I have a Yun, and I just can’t get my web browser to blink some lights. Can someone give me a hint ? I am pointing my browser at 192.168.2.14/arduino/xxx I can upload over wifi and ping the Yun.
I just want to blink the light to get started, but no luck. thanks, bill
if (client) {
String command = client.readString();
digitalWrite(13, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(13, LOW); // turn the LED off by making the voltage LOW
client.stop();
// Possible commands are listed here:
// "digital/13" -> digitalRead(13)
// "digital/13/1" -> digitalWrite(13, HIGH)
// "analog/2/123" -> analogWrite(2, 123)
// "analog/2" -> analogRead(2)
// "mode/13/input" -> pinMode(13, INPUT)
// "mode/13/output" -> pinMode(13, OUTPUT)
#include <Bridge.h>
#include <YunServer.h>
#include <YunClient.h>
// Listen on default port 5555, the webserver on the Yun
// will forward there all the HTTP requests for us.
YunServer server;
// Bridge startup
pinMode(13,OUTPUT);
Bridge.begin();
// Listen for incoming connection only from localhost
// (no one from the external network could connect)
server.listenOnLocalhost();
server.begin();
// Get clients coming from server
YunClient client = server.accept();
// There is a new client?
if (client) {
// Process request
process(client);
// Close connection and free resources.
client.stop();
delay(50); // Poll every 50ms
void process(YunClient client) {
// read the command
String command = client.readStringUntil('/');
// is "digital" command?
if (command == "digital") {
digitalCommand(client);
// is "analog" command?
if (command == "analog") {
analogCommand(client);
// is "mode" command?
if (command == "mode") {
modeCommand(client);
void digitalCommand(YunClient client) {
int pin, value;
// Read pin number
pin = client.parseInt();
// If the next character is a '/' it means we have an URL
// with a value like: "/digital/13/1"
if (client.read() == '/') {
value = client.parseInt();
digitalWrite(pin, value);
else {
value = digitalRead(pin);
// Send feedback to client
client.print(F("Pin D"));
client.print(pin);
client.print(F(" set to "));
client.println(value);
// Update datastore key with the current pin value
String key = "D";
key += pin;
Bridge.put(key, String(value));
void analogCommand(YunClient client) {
int pin, value;
// Read pin number
// with a value like: "/analog/5/120"
// Read value and execute command
analogWrite(pin, value);
client.print(pin);
client.print(F(" set to analog "));
String key = "D";
key += pin;
else {
// Read analog pin
value = analogRead(pin);
client.print(F("Pin A"));
client.print(pin);
client.print(F(" reads analog "));
String key = "A";
key += pin;
void modeCommand(YunClient client) {
int pin;
// Read pin number
// If the next character is not a '/' we have a malformed URL
if (client.read() != '/') {
client.println(F("error"));
return;
String mode = client.readStringUntil('\r');
if (mode == "input") {
pinMode(pin, INPUT);
client.print(pin);
client.print(F(" configured as INPUT!"));
return;
if (mode == "output") {
pinMode(pin, OUTPUT);
client.print(pin);
client.print(F(" configured as OUTPUT!"));
return;
client.print(F("error: invalid mode "));
client.print(mode);
Additionally, I don’t understand when the page talks about “REST” (I know POST and GET) and the required password… Isn’t there an index of yun-related tutorials, or a single step-by-step Yun guide?
Till now what I understood and what I miss is:
Create a suitable webpage (how??)
Put the web page in \arduino\www folder in SD card
Create a suitable Sketch to decode commands received from webpage (ok, see tutorial)
Setup a [yunname].local/ address (how?? is it done by Arduino IDE installer or what? Can I setup such address by installing just the ZIP version of the IDE?)
Connect to Yun using [yunname].local/sd/mypage.html - Can I connect by WiFi to a Yun not connected to internet?
I created this page, would it work? (I did not yet purchase a Yun
But how do I pass a parameter from sketch to web page?
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
</head>
<body>
<script type="text/javascript">
var StatoLed = -1;
function Accendi() {
//window.open("http://myArduinoYun.local/arduino/digital/13/1","CommandWindow"); // Accendi LED
StatoLed = 1; // In realtà deve impostarla la funzione Leggi()
Leggi();
function Spegni() {
//window.open("http://myArduinoYun.local/arduino/digital/13/0","CommandWindow"); // Spegni LED
StatoLed = 0; // In realtà deve impostarla la funzione Leggi()
Leggi();
function Leggi() {
window.open("http://myArduinoYun.local/arduino/digital/13","CommandWindow"); // Leggi LED
// E il valore letto dove viene messo??
// StatoLed = ??? ; // DEBUG
if (StatoLed == 0) {
document.getElementById("Led13_on").checked = false;
document.getElementById("Led13_off").checked = true;
alert("Spento?");
if (StatoLed == 1) {
document.getElementById("Led13_on").checked = true;
document.getElementById("Led13_off").checked = false;
alert("Acceso?");
</script>
<input type="submit" value="ACCENDI" id="btn_on" onclick="Accendi();">
<input type="submit" value="Spegni" id="btn_off" onclick="Spegni();">
<input type="radio" name="Led13" value="on" id="Led13_on" checked disabled>Acceso
<input type="radio" name="Led13" value="off" id="Led13_off" disabled>Spento
</body>
</html>
jumpjack: You are asking some very broad and general questions, which is not in the same scope as the original question. It's best to start a new topic for questions that are so significantly different.
Since any answers to your questions would probably be interesting to a wide audience, I've started a new thread to discuss your questions HERE. Please respond in that thread, do not continue to post to this one.
