WebClient Repeating - No Response After Displaying My IP ... [solved]
I'm not even getting the "connecting..." message in the Serial Monitor. I provide my arduino's IP proven successful in previous examples and a DNS IP by using "ipconfig /all" in the command prompt. What am I doing wrong? :.
Wireless LAN adapter Wireless Network Connection:
   Connection-specific DNS Suffix  . : stny.rr.com
   Description . . . . . . . . . . . : Atheros AR9285 802
   Physical Address. . . . . . . . . : C4-17-FE-9E-40-86
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   Link-local IPv6 Address . . . . . : fe80::dbb:d4cc:6ce
   IPv4 Address. . . . . . . . . . . : 192.168.1.121(Pref
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : Friday, November 3
   Lease Expires . . . . . . . . . . : Saturday, December
   Default Gateway . . . . . . . . . : 192.168.1.1
   DHCP Server . . . . . . . . . . . : 192.168.1.1
   DHCPv6 IAID . . . . . . . . . . . : 331618302
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-12-FA-
   DNS Servers . . . . . . . . . . . : 209.18.47.61
                                              209.18.47.62
  Repeating Web client
 This sketch connects to a a web server and makes a request
 using a Wiznet Ethernet shield. You can use the Arduino Ethernet shield, or
 the Adafruit Ethernet shield, either one will work, as long as it's got
 a Wiznet Ethernet module on board.
 This example uses DNS, by assigning the Ethernet client with a MAC address,
 IP address, and DNS address.
 Circuit:
 * Ethernet shield attached to pins 10, 11, 12, 13
 created 19 Apr 2012
 by Tom Igoe
 http://arduino.cc/en/Tutorial/WebClientRepeating
 This code is in the public domain.
#include <SPI.h>
#include <Ethernet.h>
// assign a MAC address for the ethernet controller.
// fill in your address here:
byte mac[] = {0x90, 0xA2, 0xDA, 0x0D, 0x97, 0x39};
// fill in an available IP address on your network here,
// for manual configuration:
IPAddress ip(192,168,1,118);
// fill in your Domain Name Server address here:
IPAddress myDns(209,18,47,61);
// initialize the library instance:
EthernetClient client;
char server[] = "www.arduino.cc";
unsigned long lastConnectionTime = 0;          // last time you connected to the server, in milliseconds
boolean lastConnected = false;                 // state of the connection last time through the main loop
const unsigned long postingInterval = 60*1000;  // delay between updates, in milliseconds
  // start serial port:
  // give the ethernet module time to boot up:
  // start the Ethernet connection using a fixed IP address and DNS server:
  Ethernet.begin(mac, ip, myDns);
  // print the Ethernet board/shield's IP address:
  Serial.print("My IP address: ");
  Serial.println(Ethernet.localIP());
  // if there's incoming data from the net connection.
  // send it out the serial port.  This is for debugging
  // purposes only:
  if (client.available()) {
    char c = client.read();
    Serial.print(c);
  // if there's no net connection, but there was one last time
  // through the loop, then stop the client:
  if (!client.connected() && lastConnected) {
    Serial.println("disconnecting.");
    client.stop();
  // if you're not connected, and ten seconds have passed since
  // your last connection, then connect again and send data:
  if(!client.connected() && (millis() - lastConnectionTime > postingInterval)) {
    httpRequest();
  // store the state of the connection for next time through
  // the loop:
  lastConnected = client.connected();
// this method makes a HTTP connection to the server:
void httpRequest() {
  // if there's a successful connection:
  if (client.connect(server, 80)) {
    Serial.println("connecting...");
    // send the HTTP PUT request:
    client.println("GET /latest.txt HTTP/1.1");
    client.println("Host: www.arduino.cc");
    client.println("User-Agent: arduino-ethernet");
    client.println("Connection: close");
    client.println();
    // note the time that the connection was made:
    lastConnectionTime = millis();
  else {
    // if you couldn't make a connection:
    Serial.println("connection failed");
    client.stop();
ah I get it now. It says use an available IP, such as, one that is not already in use. I used ping 192.168.1.115 this time and I see the HTTP request repeating. 8)
