Webduino authentication website from SD card
Hello Guys!
Authentication code: (http://ten-fingers-and-a-brain.com/tag/arduino/)
/* Web_Authentication.ino - Webduino Authentication example */
/* This example assumes that you're familiar with the basics
 * of the Ethernet library (particularly with setting MAC and
 * IP addresses) and with the basics of Webduino. If you
 * haven't had a look at the HelloWorld example you should
 * probably check it out first */
/* you can change the authentication realm by defining
 * WEBDUINO_AUTH_REALM before including WebServer.h */
#define WEBDUINO_AUTH_REALM "Weduino Authentication Example"
#include "SPI.h"
#include "Ethernet.h"
#include "WebServer.h"
/* CHANGE THIS TO YOUR OWN UNIQUE VALUE.  The MAC number should be
 * different from any other devices on your network or you'll have
 * problems receiving packets. */
static uint8_t mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
/* CHANGE THIS TO MATCH YOUR HOST NETWORK.  Most home networks are in
 * the 192.168.0.XXX or 192.168.1.XXX subrange.  Pick an address
 * that's not in use and isn't going to be automatically allocated by
 * DHCP from your router. */
static uint8_t ip[] = { 192, 168, 1, 210 };
/* This creates an instance of the webserver.  By specifying a prefix
 * of "", all pages will be at the root of the server. */
#define PREFIX ""
WebServer webserver(PREFIX, 80);
void defaultCmd(WebServer &server, WebServer::ConnectionType type, char *, bool)
  server.httpSuccess();
  if (type != WebServer::HEAD)
    P(helloMsg) = "<h1>Hello, World!</h1><a href=\"private.html\">Private page</a>";
    server.printP(helloMsg);
void privateCmd(WebServer &server, WebServer::ConnectionType type, char *, bool)
  /* if the user has requested this page using the following credentials
   * username = user
   * password = user
   * display a page saying "Hello User"
   * the credentials have to be concatenated with a colon like
   * username:password
   * and encoded using Base64 - this should be done outside of your Arduino
   * to be easy on your resources
   * in other words: "dXNlcjp1c2Vy" is the Base64 representation of "user:user"
   * if you need to change the username/password dynamically please search
   * the web for a Base64 library */
  if (server.checkCredentials("dXNlcjp1c2Vy"))
      P(helloMsg) = "<h1>Hello User</h1>";
   * username = admin
   * password = admin
   * display a page saying "Hello Admin"
   * in other words: "YWRtaW46YWRtaW4=" is the Base64 representation of "admin:admin" */
  else if (server.checkCredentials("YWRtaW46YWRtaW4="))
      P(helloMsg) = "<h1>Hello Admin</h1>";
    /* send a 401 error back causing the web browser to prompt the user for credentials */
    server.httpUnauthorized();
  Ethernet.begin(mac, ip);
  webserver.setDefaultCommand(&defaultCmd);
  webserver.addCommand("index.html", &defaultCmd);
  webserver.addCommand("private.html", &privateCmd);
  webserver.begin();
  char buff[64];
  int len = 64;
  /* process incoming connections one at a time forever */
  webserver.processConnection(buff, &len);
I have a index.htm and pic.jpg on the SD card.
index.htm:
<!DOCTYPE html>
<html>
<head>
<link rel="shortcut icon" href="/favicon.ico">
</head>
<body>
<BODY background="pic.jpg" style="background-position:top center; background-repeat:no-repeat; background-attachment:fixed">
</body>
</html>
How can I display a background image? How can I read the index.htm file on the SD card?
Somebody help me! =( Please :frowning:
