Hi guys!
When i compile my web server in the IDE of arduino, for 1 second the web server work perfectly.
This is my sketch:
#include <SPI.h>
#include <Ethernet.h>
// MAC address from Ethernet shield sticker under board
byte mac[] = { 0x90, 0xAD, 0xDA, 0x0D, 0xBB, 0x29 };
IPAddress ip(192, 168, 1, 190); // IP address, may need to change depending on network
EthernetServer server(80); // create a server at port 80
String HTTP_req; // stores the HTTP request
boolean LED_status = 0; // state of LED, off by default
Ethernet.begin(mac, ip); // initialize Ethernet device
server.begin(); // start to listen for clients
Serial.begin(9600); // for diagnostics
pinMode(2, OUTPUT); // LED on pin 2
EthernetClient client = server.available(); // try to get client
if (client) { // got client?
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) { // client data available to read
char c = client.read(); // read 1 byte (character) from client
HTTP_req += c; // save the HTTP request 1 char at a time
// last line of client request is blank and ends with \n
// respond to client only after last line received
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connection: close");
client.println();
// send web page
client.println("");
client.println("");
client.println("");
client.println("Arduino LED Control");
client.println("");
client.println("");
client.println("
LED
");client.println("
Click to switch LED on and off.
");client.println("<form method="get">");
ProcessCheckbox(client);
client.println("");
client.println("");
client.println("");
Serial.print(HTTP_req);
HTTP_req = ""; // finished with request, empty string
// every line of text received from the client ends with \r\n
if (c == '\n') {
// last character on line of received text
// starting new line with next character read
else if (c != '\r') {
// a text character was received from client
currentLineIsBlank = false;
} // end if (client.available())
} // end while (client.connected())
delay(1); // give the web browser time to receive the data
client.stop(); // close the connection
} // end if (client)
// switch LED and send back HTML for LED checkbox
void ProcessCheckbox(EthernetClient cl)
if (HTTP_req.indexOf("LED2=2") > -1) { // see if checkbox was clicked
// the checkbox was clicked, toggle the LED
if (LED_status) {
LED_status = 0;
else {
LED_status = 1;
if (LED_status) { // switch LED on
digitalWrite(2, HIGH);
// checkbox is checked
cl.println("<input type="checkbox" name="LED2" value="2"
onclick="submit();" checked>LED2");
else { // switch LED off
digitalWrite(2, LOW);
// checkbox is unchecked
onclick="submit();">LED2");
When i have finish the compiled the web server work, but after few seconds the server stops Responding and Error . I must then recompile the server and works again for a few seconds .
I also tried with the sketch example of the web server , and there is the same error . Can anyone help ?
