\bigda\Documents\Arduino\libraries -fqbn=esp8266:esp8266:d1_mini_clone:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,FlashMode=dout,FlashFreq=40,eesz=4M2M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=921600 -ide-version=10816 -build-path C:\Users\bigda\AppData\Local\Temp\arduino_build_590915 -warnings=none -build-cache C:\Users\bigda\AppData\Local\Temp\arduino_cache_373805 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.python3.path=C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.4-gcc10.3-1757bed.path=C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs.path=C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs-3.0.4-gcc10.3-1757bed.path=C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs.path=C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs-3.0.4-gcc10.3-1757bed.path=C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -verbose C:\Users\bigda\Dropbox\Arduino\Arduino Libraries\D1MiniStartupWRF24\D1MiniStartupWRF24.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\bigda\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\bigda\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\bigda\Documents\Arduino\libraries -fqbn=esp8266:esp8266:d1_mini_clone:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,FlashMode=dout,FlashFreq=40,eesz=4M2M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=921600 -ide-version=10816 -build-path C:\Users\bigda\AppData\Local\Temp\arduino_build_590915 -warnings=none -build-cache C:\Users\bigda\AppData\Local\Temp\arduino_cache_373805 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.python3.path=C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.4-gcc10.3-1757bed.path=C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs.path=C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs-3.0.4-gcc10.3-1757bed.path=C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs.path=C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs-3.0.4-gcc10.3-1757bed.path=C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -verbose C:\Users\bigda\Dropbox\Arduino\Arduino Libraries\D1MiniStartupWRF24\D1MiniStartupWRF24.ino
Using board 'd1_mini_clone' from platform in folder: C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2
Using core 'esp8266' from platform in folder: C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2
Detecting libraries used...
"C:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10816 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINI\"" -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "C:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915\\sketch\\D1MiniStartupWRF24.ino.cpp" -o nul
Alternatives for ESP8266WiFi.h: [ESP8266WiFi@1.0]
ResolveLibrary(ESP8266WiFi.h)
-> candidates: [ESP8266WiFi@1.0]
"C:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10816 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINI\"" -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src" "C:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915\\sketch\\D1MiniStartupWRF24.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
"C:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10816 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINI\"" -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "C:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915\\sketch\\D1MiniStartupWRF24.ino.cpp" -o nul
Alternatives for nRF24L01.h: [RF24-master@1.3.9 RF24@1.4.1]
ResolveLibrary(nRF24L01.h)
-> candidates: [RF24-master@1.3.9 RF24@1.4.1]
"C:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10816 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINI\"" -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\bigda\\Documents\\Arduino\\libraries\\RF24-master" "C:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915\\sketch\\D1MiniStartupWRF24.ino.cpp" -o nul
Using cached library dependencies for file: C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\BearSSLHelpers.cpp
Using cached library dependencies for file: C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\CertStoreBearSSL.cpp
Using cached library dependencies for file: C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\ESP8266WiFi.cpp
Using cached library dependencies for file: C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\ESP8266WiFiAP.cpp
Using cached library dependencies for file: C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\ESP8266WiFiGeneric.cpp
Using cached library dependencies for file: C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\ESP8266WiFiGratuitous.cpp
Using cached library dependencies for file: C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\ESP8266WiFiMulti.cpp
Using cached library dependencies for file: C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\ESP8266WiFiSTA-WPS.cpp
Using cached library dependencies for file: C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\ESP8266WiFiSTA.cpp
Using cached library dependencies for file: C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\ESP8266WiFiScan.cpp
Using cached library dependencies for file: C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\WiFiClient.cpp
Using cached library dependencies for file: C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\WiFiClientSecureBearSSL.cpp
Using cached library dependencies for file: C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\WiFiServer.cpp
Using cached library dependencies for file: C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\WiFiServerSecureBearSSL.cpp
Using cached library dependencies for file: C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\WiFiUdp.cpp
Using cached library dependencies for file: C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi\src\enable_wifi_at_boot_time.cpp
Using cached library dependencies for file: C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SPI\SPI.cpp
Using cached library dependencies for file: C:\Users\bigda\Documents\Arduino\libraries\RF24-master\RF24.cpp
Generating function prototypes...
