WEB SERVER WITH MUTIPLE LEDs
i’m trying to just to turn on and off few leds, program work ok when i turn on one led then turn it off, and turn on different led or same but it gives me all sort of errors when i try to use more than one led on same time (connection time out, reset, arduino not responding), i’m thinking this is a memory (RAM) issue, but as i’m new to this i have no idea where to look for, Please help
#include <SPI.h>
#include <Ethernet.h>
byte mac = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,1,177);
String readString = String(100);
String led = String(4);
String value = String(1);
byte x=0;
byte ledst1=0,ledst2=0,ledst3=0;
byte ledr=5,ledg=6,ledb=7;
EthernetServer server(80);
pinMode(ledr, OUTPUT);
pinMode(ledg, OUTPUT);
pinMode(ledb, OUTPUT);
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
server.begin();
Serial.print("server is at ");
Serial.println(Ethernet.localIP());
// listen for incoming clients
if (client) {
Serial.println(“new client”);
readString = “”;
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
if(readString.length() < 100){
readString+=c;
// if you’ve gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == ‘\n’ && currentLineIsBlank) {
// send a standard http response header
client.println(“HTTP/1.1 200 OK”);
client.println(“Content-Type: text/html”);
client.println(“Connection: close”); // the connection will be closed after completion of the response
if(readString.indexOf("/?led")>0){
processRequest();
client.println();
client.println("");
client.println("");
client.println("");
client.println(“
Hello From Arduino
client.println("
client.println(readString);
client.println("
String form = getForm();
client.println(form);
client.println("");
client.println("");
if (c == ‘\n’) {
// you’re starting a new line
else if (c != ‘\r’) {
// you’ve gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(100);
// close the connection:
client.stop();
Serial.println(“client disonnected”);
void processRequest(){
//Turn the leds on and set the status
x = readString.indexOf("/?")+2;
led = readString.substring(x,x+4);
value = readString.substring(x+5,x+6);
Serial.println(led);
Serial.println(value);
if(led==“led1”){
if(value == “1”){
digitalWrite(ledr, HIGH);
ledst1 = 1;
}else{
digitalWrite(ledr, LOW);
ledst1 = 0;
}else if(led==“led2”){
if(value == “1”){
digitalWrite(ledg, HIGH);
ledst2 = 1;
}else{
digitalWrite(ledg, LOW);
ledst2 = 0;
}else if(led==“led3”){
if(value == “1”){
digitalWrite(ledb, HIGH);
ledst3 = 1;
}else{
digitalWrite(ledb, LOW);
ledst3 = 0;
String getForm(){
String data = “”;
if(ledst1==0){
data += "LED 1 ON
}else{
data += "LED 1 OFF
if(ledst2==0){
data += "LED 2 ON
}else{
data += "LED 2 OFF
if(ledst3==0){
data += "LED 3 ON
}else{
data += "LED 3 OFF
data += “”;
return data;
Learn to use the F() macro (usable for all print()/println() calls with only a constant string as the argument) and eliminate the use of the String object, use C strings (character arrays) instead. An Arduino UNO has 2kB of RAM, you have to take care for it and use as less as possible of it.
The below is combined client/server code that shows the use of the F() macro. Large sections of static text strings can also be bundled into a single F() macro.
//zoomkat 7-03-12, combined client and server
//simple button GET with iframe code
//for use with IDE 1.0
//open serial monitor and send an g to test client and
//see what the arduino client/server receives
//web page buttons make pin 5 high/low
//use the ' in html instead of " to prevent having to escape the "
//address will look like http://192.168.1.102:84 when submited
//for use with W5100 based ethernet shields
//note that the below bug fix may be required
// http://code.google.com/p/arduino/issues/detail?id=605
#include <SPI.h>
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //assign arduino mac address
byte ip[] = {192, 168, 1, 102 }; // ip in lan assigned to arduino
byte gateway[] = {192, 168, 1, 1 }; // internet access via router
byte subnet[] = {255, 255, 255, 0 }; //subnet mask
EthernetServer server(84); //server port arduino server will use
EthernetClient client;
char serverName[] = "web.comporium.net"; // (DNS) zoomkat's test web page server
//byte serverName[] = { 208, 104, 2, 86 }; // (IP) zoomkat web page server IP address
String readString; //used by server to capture GET request
void setup(){
  pinMode(5, OUTPUT); //pin selected to control
  pinMode(6, OUTPUT); //pin selected to control
  pinMode(7, OUTPUT); //pin selected to control
  pinMode(8, OUTPUT); //pin selected to control
  //pinMode(5, OUTPUT); //pin 5 selected to control
  Ethernet.begin(mac,ip,gateway,gateway,subnet);
  server.begin();
  Serial.println(F("server/client 1.0 test 7/03/12")); // keep track of what is loaded
  Serial.println(F("Send an g in serial monitor to test client")); // what to do to test client
void loop(){
  // check for serial input
  if (Serial.available() > 0)
    byte inChar;
    inChar = Serial.read();
    if(inChar == 'g')
      sendGET(); // call client sendGET function
  if (client) {
        //read char by char HTTP request
        if (readString.length() < 100) {
          //store characters to string
          readString += c;
          //Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          Serial.print(readString); //print to serial monitor for debuging
            //now output HTML data header
          if(readString.indexOf('?') >=0) { //don't send new page
            client.println(F("HTTP/1.1 204 Zoomkat"));
