I can't figure out how to get this sketch working and I get a ton of errors. Any Help is much appreciated .
#ifndef WEBDUINO_H_
#define WEBDUINO_H_
#include <string.h>
#include <stdlib.h>
* CONFIGURATION
#define WEBDUINO_VERSION 1004
#define WEBDUINO_VERSION_STRING "1.4"
#if WEBDUINO_SUPRESS_SERVER_HEADER
#define WEBDUINO_SERVER_HEADER ""
#else
#define WEBDUINO_SERVER_HEADER "Server: Webduino/" WEBDUINO_VERSION_STRING CRLF
#endif
// standard END-OF-LINE marker in HTTP
#define CRLF "\r\n"
// If processConnection is called without a buffer, it allocates one
// of 32 bytes
#define WEBDUINO_DEFAULT_REQUEST_LENGTH 200
// How long to wait before considering a connection as dead when
// reading the HTTP request. Used to avoid DOS attacks.
#ifndef WEBDUINO_READ_TIMEOUT_IN_MS
#define WEBDUINO_READ_TIMEOUT_IN_MS 10000
#endif
#ifndef WEBDUINO_FAIL_MESSAGE
#define WEBDUINO_FAIL_MESSAGE "<h1>EPIC FAIL</h1>"
#endif
// add "#define WEBDUINO_SERIAL_DEBUGGING 1" to your application
// before including WebServer.h to have incoming requests logged to
// the serial port.
#ifndef WEBDUINO_SERIAL_DEBUGGING
#define WEBDUINO_SERIAL_DEBUGGING 0
#endif
#if WEBDUINO_SERIAL_DEBUGGING
#include <HardwareSerial.h>
#endif
// declared in wiring.h
extern "C" unsigned long millis(void);
// declare a static string
#define P(name) static const prog_uchar name[] PROGMEM
// returns the number of elements in the array
#define SIZE(array) (sizeof(array) / sizeof(*array))
* DECLARATIONS
/* Return codes from nextURLparam. NOTE: URLPARAM_EOS is returned
* when you call nextURLparam AFTER the last parameter is read. The
* last actual parameter gets an "OK" return code. */
typedef enum URLPARAM_RESULT { URLPARAM_OK,
URLPARAM_NAME_OFLO,
URLPARAM_VALUE_OFLO,
URLPARAM_BOTH_OFLO,
URLPARAM_EOS // No params left
class WebServer: public Print
public:
// passed to a command to indicate what kind of request was received
enum ConnectionType { INVALID, GET, HEAD, POST ,POSTMULTI};
// any commands registered with the web server have to follow
// this prototype.
// url_tail contains the part of the URL that wasn't matched against
// the registered command table.
// tail_complete is true if the complete URL fit in url_tail, false if
// part of it was lost because the buffer was too small.
typedef void Command(WebServer &server, ConnectionType type,
char *url_tail, bool tail_complete);
// constructor for webserver object
WebServer(const char *urlPrefix = "/", int port = 80);
// start listening for connections
void begin();
// check for an incoming connection, and if it exists, process it
// by reading its request and calling the appropriate command
// handler. This version is for compatibility with apps written for
// version 1.1, and allocates the URL "tail" buffer internally.
void processConnection();
// handler. This version saves the "tail" of the URL in buff.
void processConnection(char *buff, int *bufflen);
// set command that's run when you access the root of the server
void setDefaultCommand(Command *cmd);
// set command run for undefined pages
void setFailureCommand(Command *cmd);
// add a new command to be run at the URL specified by verb
void addCommand(const char *verb, Command *cmd);
// utility function to output CRLF pair
void printCRLF();
// output a string stored in program memory, usually one defined
// with the P macro
void printP(const prog_uchar, *str);
// output raw data stored in program memory
void writeP(const prog_uchar *data, size_t length);
// output HTML for a radio button
// returns next character or -1 if we're at end-of-stream
int read();
// put a character that's been read back into the input pool
void push(int ch);
// returns true if the string is next in the stream. Doesn't
// consume any character if false, so can be used to try out
// different expected values.
bool expect(const char *expectedStr);
// returns true if a number, with possible whitespace in front, was
// read from the server stream. number will be set with the new
// value or 0 if nothing was read.
bool readInt(long &number);
// Read the next keyword parameter from the socket. Assumes that other
// code has already skipped over the headers, and the next thing to
// be read will be the start of a keyword.