"C:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10816 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINI\"" -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\bigda\\Documents\\Arduino\\libraries\\RF24-master" "C:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915\\sketch\\D1MiniStartupWRF24.ino.cpp" -o "C:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/signing.py" --mode header --publickey "C:\\Users\\bigda\\Dropbox\\Arduino\\Arduino Libraries\\D1MiniStartupWRF24/public.key" --out "C:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915/core/Updater_Signing.h"
"C:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/include" "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lwip2/include" "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915/core" -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10816 -DARDUINO_ESP8266_WEMOS_D1MINI -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_WEMOS_D1MINI\"" -DFLASHMODE_DOUT -DESP8266 "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\cores\\esp8266" "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\variants\\d1_mini" "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2\\libraries\\SPI" "-IC:\\Users\\bigda\\Documents\\Arduino\\libraries\\RF24-master" "C:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915\\sketch\\D1MiniStartupWRF24.ino.cpp" -o "C:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915\\sketch\\D1MiniStartupWRF24.ino.cpp.o"
Compiling libraries...
Compiling library "ESP8266WiFi"
Using previously compiled file: C:\Users\bigda\AppData\Local\Temp\arduino_build_590915\libraries\ESP8266WiFi\CertStoreBearSSL.cpp.o
Using previously compiled file: C:\Users\bigda\AppData\Local\Temp\arduino_build_590915\libraries\ESP8266WiFi\BearSSLHelpers.cpp.o
Using previously compiled file: C:\Users\bigda\AppData\Local\Temp\arduino_build_590915\libraries\ESP8266WiFi\ESP8266WiFiAP.cpp.o
Using previously compiled file: C:\Users\bigda\AppData\Local\Temp\arduino_build_590915\libraries\ESP8266WiFi\ESP8266WiFi.cpp.o
Using previously compiled file: C:\Users\bigda\AppData\Local\Temp\arduino_build_590915\libraries\ESP8266WiFi\ESP8266WiFiGeneric.cpp.o
Using previously compiled file: C:\Users\bigda\AppData\Local\Temp\arduino_build_590915\libraries\ESP8266WiFi\ESP8266WiFiGratuitous.cpp.o
Using previously compiled file: C:\Users\bigda\AppData\Local\Temp\arduino_build_590915\libraries\ESP8266WiFi\ESP8266WiFiMulti.cpp.o
Using previously compiled file: C:\Users\bigda\AppData\Local\Temp\arduino_build_590915\libraries\ESP8266WiFi\ESP8266WiFiSTA-WPS.cpp.o
Using previously compiled file: C:\Users\bigda\AppData\Local\Temp\arduino_build_590915\libraries\ESP8266WiFi\ESP8266WiFiSTA.cpp.o
Using previously compiled file: C:\Users\bigda\AppData\Local\Temp\arduino_build_590915\libraries\ESP8266WiFi\ESP8266WiFiScan.cpp.o
Using previously compiled file: C:\Users\bigda\AppData\Local\Temp\arduino_build_590915\libraries\ESP8266WiFi\WiFiClient.cpp.o
Using previously compiled file: C:\Users\bigda\AppData\Local\Temp\arduino_build_590915\libraries\ESP8266WiFi\WiFiClientSecureBearSSL.cpp.o
Using previously compiled file: C:\Users\bigda\AppData\Local\Temp\arduino_build_590915\libraries\ESP8266WiFi\WiFiServer.cpp.o
Using previously compiled file: C:\Users\bigda\AppData\Local\Temp\arduino_build_590915\libraries\ESP8266WiFi\WiFiServerSecureBearSSL.cpp.o
Using previously compiled file: C:\Users\bigda\AppData\Local\Temp\arduino_build_590915\libraries\ESP8266WiFi\WiFiUdp.cpp.o
Using previously compiled file: C:\Users\bigda\AppData\Local\Temp\arduino_build_590915\libraries\ESP8266WiFi\enable_wifi_at_boot_time.cpp.o
Using previously compiled file: C:\Users\bigda\AppData\Local\Temp\arduino_build_590915\libraries\ESP8266WiFi\ESP8266WiFi.a
Compiling library "SPI"
Using previously compiled file: C:\Users\bigda\AppData\Local\Temp\arduino_build_590915\libraries\SPI\SPI.cpp.o
Compiling library "RF24-master"
Using previously compiled file: C:\Users\bigda\AppData\Local\Temp\arduino_build_590915\libraries\RF24-master\RF24.cpp.o
Compiling core...
Using precompiled core: C:\Users\bigda\AppData\Local\Temp\arduino_cache_373805\core\core_1d83645bea6c5d9282acb49c4ddb2e62.a
Linking everything together...
