WebClient example with static IP not working
Any ideas? I'm using the WebClient example from the Ethernet library on Arduino 1.0 with no modifications except adding a static IP address. It works fine with DHCP, but with a static IP the client.connect() call fails.
Here is the failure I get in the console - just as if the server doesn't respond.
connecting...
connection failed
disconnecting.
I've even tried increasing the delay to 5s in case the WizNET chip isn't done initializing the registers... I don't believe that's the problem, just trying something.
Here are the only changes I've made to the default sketch:
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    // no point in carrying on, so do nothing forevermore:
    for(;;)
to:
  IP Address xyz(192,168,1,122);
  Ethernet.begin(mac,xyz);
That is a free IP on my subnet and there is no conflicts. I can ping the the board once the sketch starts. This is with an official ethernet shield and mega 2560.
Any ideas?
I hope that was a typo. IPAddress is one word. This is what I use.
IPAddress ip(192,168,1,122);
   Ethernet.begin(mac,ip);
   // rest of setup code
Maybe your router ip (gateway for the Arduino) is not 192.168.1.1? Have you checked that on other localnet computers to see if there is a difference?
Yeah it was a typo in the post, sorry. I do have IPAddress.
The default gateway is 192.168.1.1 and the DNS server is the same, subnet mask is 255.255.255.0. I've even created 3 other objects to represent those (even though the (mac,ip) arguments are all that's needed in this case) and passed those into begin() to see if that changes it but I still get the same result - failure.
What brand and model of router are you using? Some are very particular about the ip range you assign for static ips. They will freak out if you assign a static ip that is within the range of the dhcp server ip pool, especially if they have already issued a dynamic ip for that mac address.
I trick my router by changing the mac address a little for each type of ip assignment.
It's not the network. It's definitely something with the Arduino. I can try it at another place to be 100% sure.
Let me note again that I CAN ping the board when I assign a static IP.
Does your router have an http login/setup page on 192.168.1.1?
http://192.168.1.1
If so, see if the Arduino will connect there.
edit: Have you checked what ip the ethernet shield gets when you use dhcp?
