web page from sd card (w5100 ethernet shield)
Hi, My native tongue isn´t English. Therefore I´ll apologise up front for any misspelling and incorrect sentence construction. Ok, now to my concern. I cant get the web browser to load any web pages from microsd card.I´ve tried to write the html into the atmega with rest of the code( client.println("...........");) and i´ve played with some sd examples also. They both work fine separately. When ever i insert mi sd card into the shields sd card socket the webpage will not load anymore. My goal would be to load the webpage from the sd card for my home lighting system. I´ve tried this code (http://arduino.cc/forum/index.php?PHPSESSID=75fcb55c4ed02cfe0829fdc3afa7e6ff&topic=162004.0)and many more. But it seems that i´am doing something wrong.Could someone please be helpful and share some thoughts here.Thanks!
Native English speaker or not, posting the same question twice isn't going to make you any friends.
Duplicate deleted.
Sorry for posting twice/littering.I´am not here for seeking friends.I was hoping to get some assistance or a little push to the right direction. Seems like you have got some spare time to make useless comments.Why not to use this time constructively and help me out a little bit.
I already helped you by moving your post from the Programming section where it didn't belong, and deleting your duplicate post - that was your "push in the right direction".
I've helped you as much as I'm going to. Good luck.
puna102: When ever i insert mi sd card into the shields sd card socket the webpage will not load anymore.
What happens? (Does your sketch receive the HTTP request? Does it recognise it and attempt to generate an HTTP response? Does it attempt to open the file in order to generate that response? Does it successfully open the file? Does it read content from the file? Does the content match what you expected? Does it produce a correctly formed HTTP response?)
You need to understand the sequence of actions that the sketch is supposed to perform and compare that to what actually happens to see where the behaviour goes wrong. If you sketch doesn't tell you that, then add trace statements so that it does.
If you still can't figure it out then I suggest you post your code, the content of the SD card (including file / directory names and file content), the URL you're submitting, the trace output you get when you submit it, and details of the response received by your browser.
Program: eth_websrv_SD
Description: Arduino web server that serves up a basic web
page. The web page is stored on the SD card.
Hardware: Arduino Uno and official Arduino Ethernet
shield. Should work with other Arduinos and
compatible Ethernet shields.
2Gb micro SD card formatted FAT16
Software: Developed using Arduino 1.0.3 software
Should be compatible with Arduino 1.0 +
SD card contains web page called index.htm
References: - WebServer example by David A. Mellis and
modified by Tom Igoe
Date: 10 January 2013
Author: W.A. Smith, http://startingelectronics.com
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
// MAC address from Ethernet shield sticker under board
byte mac = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 10, 100); // IP address, may need to change depending on network
EthernetServer server(80); // create a server at port 80
File webFile;
Ethernet.begin(mac, ip); // initialize Ethernet device
server.begin(); // start to listen for clients
Serial.begin(9600); // for debugging
// initialize SD card
Serial.println(“Initializing SD card…”);
if (!SD.begin(4)) {
Serial.println(“ERROR - SD card initialization failed!”);
return; // init failed
Serial.println(“SUCCESS - SD card initialized.”);
// check for index.htm file
if (!SD.exists(“index.htm”)) {
Serial.println(“ERROR - Can’t find index.htm file!”);
return; // can’t find index file
Serial.println(“SUCCESS - Found index.htm file.”);
EthernetClient client = server.available(); // try to get client
if (client) { // got client?
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) { // client data available to read
Serial.println(“Client Available”);
char c = client.read(); // read 1 byte (character) from client
// last line of client request is blank and ends with \n
// respond to client only after last line received
if (c == ‘\n’ && currentLineIsBlank) {
Serial.println(“Print Standard Page Info”);
// send a standard http response header
client.println(“HTTP/1.1 200 OK”);
client.println(“Content-Type: text/html”);
client.println(“Connection: close”);
client.println();
// send web page
webFile = SD.open(“index.htm”); // open web page file
if (webFile) {
while(webFile.available()) {
Serial.println(“WebFile available”);
client.write(webFile.read()); // send web page to client
webFile.close();
Serial.println(“WebFile closed”);
// every line of text received from the client ends with \r\n
if (c == ‘\n’) {
// last character on line of received text
// starting new line with next character read
else if (c != ‘\r’) {
// a text character was received from client
currentLineIsBlank = false;
} // end if (client.available())
} // end while (client.connected())
delay(1); // give the web browser time to receive the data
client.stop(); // close the connection
} // end if (client)
It looks like it does not open the webpage file. Everything till webFile = SD.open(“index.htm”); // open web page file
if (webFile) {
seems to be OK. Please correct me if i´am mistaken.
