Hi guys!!
I’m stuck on a really simple webserver using the Webduino library.
Just a few words about it: This server turns ON and OFF a relay, with url commands like “192.168.x.x/R1=ON” or “192.168.x.x/R1=OFF”. and everything works fine. Then i tried to get some variables in the same way,setting up their name and their values in the URL and parsing it to store these variables . For example, i tried to store a variable with the value of a temperature setpoint, with the command “SETCOLD12” ( complete url : 192.168.x.x/SETCOLD12)
To do that, i used strings.By default, the sketch saves a string with the url parameter after the numeric address ( in the first examples url_param is “R1=ON”) , then i tried to ‘split’ this string to get a code (SETCOLD) and a value (12) using string.substring() method to split them, and string.toInt() to save the setpoint value in a variable.
Compilation is OK, but when i upload my sketch to arduino UNO + Ethernet , the servers drops down. 192.168.x.x is no more reachable ( everything was ok before implementing this strings) , and RX pin on ETH shield is continuosly lighted up.
When it works, user and pass to authenticate are : user=ciccio password=pino
Here’s my code:
#include <Ethernet.h>
#include <SPI.h>
#include <WebServer.h> //libreria webduino
//Mac address and IP address
static byte mac_Add[] = {0x05, 0xA3, 0xBB, 0xCC, 0xDE, 0x02 };
//my IP
static byte ip_Add[] = {192, 168, 1, 36 };
//creazione oggetto Webduino
WebServer webserver("", 80);
//relay status
boolean Rele1 = false;
boolean Rele2 = false;
boolean Rele3 = false;
int c1=10; // just for trying a server.print
int c2=3;
int c3=340;
int coldpoint,hotpoint,lightpoint;
void privateCmd(WebServer &server, WebServer::ConnectionType type, char *url_param, bool param_complete)
{ //da web_Authentication
if (server.checkCredentials("Y2ljY2lvOnBpbm8=")) //da web_Authentication su base64 scrivere admin:admin
// e la traduzione sarà YWRtaW46YWRtaW4= http://www.motobit.com/util/base64-decoder-encoder.asp
server.httpSuccess(); //da web_Authentication
if (type != WebServer::HEAD) //da web_Authentication
String s="";
String code="";
String setpoint="";
if (param_complete == true)
s = url_param;
code=s.substring(0,7);
setpoint=s.substring(7,9);
if ( s == "R1=ON")
Rele1 = true;
digitalWrite(2, HIGH);
else if ( s == "R1=OFF")
Rele1 = false;
digitalWrite(2, LOW);
else if (code != "");
if(code=="SETCOLD"){
int coldpoint=setpoint.toInt();
else if(code=="SETHOTT"){
int hotpoint=setpoint.toInt();
else if(code=="SETLITE"){
int lightpoint=setpoint.toInt();
//gestisco la pagina html in base allo stato delle uscite di Arduino
P(htmlHead) =
"<html>"
"<head>"
"<title> DomotiControl </title>"
"</head>"
"<body>";
server.printP(htmlHead);
server.print("<div style='width: 360px; height: 640px;'>");
server.print("<big style='color: rgb(0, 0, 102);'><big><big><span style='font-family: Segoe UI;'>Casa Domotica Arduino.</span></big></big></big>
server.print("<table border=\"1\">");
server.print("<tr><td>Sensore</td><td>Valore</td><td>SetPoint attuale</td><td>Stato Relè</td><td>Comandi</td></tr>
server.print("<tr><td>Luminosita</td><td>");
server.print(c1);
server.print("</td><td>");
server.print(lightpoint);
server.print("</td>");
if(Rele1 == true)
server.print("<td style=\"color: red;\">RELE 1 ON</td><td>");
server.print("<td style=\"color: black;\">RELE 1 OFF</td><td>");
if(Rele1 == false)
server.print("<input type=\"button\" value=\"clicca qui\"onclick=\"location.href='index.htm?R1=ON'\">");
server.print("<input type=\"button\" value=\"clicca qui\"onclick=\"location.href='index.htm?R1=OFF'\">");
server.print("</td></tr>");
server.print("<tr><td>Freddo</td><td>");
server.print(c2);
server.print(coldpoint);
if(Rele2 == true)
server.print("<td style=\"color: red;\">RELE 2 ON</td><td>");
server.print("<td style=\"color: black;\">RELE 2 OFF</td><td>");
if(Rele2 == false)
server.print("<input type=\"button\" value=\"clicca qui\"onclick=\"location.href='index.htm?R2=ON'\">");
server.print("<input type=\"button\" value=\"clicca qui\"onclick=\"location.href='index.htm?R2=OFF'\">");
server.print("<tr><td>Caldo</td><td>");
server.print(c3);
server.print(hotpoint);
if(Rele3 == true)
server.print("<td style=\"color: red;\">RELE 3 ON</td><td>");
server.print("<td style=\"color: black;\">RELE 3 OFF</td><td>");
if(Rele3 == false)
server.print("<input type=\"button\" value=\"clicca qui\" onclick=\"location.href='index.htm?R3=ON'\">");
server.print("<input type=\"button\" value=\"clicca qui\"onclick=\"location.href='index.htm?R3=OFF'\">");
server.print("</table></body></html>");
/* send a 401 error back causing the web browser to prompt the user for credentials */
server.httpUnauthorized();
//inizializzo l'ethernet shield con il mac e il address
Ethernet.begin(mac_Add, ip_Add);
//definisci l'azione di default che verrà eseguita quando l'utente
//naviga nella root del sito
webserver.setDefaultCommand(&privateCmd);
webserver.addCommand("index.htm", &privateCmd);
//avvia il web server
webserver.begin();
delay(100);
//definisci i pin 2 3 4 in uscita
pinMode(2, OUTPUT);
//inizializza i le uscite
//elabora costantemente tutte le richieste provenienti dal browser
webserver.processConnection();
Can someone help me getting reed of this problem?