// returns true if we're not at end-of-stream
bool readPOSTparam(char *name, int nameLen, char *value, int valueLen);
int readNextFormPart(int action);
// Read the next keyword parameter from the buffer filled by getRequest.
// returns 0 if everything weent okay, non-zero if not
// (see the typedef for codes)
URLPARAM_RESULT nextURLparam(char **tail, char *name, int nameLen,
// output headers and a message indicating a server error
void httpFail();
// output standard headers indicating "200 Success". You can change the
// type of the data you're outputting or also add extra headers like
// "Refresh: 1". Extra headers should each be terminated with CRLF.
void httpSuccess(const char *contentType = "text/html; charset=utf-8",
const char *extraHeaders = NULL);
// used with POST to output a redirect to another URL. This is
// preferable to outputting HTML from a post because you can then
// refresh the page without getting a "resubmit form" dialog.
void httpSeeOther(const char *otherURL);
void httpContinue();
// implementation of write used to implement Print interface
virtual void write(uint8_t);
virtual void write(const char *str);
virtual void write(const uint8_t *buffer, size_t size);
void write(const char *data, size_t length);
char m_filename[20];
int bounlength;
//private:
protected:
Server m_server;
Client m_client;
const char *m_urlPrefix;
int m_pushback[100];
int m_pushbackDepth;
long m_contentLength;
bool m_readingContent;
int conttype;
char m_boundary[90];
Command *m_failureCmd;
Command *m_defaultCmd;
struct CommandMap
const char *verb;
Command *cmd;
} m_commands[8];
char m_cmdCount;
void reset();
void getRequest(WebServer::ConnectionType &type, char *request, int *length);
bool dispatchCommand(ConnectionType requestType, char *verb,
void processHeaders();
static void defaultFailCmd(WebServer &server, ConnectionType type,
void noRobots(ConnectionType type);
* IMPLEMENTATION
WebServer::WebServer(const char *urlPrefix, int port) :
m_server(port),
m_client(255),
m_urlPrefix(urlPrefix),
m_pushbackDepth(0),
m_cmdCount(0),
m_contentLength(0),
m_failureCmd(&defaultFailCmd),
m_defaultCmd(&defaultFailCmd)
void WebServer::begin()
m_server.begin();
void WebServer::setDefaultCommand(Command *cmd)
m_defaultCmd = cmd;
void WebServer::setFailureCommand(Command *cmd)
m_failureCmd = cmd;
void WebServer::addCommand(const char *verb, Command *cmd)
if (m_cmdCount < SIZE(m_commands))
m_commands[m_cmdCount].verb = verb;
m_commands[m_cmdCount++].cmd = cmd;
void WebServer::write(uint8_t ch)
m_client.write(ch);
void WebServer::write(const char *str)
m_client.write(str);
void WebServer::write(const uint8_t *buffer, size_t size)
m_client.write(buffer, size);
void WebServer::write(const char *buffer, size_t length)
m_client.write((const uint8_t *)buffer, length);
void WebServer::writeP(const prog_uchar *data, size_t length)
// copy data out of program memory into local storage, write out in
// chunks of 32 bytes to avoid extra short TCP/IP packets
uint8_t buffer[32];
size_t bufferEnd = 0;
while (length--)
if (bufferEnd == 32)
m_client.write(buffer, 32);
bufferEnd = 0;
buffer[bufferEnd++] = pgm_read_byte(data++);
if (bufferEnd > 0)
m_client.write(buffer, bufferEnd);
void WebServer::printP(const prog_uchar *str)
uint8_t buffer[32];
while (buffer[bufferEnd++] = pgm_read_byte(str++))
bufferEnd = 0;
// write out everything left but trailing NUL
if (bufferEnd > 1)
m_client.write(buffer, bufferEnd - 1);
void WebServer::printCRLF()
m_client.write((const uint8_t *)"\r\n", 2);
bool WebServer::dispatchCommand(ConnectionType requestType, char *verb,
bool tail_complete)
if ((verb[0] == 0) || ((verb[0