// With the ethernet shield, the chip select for the
// SD card is not SS (in use for ethernet), but pin 4.
const int chipSelectSD = 4;
  // make sure that the default chip select pin is set to
  // output for the SD, even if you don't use it:
  pinMode(10, OUTPUT);
  // According to this:
  //   http://www.ladyada.net/learn/arduino/ethfiles.html
  // The SS (pin 10) has to be high to disable the W5100
  digitalWrite(10, HIGH);
  // Initializing the SD before the ethernet W5100.
  if (!SD.begin(chipSelectSD))
    // The SD card can't be found.
    Serial.println(F("SD.begin failed"));
  Ethernet.begin ...
  server.begin ....
Thanks to all of you. i´am really grateful.I got it working. It loads a very small page (containing two lines only). It is awfully slow. I´ll keep trying and searching.Meanwhile when someone stumbles on this post and has some good ideas or some examples, feel free to post them.(I´am trying to make a home lighting and shades control system, that can be controlled from pc, or phone). I would be grateful.Once again thanks to you all
Test code that loads files from the SD card fairly rapidly.
//zoomkat 2/26/13
//SD server slider test code
//open serial monitor to see what the arduino receives
//browser address will look like http://192.168.1.102:84/servosld.htm when submited
//for use with W5100 based ethernet shields
//put the servosld.htm, slider.js, bluev_sl.gif,
//and bluev_bg.gif on the SD card
//download flies at:
// http://web.comporium.net/~shb/pix/servosld.htm
// http://web.comporium.net/~shb/pix/slider.js
// http://web.comporium.net/~shb/pix/bluev_bg.gif
// http://web.comporium.net/~shb/pix/bluev_sl.gif
#include <SD.h>
#include <SPI.h>
#include <Servo.h>
Servo myservoa, myservob, myservoc, myservod;  // create servo object to control a servo
Servo myservoe, myservof, myservog; // myservoh not used due to lack of another free pin
String readString, pos;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port
void setup(){
  // disable w5100 while setting up SD
  pinMode(10,OUTPUT);
  digitalWrite(10,HIGH);
  Serial.print("Starting SD..");
  if(!SD.begin(4)) Serial.println("failed");
  else Serial.println("ok");
  Ethernet.begin(mac, ip, gateway, gateway, subnet);
  //delay(2000);
  server.begin();
  Serial.println("Ready");
  myservoa.attach(2);  //the pin for the servoa control
  myservob.attach(3);  //the pin for the servob control
  myservoc.attach(5);  //the pin for the servoc control
  myservod.attach(6);  //the pin for the servod control
  myservoe.attach(7);  //the pin for the servoa control
  myservof.attach(8);  //the pin for the servob control
  myservog.attach(9);  //the pin for the servoc control
  //myservoh.attach(10);  //the pin for the servod control
void loop(){
  // Create a client connection
  if (client) {
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          Serial.println(readString); //print to serial monitor for debuging
            //select proper header for file to be sent to browser
          client.println("HTTP/1.1 200 OK"); //send new page
          if(readString.indexOf("servosld") >=0) {
            client.println("Content-Type: text/html");
            client.println();
          if(readString.indexOf("slider") >=0) {
            client.println("Content-Type: application/x-javascript");
            client.println();
          if(readString.indexOf("bluev") >=0) {
            client.println("Content-Type: image/gif");
            client.println();
          //select file to send to browser
            File myFile = SD.open("SERVOSLD.HTM");
            if (myFile) {
              byte clientBuf[64];
              int clientCount = 0;
              while (myFile.available())
                clientBuf[clientCount] = myFile.read();
                clientCount++;
                if(clientCount > 63)
                  client.write(clientBuf,64);
                  clientCount = 0;
              if(clientCount > 0) client.write(clientBuf,clientCount);
              myFile.close();
            File myFile = SD.open("slider.js");
            if (myFile) {
