Web-server-php-script-arduino-code-help
Hi. Sorry for the confusing subject tile.
I am trying to make a automatic flower "guard" that is suposed to water a couple of plants when the soil is estimated to be too dry. This is done with the arduino taking measurements from two analog pins and send their value to a php-script on a web server, storing the values in a database and presenting them on a web page. I works fine exept for the fact that measurements are only sent once. If I want to get measurements presented on the web page continually I must compile my arduino program again. I have made a small version of my main code that only sends values to the web server from the analog pins to make troubleshooting easier.
    #include <SPI.h>
    #include <Ethernet.h>
  // Pin Defination:---------------------------------------------------------------------------------------------------------------
     unsigned int localPort = 8888;
     int fukt_sensor_01 = A5;  // Analog fuktighetsmätare Input_Pin 1
     int fukt_sensor_02 = A4;  // Analog fuktighetsmätare Input_Pin 2
   //+++++++++++++++++++++++++++++++++++++++++++++ Define Values ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
     int fukt_val_01, fukt_val_02;
  // +++++++++++++++++++++++++++++++++ Arduino standard setup +++++++++++++++++++++++++++++++++++++++++++
  // Enter a MAC address and IP address for your controller below.
  // The IP address will be dependent on your local network:
  byte mac[] = {  0x90, 0xA2, 0xDA, 0x00, 0x3C, 0xAE };    //Arduino MAC
  byte ip[] = { 193,10,39,166 };     //Arduino IP
  byte server[] = { 194,68,48,95 }; // benriach.widell.net
  // Initialize the Ethernet client library
  // with the IP address and port of the server
  // that you want to connect to (port 80 is default for HTTP):
  Client client(server, 80);
        // initialize the pins
  	//-------------sen_01---------------
        pinMode(fukt_sensor_01,INPUT);   // Analog pin
        //-------------sen_02---------------
        pinMode(fukt_sensor_02,INPUT);   // Analog pin
          Ethernet.begin(mac, ip);
  	// setup serial communication
        Serial.println("connecting...");
        delay(2000);
        if (client.connect())
          Serial.println("network connected");
        // kf you didn't get a connection to the server:
        Serial.println("connection failed");
void loop  ()
//======================== For sensor 01 ===============================================================================
          fukt_val_01 = analogRead(fukt_sensor_01); // read sensor 01
//======================== For sensor 02 ===============================================================================
          fukt_val_02 = analogRead(fukt_sensor_02); // read sensor 02
          char values_to_send[70];
          sprintf(values_to_send,"%s%d%s%d%s\n","GET /~david/test.php?fukt_val_01=",fukt_val_01,"&fukt_val_02=",fukt_val_02," HTTP/1.0");
          client.println(values_to_send);
         delay(10000);
Typically, there needs to be two carriage return/line feed combinations sent to signal the end of client data. You are only sending one. Try adding a second client.println(), that prints nothing (except the cr/ln).
Where is the code to read the reply? What is the purpose of sending data again 10 seconds later, if the previous send failed?
Thank you. I will try that as soon as I am able. This is just a test code. In the real code the sends will be much more sparse.
