Good day,
Which would be the best choice? Web Server or Pachube?
Using an Arduino and Ethernet shield. Display on a web page one or more lines of text with a check box. Text will come from the SD card on the ethernet shield. The user will view from a computer or Android phone. (web Browser) Select the checkbox which will remove the text from the web page and from the SD card.
The text will be a grocery/item list. As you purchase the item then you can check it so it is removed from the list on the web page.
What do you think? I'm also looking for example code in either method to receive data back from the web page so I can remove it from the SD card.
Thanks Randy