              byte clientBuf[64];
                clientCount++;
                  clientCount = 0;
              myFile.close();
          if(readString.indexOf("bluev_sl") >=0) {
            File myFile = SD.open("bluev_sl.gif");
            if (myFile) {
              byte clientBuf[64];
                clientCount++;
                  clientCount = 0;
              myFile.close();
          if(readString.indexOf("bluev_bg") >=0) {
            File myFile = SD.open("bluev_bg.gif");
            if (myFile) {
              byte clientBuf[64];
                clientCount++;
                  clientCount = 0;
              myFile.close();
          delay(1);
          //stopping client
          client.stop();
          //process GET string request from client and and position servo
          pos = readString.substring(8, 12); //get the first four characters
          //Serial.println(pos);
          int n = pos.toInt();  //convert readString into a number
          Serial.println(n);
          if(readString.indexOf("?0") >0) myservoa.writeMicroseconds(n);
          if(readString.indexOf("?1") >0) myservob.writeMicroseconds(n);
          if(readString.indexOf("?2") >0) myservoc.writeMicroseconds(n);
          if(readString.indexOf("?3") >0) myservod.writeMicroseconds(n);
          if(readString.indexOf("?4") >0) myservoe.writeMicroseconds(n);
          if(readString.indexOf("?5") >0) myservof.writeMicroseconds(n);
          if(readString.indexOf("?6") >0) myservog.writeMicroseconds(n);
          //only seven servo pins, so back to myservoa for testing
          if(readString.indexOf("?7") >0) myservoa.writeMicroseconds(n);
          //clearing string for next read
          readString="";
          pos="";
Hi everyone. I´am stuck again.I took an example sketch from: http://startingelectronics.com/tutorials/arduino/ethernet-shield-web-server-tutorial/SD-card-IO/
I got it to load the web page but that´s all. It doesn´ t show thw analog values and buttons and check boxes do not respond. Has anyone any ideas what am i doing wrong?
  Program:      eth_websrv_SD_Ajax_in_out
  Description:  Arduino web server that displays 4 analog inputs,
                the state of 3 switches and controls 4 outputs,
                2 using checkboxes and 2 using buttons.
                The web page is stored on the micro SD card.
                2Gb micro SD card formatted FAT16.
                A2 to A4 analog inputs, pins 2, 3 and 5 for
                the switches, pins 6 to 9 as outputs (LEDs).
                - SD card examples by David A. Mellis and
                  Tom Igoe
                - Ethernet library documentation:
                  http://arduino.cc/en/Reference/Ethernet
                - SD Card library documentation:
                  http://arduino.cc/en/Reference/SD
  Date:         4 April 2013
#include <SPI.h>
#include <SD.h>
// size of buffer to store received HTTP request
#define REQ_SIZE 60
File webFile;               // the web page file on the SD card
String HTTP_req;            // stores the HTTP request
int req_index = 0;          // limits size of stored HTTP request
boolean LED_state[4] = {0}; // stores the states of the LEDs
  pinMode(10,OUTPUT);
    Serial.println("Initializing SD card...");
    if (!SD.begin(4)) {
        Serial.println("ERROR - SD card initialization failed!");
    Serial.println("SUCCESS - SD card initialized.");
    if (!SD.exists("index.htm")) {
        Serial.println("ERROR - Can't find index.htm file!");
        return;  // can't find index file
    Serial.println("SUCCESS - Found index.htm file.");
    // switches on pins 2, 3 and 5
    pinMode(2, INPUT);
    pinMode(3, INPUT);
    pinMode(5, INPUT);
    // LEDs
    pinMode(6, OUTPUT);
    pinMode(7, OUTPUT);
    pinMode(8, OUTPUT);
    pinMode(9, OUTPUT);
    digitalWrite(10,LOW);
                // limit the size of the stored received HTTP request
                if (req_index < REQ_SIZE) {
                    HTTP_req += c;  // save the HTTP request 1 char at a time
                    req_index++;
