hello ,
can any one help me how to read data from ADC of ARDUINO and display it on web page through the Ethernet protocol.
thanks,
What have you tried so far?
A possible way.
//zoomkat 12-3-15
//simple button GET with iframe code
//open serial monitor to see what the arduino receives
//use the ' instead of " in html ilnes
//address will look like http://192.168.1.102:84/ when submited
//for use with W5100 based ethernet shields
#include <SPI.h>
#include <Ethernet.h>
const int analogInPin0 = A0;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //ethernet shield mac address
byte ip[] = { 192, 168, 1, 102 }; // arduino IP in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
String readString;
void setup(){
pinMode(4, OUTPUT); //pin selected to control
//start Ethernet
Ethernet.begin(mac, ip, gateway, gateway, subnet);
server.begin();
//enable serial data print
Serial.println("server test button and box"); // so I can keep track of what is loaded
void loop(){
// Create a client connection
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
Serial.println(readString); //print to serial monitor for debuging
//now output HTML data header
if(readString.indexOf('?') >=0) { //don't send new page
client.println("HTTP/1.1 204 Zoomkat\r\n\r\n");
else if(readString.indexOf("data") >=0)
client.print("<HTML><HEAD>");
client.print("
analog input0 is: ");
client.print(analogRead(analogInPin0));
client.println("
</BODY></HTML>");
else {
client.println("HTTP/1.1 200 OK"); //send new page
client.println("Content-Type: text/html");
client.println();
client.println("<HTML>");
client.println("<HEAD>");
client.println("<TITLE>Arduino GET test page</TITLE>");
client.println("</HEAD>");
client.println("<BODY>");
client.println("<H1>Zoomkat's simple Arduino button</H1>");
client.println("<a href='/?on1' target='inlineframe'>ON</a>");
client.println("<a href='/?off' target='inlineframe'>OFF</a>");
client.println("<a href='/data' target='DataBox'>DATA</a>
client.print("<iframe src='/data' width='350' height='250' name='DataBox'>");
client.print("</iframe>");
client.println("<IFRAME name=inlineframe style='display:none'>");
client.println("</IFRAME>");
client.println("</BODY>");
client.println("</HTML>");
delay(1);
//stopping client
client.stop();
///////////////////// control arduino pin
if(readString.indexOf("on1") >0)//checks for on
digitalWrite(4, HIGH); // set pin 4 high
Serial.println("Led On");
if(readString.indexOf("off") >0)//checks for off
digitalWrite(4, LOW); // set pin 4 low
Serial.println("Led Off");
//clearing string for next read
readString="";
Are you planning on hosting the website from the Arduino itself or on a server?
If you are hosting the website from a server then you can set up a page that will take a POST or even a simple REST command from the Arduino (over ethernet shield) to update a value on the website.
Arduino reads ADC --> ethernet post/REST to server --> Server stores value in DB --> Serves web page
This way you can get real world data with a powerful web server.
But if you want it all in one package, simple website served from the Arduino then zoomkat's solution looks great.
hello Nick Gammon,
I want for example reading data from serial port and then display it on web page i tried to take the data but i can't display it on web page.
thanks,