            client.println();
            client.println();
          else {
            client.println(F("HTTP/1.1 200 OK")); //send new page on browser request
            client.println(F("Content-Type: text/html"));
            client.println();
            client.println(F("<HTML>"));
            client.println(F("<HEAD>"));
            client.println(F("<TITLE>Arduino GET test page</TITLE>"));
            client.println(F("</HEAD>"));
            client.println(F("<BODY>"));
            client.println(F("<H1>Zoomkat's simple Arduino 1.0 button</H1>"));
            // DIY buttons
            client.println(F("Pin5"));
            client.println(F("<a href=/?on2 target=inlineframe>ON</a>"));
            client.println(F("<a href=/?off3 target=inlineframe>OFF</a>
            client.println(F("Pin6"));
            client.println(F("<a href=/?on4 target=inlineframe>ON</a>"));
            client.println(F("<a href=/?off5 target=inlineframe>OFF</a>
            client.println(F("Pin7"));
            client.println(F("<a href=/?on6 target=inlineframe>ON</a>"));
            client.println(F("<a href=/?off7 target=inlineframe>OFF</a>
            client.println(F("Pin8"));
            client.println(F("<a href=/?on8 target=inlineframe>ON</a>"));
            client.println(F("<a href=/?off9 target=inlineframe>OFF</a>
            client.println(F("Pins"));
            client.println(F("&nbsp;<a href=/?off2468 target=inlineframe>ALL ON</a>"));
            client.println(F("&nbsp;<a href=/?off3579 target=inlineframe>ALL OFF</a>
                      // mousedown buttons
          client.println(F("<input type=button value=ON onmousedown=location.href='/?on4;' target=inlineframe>"));
          client.println(F("<input type=button value=OFF onmousedown=location.href='/?off5;' target=inlineframe>"));
          client.println(F("&nbsp;<input type=button value='ALL OFF' onmousedown=location.href='/?off3579;' target=inlineframe>
          // mousedown radio buttons
          client.println(F("<input type=radio onmousedown=location.href='/?on6;' target=inlineframe>ON</>"));
          client.println(F("<input type=radio onmousedown=location.href='/?off7; target=inlineframe'>OFF</>"));
          client.println(F("&nbsp;<input type=radio onmousedown=location.href='/?off3579;' target=inlineframe>ALL OFF</>
          // custom buttons
          client.print(F("<input type=submit value=ON target=inlineframe style=width:100px;height:45px onClick=location.href='/?on8;'>"));
          client.print(F("<input type=submit value=OFF target=inlineframe style=width:100px;height:45px onClick=location.href='/?off9;' target=inlineframe>"));
          client.print(F("&nbsp;<input type=submit value='ALL OFF' target=inlineframe style=width:100px;height:45px onClick=location.href='/?off3579;' target=inlineframe>"));
            client.println(F("<IFRAME name=inlineframe style='display:none'>"));
            client.println(F("</IFRAME>"));
            client.println(F("</BODY>"));
            client.println(F("</HTML>"));
          delay(1);
          //stopping client
          client.stop();
          ///////////////////// control arduino pin
          if(readString.indexOf('2') >0)//checks for 2
            digitalWrite(5, HIGH);    // set pin 5 high
            Serial.println("Led 5 On");
          if(readString.indexOf('3') >0)//checks for 3
            digitalWrite(5, LOW);    // set pin 5 low
            Serial.println("Led 5 Off");
          if(readString.indexOf('4') >0)//checks for 4
            digitalWrite(6, HIGH);    // set pin 6 high
            Serial.println("Led 6 On");
          if(readString.indexOf('5') >0)//checks for 5
            digitalWrite(6, LOW);    // set pin 6 low
            Serial.println("Led 6 Off");
          if(readString.indexOf('6') >0)//checks for 6
            digitalWrite(7, HIGH);    // set pin 7 high
            Serial.println("Led 7 On");
          if(readString.indexOf('7') >0)//checks for 7
            digitalWrite(7, LOW);    // set pin 7 low
            Serial.println("Led 7 Off");
          if(readString.indexOf('8') >0)//checks for 8
            digitalWrite(8, HIGH);    // set pin 8 high
            Serial.println("Led 8 On");
          if(readString.indexOf('9') >0)//checks for 9
            digitalWrite(8, LOW);    // set pin 8 low
            Serial.println("Led 8 Off");
          //clearing string for next read
          readString="";
void sendGET() //client function to send and receive GET data from external server.
  if (client.connect(serverName, 80)) {
    Serial.println(F("connected"));
    client.println(F("GET /~shb/arduino.txt HTTP/1.1"));
    client.println(F("Host: web.comporium.net"));
    client.println(F("Connection: close"));
    client.println();
  else {
    Serial.println(F("connection failed"));
  while(client.connected() && !client.available()) delay(1); //waits for data
  while (client.connected() || client.available()) { //connected or data available
    Serial.print(c);
  Serial.println(F("disconnecting."));
  Serial.println(F("=================="));
  client.stop();
Thanks Guys, trouble is not my code, but i learn some new stuff from you guys, my problem was when i turn on single color(i used a RGB) these codes works fine but if try to use the two or all three colors arduino kind of stuck.
problem was i wasn't using a current limiting resistor for led, i thought i won't be a problem. but all solved when attached a 47 ohm to the ground pin of my led.
thanks for all the help