                if (c == '\n' && currentLineIsBlank) {
                    // remainder of header follows below, depending on if
                    // web page or XML page is requested
                    // Ajax request - send XML file
                    if (HTTP_req.indexOf("ajax_inputs") > -1) {
                        // send rest of HTTP header
                        client.println("Content-Type: text/xml");
                        client.println("Connection: keep-alive");
                        client.println();
                        SetLEDs();
                        // send XML file containing input states
                        XML_response(client);
                    else {  // web page request
                        client.println();
                        // send web page
                    SD.begin(4);
                        webFile = SD.open("index.htm");        // open web page file
                        if (webFile) {
                           byte clientBuf[64];
                             clientBuf[clientCount] = webFile.read();
                clientCount++;
                  clientCount = 0;
                            webFile.close();
                    // display received HTTP request on serial port
                    HTTP_req = "";          // finished with request, empty string
                    req_index = 0;          // reset HTTP request character counter
                if (c == '\n') {
                else if (c != '\r') {
// checks if received HTTP request is switching on/off LEDs
// also saves the state of the LEDs
void SetLEDs(void)
    // LED 1 (pin 6)
    if (HTTP_req.indexOf("LED1=1") > -1) {  // switch LED on?
        LED_state[0] = 1;  // save LED state
        digitalWrite(6, HIGH);
    else if (HTTP_req.indexOf("LED1=0") > -1) { // switch LED off?
        LED_state[0] = 0;  // save LED state
        digitalWrite(6, LOW);
    // LED 2 (pin 7)
    if (HTTP_req.indexOf("LED2=1") > -1) {
        LED_state[1] = 1;  // save LED state
        digitalWrite(7, HIGH);
    else if (HTTP_req.indexOf("LED2=0") > -1) {
        LED_state[1] = 0;  // save LED state
        digitalWrite(7, LOW);
    // LED 3 (pin 8)
    if (HTTP_req.indexOf("LED3=1") > -1) {
        LED_state[2] = 1;  // save LED state
        digitalWrite(8, HIGH);
    else if (HTTP_req.indexOf("LED3=0") > -1) {
        LED_state[2] = 0;  // save LED state
        digitalWrite(8, LOW);
    // LED 4 (pin 9)
    if (HTTP_req.indexOf("LED4=1") > -1) {
        LED_state[3] = 1;  // save LED state
        digitalWrite(9, HIGH);
    else if (HTTP_req.indexOf("LED4=0") > -1) {
        LED_state[3] = 0;  // save LED state
        digitalWrite(9, LOW);
[code]// send the XML file with analog values, switch status
//  and LED status
void XML_response(EthernetClient cl)
    int analog_val;            // stores value read from analog inputs
    int count;                 // used by 'for' loops
    int sw_arr[] = {2, 3, 5};  // pins interfaced to switches
    cl.print("<?xml version = \"1.0\" ?>");
    cl.print("<inputs>");
    // read analog inputs
    for (count = 2; count <= 5; count++) { // A2 to A5
        analog_val = analogRead(count);
        cl.print("<analog>");
        cl.print(analog_val);
        cl.println("</analog>");
    // read switches
    for (count = 0; count < 3; count++) {
        cl.print("<switch>");
        if (digitalRead(sw_arr[count])) {
            cl.print("ON");
        else {
            cl.print("OFF");
        cl.println("</switch>");
    // checkbox LED states
    // LED1
    cl.print("<LED>");
    if (LED_state[0]) {
        cl.print("checked");
    else {
        cl.print("unchecked");
    cl.println("</LED>");
    // LED2
    cl.print("<LED>");
    if (LED_state[1]) {
    else {
    // button LED states
    // LED3
    cl.print("<LED>");
    if (LED_state[2]) {
        cl.print("on");
    else {
        cl.print("off");
    // LED4
    cl.print("<LED>");
    if (LED_state[3]) {
        cl.print("on");
    else {
        cl.print("off");
    cl.print("</inputs>");
[/code]
