Please help, I have almost finished my Simple Thermostat Project.
Code is below.
Temperature is measured using a LM35, and is known as temperatureC in my program, I also have a setpoint. I have this working so that it controls the relay depending on the value of the setpoint.
I had a keypad which called incUP() and incdown() which worked fine. But I removed the keypad I want to set the setpoint remotley via web page.
I have managed to display the temperature and Setpoint on a webpage after a good explanation of Pauls.
But know I'm truly stuck.
I need a Inc and dec button in my webpage function to toggle a flag or state on off so to call the IncUp or Down Fucntion.
Please help.
Code below. Thanks Andy
//Headers
#include <EtherCard.h>
#include <EEPROM.h>
#include <Wire.h>
//option #include <HCMatrixKeypad.h>
//Webpage
boolean toggle;
static uint8_t IPaddress[] = { 192,168,1,225 };
static uint8_t GatewayIP[] = { 192,168,1,1 };
static uint8_t MACAddress[6] = {0x54, 0x55, 0x58, 0x10, 0x00, 0x24};
byte Ethernet::buffer[500];
BufferFiller bfill;
/* Initialise the LiquidCrystal library */
LiquidCrystal_I2C lcd(0x27,20,4);
/* Optional Keypad */
const int DEBOUNCE = 10;
//const byte Left = 4; // Column number of Left key
//const byte Right = 3; // Column number of Right key
//Declare Variables
float setpoint;
char temp_str[10];
char setpoint_str[10];
float temperatureC;
const int sensorPin = A2;
setupnic();
lcd.init();
EEPROM.read (1); // make the eeprom or atmega328 memory address 1
setpoint = EEPROM.read(1);
setpoint = 20;
lcd.begin(16, 2);
lcd.print("Deg C");
lcd.setCursor(6, 0);
lcd.print("SetP");
pinMode(13, OUTPUT);
pinMode(9, OUTPUT);
/* Main program */
web();
lcd.backlight();
temperatureC = gettemp();
dtostrf(temperatureC,6,2,temp_str);
dtostrf(setpoint,6,2,setpoint_str);
lcd.setCursor(0, 1);
lcd.print(temperatureC);
lcd.setCursor(6, 1);
lcd.print (setpoint);
if (temperatureC +0.5 < setpoint)
digitalWrite(9, HIGH);
if (temperatureC -0.5 > setpoint)
digitalWrite(9, LOW);
void setupnic(){
Serial.print ("INIT");
if (ether.begin(sizeof Ethernet::buffer, MACAddress) == 0)
/* If it failed to initialise then do nothing */
while(1);
/* Else set up a fixed IP address */
ether.staticSetup(IPaddress, GatewayIP);
void web(){
/* Get length of recived packet */
word PacketLength = ether.packetReceive();
word pos = ether.packetLoop(PacketLength);
/* Has a valid packet been received? If so, then send the web page */
if (ether.packetLoop(PacketLength))
ether.httpServerReply(ExampleContenet());
static word ExampleContenet()
BufferFiller bfill = ether.tcpOffset();
bfill.emit_p(PSTR(
"HTTP/1.0 200 OK\r\n"
"Content-Type: text/html\r\n"
"Pragma: no-cache\r\n\r\n"
// if you want to enable the auto refresh mode
// "<meta http-equiv='refresh' content='5'/>"
"<html><head><title>Web Control</title></head><body>"
"<body bgcolor=""#ccccff"">"
"<font size=""6"">"
"<center>
"Temperature... : "
"<b> $S °C </b>
"Desired Temperature... : "
"<b> $S °C </b>
"____________________
temp_str,setpoint_str);
return bfill.position();
float gettemp() {
// converting an analog reading to a voltage,
// for 3.3v arduino use 3.3
float voltage = (analogRead(sensorPin));
float millivolts= (voltage/1024.0) * 5000;
float celsius= millivolts/10;
//converting from 10 mv per degree C with 500 mV offset
//to degrees ((voltage - 500mV) times 100)
delay(10);
return (celsius) ;
void incUP() {
setpoint = setpoint + 1;
EEPROM.write (1, setpoint);
void incDown() {
setpoint = setpoint - 1;
