Dear all,
I have code as below . I need your help in below coding. I want to keep edit option For setting date and time ,
If edit date and time is ticked . you can make changes over Web
if edit date and time is unchecked . you see current date and time.
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,1, 178);
EthernetServer server(80);
#include "Wire.h"
#define DS1307_ADDRESS 0x68
byte zero = 0x00; //workaround for issue #527
static int dd;
static int mm;
static int yy;
static int s;
static int h;
static int m;
static int wkDay;
int CENTURY=2000;
int RTC_ERROR_FLAG=0;
void getRTCDateTime(){
Wire.beginTransmission(DS1307_ADDRESS);
Wire.write(zero);
Wire.endTransmission();
Wire.requestFrom(DS1307_ADDRESS, 7);
if(RTC_ERROR_FLAG==0)
//Serial.println("RTC IS ACTIVE :\n");
s = bcdToDec(Wire.read());
m = bcdToDec(Wire.read());
h = bcdToDec(Wire.read() & 0b111111); //24 hour time
wkDay = bcdToDec(Wire.read()); //0-6 -> sunday - Saturday
dd = bcdToDec(Wire.read());
mm = bcdToDec(Wire.read());
yy = CENTURY + bcdToDec(Wire.read());
byte decToBcd(byte val){
// Convert normal decimal numbers to binary coded decimal
return ( (val/10*16) + (val%10) );
byte bcdToDec(byte val) {
// Convert binary coded decimal to normal decimal numbers
return ( (val/16*10) + (val%16) );
int getLastTwoDigOfYear(int y){
return(y%1000);
void rtcWrite(){
Wire.write(zero); //stop Oscillator
Wire.write(decToBcd(s));
Wire.write(decToBcd(m));
Wire.write(decToBcd(h));
Wire.write(decToBcd(wkDay));
Wire.write(decToBcd(dd));
Wire.write(decToBcd(mm));
Wire.write(decToBcd(getLastTwoDigOfYear(yy)));
Wire.write(zero); //start
Wire.begin();
Ethernet.begin(mac, ip);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
getRTCDateTime();
Ethernet_webserver();
void Ethernet_webserver()
if (client)
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connnection: close");
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<html>");
// add a meta refresh tag, so the browser pulls again every 5 seconds:
client.println("<meta http-equiv=\"refresh\" content=\"5\">");
// add sententence here
client.print("LOCAL DATE :");
client.print(dd);
client.print("/");
client.print(mm);
client.print("/");
client.print(yy);
client.println("
client.print("LOCAL TIME :");
client.print(h);
client.print("/");
client.print(m);
client.print("/");
client.print(s);
client.println("
client.println("</html>");
if (c == '\n') {
// you're starting a new line
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println("client disonnected");