"C:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/mkdir.py" -p "C:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915/ld_h/"
"C:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/cp.py" "C:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/ld/eagle.flash.4m2m.ld" "C:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915/ld_h/local.eagle.flash.ld.h"
"C:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-gcc" -CC -E -P -DVTABLES_IN_FLASH -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 "C:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915/ld_h/local.eagle.flash.ld.h" -o "C:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915/local.eagle.flash.ld"
"C:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-gcc" -CC -E -P -DVTABLES_IN_FLASH -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 "C:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/ld/eagle.app.v6.common.ld.h" -o "C:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915/local.eagle.app.v6.common.ld"
"C:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-gcc" -fno-exceptions -Wl,-Map "-Wl,C:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915/D1MiniStartupWRF24.ino.map" -g -w -Werror=return-type -Os -nostdlib -Wl,--no-check-sections -u app_entry -u _printf_float -u _scanf_float -Wl,-static "-LC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lib" "-LC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/lib/NONOSDK22x_190703" "-LC:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915" "-LC:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sdk/libc/xtensa-lx106-elf/lib" -Tlocal.eagle.flash.ld -Wl,--gc-sections -Wl,-wrap,system_restart_local -Wl,-wrap,spi_flash_read -o "C:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915/D1MiniStartupWRF24.ino.elf" -Wl,--start-group "C:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915\\sketch\\D1MiniStartupWRF24.ino.cpp.o" "C:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915\\libraries\\ESP8266WiFi\\ESP8266WiFi.a" "C:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915\\libraries\\RF24-master\\RF24.cpp.o" "C:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_cache_373805\\core\\core_1d83645bea6c5d9282acb49c4ddb2e62.a" -lhal -lphy -lpp -lnet80211 -llwip2-536-feat -lwpa -lcrypto -lmain -lwps -lbearssl -lespnow -lsmartconfig -lairkiss -lwpa2 -lstdc++ -lm -lc -lgcc -Wl,--end-group "-LC:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915"
"C:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/elf2bin.py" --eboot "C:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/bootloaders/eboot/eboot.elf" --app "C:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915/D1MiniStartupWRF24.ino.elf" --flash_mode dout --flash_freq 40 --flash_size 4M --path "C:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin" --out "C:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915/D1MiniStartupWRF24.ino.bin"
Creating BIN file "C:\Users\bigda\AppData\Local\Temp\arduino_build_590915/D1MiniStartupWRF24.ino.bin" using "C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2/bootloaders/eboot/eboot.elf" and "C:\Users\bigda\AppData\Local\Temp\arduino_build_590915/D1MiniStartupWRF24.ino.elf"
"C:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/signing.py" --mode sign --privatekey "C:\\Users\\bigda\\Dropbox\\Arduino\\Arduino Libraries\\D1MiniStartupWRF24/private.key" --bin "C:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915/D1MiniStartupWRF24.ino.bin" --out "C:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915/D1MiniStartupWRF24.ino.bin.signed" --legacy "C:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915/D1MiniStartupWRF24.ino.bin.legacy_sig"
"C:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.0.2/tools/sizes.py" --elf "C:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915/D1MiniStartupWRF24.ino.elf" --path "C:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin" --mmu "-DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000"
Executable segment sizes:
ICACHE : 32768 - flash instruction cache
IROM : 242072 - code in flash (default or ICACHE_FLASH_ATTR)
IRAM : 27273 / 32768 - code in IRAM (IRAM_ATTR, ISRs...)
DATA : 1500 ) - initialized variables (global, static) in RAM/HEAP
RODATA : 1020 ) / 81920 - constants (global, static) in RAM/HEAP
BSS : 25784 ) - zeroed variables (global, static) in RAM/HEAP
Multiple libraries were found for "nRF24L01.h"
Used: C:\Users\bigda\Documents\Arduino\libraries\RF24-master
Not used: C:\Users\bigda\Documents\Arduino\libraries\RF24
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\ESP8266WiFi
Using library SPI at version 1.0 in folder: C:\Users\bigda\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\libraries\SPI
Using library RF24-master at version 1.3.9 in folder: C:\Users\bigda\Documents\Arduino\libraries\RF24-master
"C:\\Users\\bigda\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-size" -A "C:\\Users\\bigda\\AppData\\Local\\Temp\\arduino_build_590915/D1MiniStartupWRF24.ino.elf"
Sketch uses 271865 bytes (26%) of program storage space. Maximum is 1044464 bytes.
Global variables use 28304 bytes (34%) of dynamic memory, leaving 53616 bytes for local variables. Maximum is 81920 bytes.
