Web Editor won't connect to Opta
The Web Editor won't connect to an Opta, but at the same time it's shown as "online" under Devices and it also will read & write values with a dashboard. The Opta is only connected via Ethernet, not USB.
I tried connecting to USB, but even though the Arduino Cloud Agent is running, the web editor still won't connect.
Also, a few weeks ago I was able to click on the device name at the top of the Web Editor and re-select the same device from the popup, which then usually made it connect. But now clicking on the device name does not even produce a selection pop-up, let alone reset the connection.
Using Firefox v129.
Edit: I tried restarting the Arduino Agent, rebooting Windows 10, deleting the device and creating/associating it as a new device, but nothing so far has worked. The local IDE can upload via USB no problem. (Maybe related: It took 3 tries to add a new device. The first two tries took over 10 minutes then returned to the initial "add device" dialog, with no device added or error message.)
Edit2: I also tried another Opta and successfully created a new cloud device for it, but this one doesn't show up online at all, unlike the other one.
Edit3: I opened the Arduino Cloud Agent Debug Console and noticed that when switching to, or reloading, the Web Editor, I instantly get 4 identical sets of map updates. The serial port IsOpen flag is false, but the local IDE is closed so nothing else is using that port.
Serial Ports:
    "Name": "COM17",
    "SerialNumber": "0027001F3532511339353732",
    "IsOpen": false,
    "VendorID": "0x2341",
    "ProductID": "0x0164"
downloadtool windows-drivers latest arduino keep
downloadtool bossac 1.7.0 arduino keep
downloadtool arduino-fwuploader latest arduino keep
downloadtool rp2040tools latest arduino keep
list
Serial Ports:
    "Name": "COM17",
    "IsOpen": false,
  "DownloadStatus": "Pending",
  "Msg": "Ensure that the files are executable"
  "Msg": "Updating map with location C:\\Users\\Conpewter\\.arduino-create\\arduino\\bossac\\1.7.0"
  "DownloadStatus": "Success",
  "Msg": "Map Updated"
  "Msg": "Updating map with location C:\\Users\\Conpewter\\.arduino-create\\arduino\\windows-drivers\\latest"
  "Msg": "Updating map with location C:\\Users\\Conpewter\\.arduino-create\\arduino\\rp2040tools\\latest"
  "Msg": "Updating map with location C:\\Users\\Conpewter\\.arduino-create\\arduino\\arduino-fwuploader\\latest"
downloadtool fwupdater latest arduino keep
  "Msg": "Updating map with location C:\\Users\\Conpewter\\.arduino-create\\arduino\\fwupdater\\latest"
list
Serial Ports:
    "Name": "COM17",
    "IsOpen": false,
list
Serial Ports:
    "Name": "COM17",
    "IsOpen": false,
close COM17
  "Error": "We could not find the serial port COM17 that you were trying to close."
list
Serial Ports:
    "Name": "COM17",
    "IsOpen": false,
list
Serial Ports:
    "Name": "COM17",
    "IsOpen": false,
list
Serial Ports:
    "Name": "COM17",
    "IsOpen": false,
And here's the code I uploaded with the local IDE. I inlined the two header files for completion and easier reading. This works fine with a little dashboard, but again the device is not seen as online by the Web Editor.
//#include "arduino_secrets.h"
#define SECRET_OPTIONAL_DNS ""
#define SECRET_OPTIONAL_GATEWAY ""
#define SECRET_OPTIONAL_IP ""
#define SECRET_OPTIONAL_NETMASK ""
//#include "thingProperties.h"
#include <ArduinoIoTCloud.h>
#include <Arduino_ConnectionHandler.h>
const char IP[]      = SECRET_OPTIONAL_IP;
const char DNS[]     = SECRET_OPTIONAL_DNS;
const char GATEWAY[] = SECRET_OPTIONAL_GATEWAY;
const char NETMASK[] = SECRET_OPTIONAL_NETMASK;
void onLightChange();
bool button;
bool light;
void initProperties(){
  ArduinoCloud.addProperty(button, READ, ON_CHANGE, NULL);
  ArduinoCloud.addProperty(light, READWRITE, ON_CHANGE, onLightChange);
EthernetConnectionHandler ArduinoIoTPreferredConnection(IP, DNS, GATEWAY, NETMASK);
  delay(1500);
  initProperties();
  ArduinoCloud.begin(ArduinoIoTPreferredConnection);
  // 0=only errors, 4=max verbosity.
  setDebugMessageLevel(4);
  ArduinoCloud.printDebugInfo();
  ArduinoCloud.update();
  button = !digitalRead(BTN_USER);
void onLightChange()  {
  if ( light ) {
    digitalWrite(LED_D3, HIGH);
    digitalWrite(LED_D3, LOW);
