As this is my first post here welcome everyone.
I have got RPI (want to use it as a web server) and I wanted to buy 3 Arduinos Ethernet for each room to control the lights (I know that I could buy just one and connect all the wires to it but want to have one for each room).
I have been learning about ethernet shield from Arduino Ethernet Shield Web Server Tutorial and I have learned a lot but there is a solution for only one Arduino.
What do I need to create a page which would allow me to control all the pins from all 3 Arduinos on one page?
Thanks. That is a very simple solution but frames don't give you the freedom
I was thinking about something more advanced and more visual.
I was also thinking about macro when one link/button would switch off all lights.
Can someone post a PHP code which could display pin status and switch on/off one light and another to switch all off the lights?
You could try to use Jquery. It is easy to use and will probably get you the visual look you are looking for, There are a lot of tutorials including ones directly involving RPI
Below you can look at my remote control (IR controlled via web) I created using Jquery mobile (it is still in beta )
