webpage to lcd without using sd card
i want show some text on lcd which i typed on webpage(i.e what ever i typed on webpage it has to display on lcd).
this code is working fine but here i stored index.htm in sd card . but i want to modify this code without using sd card.
can anyone help me.
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
#include "rgb_lcd.h"
#include <Wire.h>
rgb_lcd lcd;
#define REQ_BUF_SZ   90
#define LCD_BUF_SZ   17
byte mac[] = {
  0x98, 0x4F, 0xEE,0x01, 0x65, 0x4E };
IPAddress ip(192,168,19,170);
String readString;
EthernetServer server(80);      // create a server at port 80
File webFile;                    // the web page file on the SD card
char HTTP_req[REQ_BUF_SZ] = {0}; // buffered HTTP request stored as null terminated string
char req_index = 0;              // index into HTTP_req buffer
char lcd_buf_1[LCD_BUF_SZ] = {0};// buffer to save LCD line 1 text to
char lcd_buf_2[LCD_BUF_SZ] = {0};// buffer to save LCD line 2 text to
//LiquidCrystal lcd(3, 2, 8, 7, 6, 5);
    // disable Ethernet chip
    pinMode(10, OUTPUT);
    digitalWrite(10, HIGH);
    Serial.begin(115200);       // for debugging
    lcd.begin(16, 2);
    // Message on LCD
    lcd.print(F("Initializing"));
    // initialize SD card
    Serial.println("Initializing SD card...");
    if (!SD.begin(4)) {
        Serial.println("ERROR - SD card initialization failed!");
        lcd.print(F("SD init failed"));
        return;    // init failed
    Serial.println("SUCCESS - SD card initialized.");
    // check for index.htm file
    if (!SD.exists("index.htm")) {
        Serial.println("ERROR - Can't find index.htm file!");
        return;  // can't find index file
    Serial.println("SUCCESS - Found index.htm file.");
    Ethernet.begin(mac, ip);  // initialize Ethernet device
    server.begin();           // start to listen for clients
    // End of initialization message on LCD + print IP address
    lcd.clear();
    lcd.setCursor(0, 0);
    lcd.print(F("Done."));
    lcd.setCursor(0, 1);
    lcd.print(ip);
    EthernetClient client = server.available();  // try to get client
    if (client) {  // got client?
        boolean currentLineIsBlank = true;
        while (client.connected()) {
            if (client.available()) {   // client data available to read
                char c = client.read(); // read 1 byte (character) from client
                // limit the size of the stored received HTTP request
                // buffer first part of HTTP request in HTTP_req array (string)
                // leave last element in array as 0 to null terminate string (REQ_BUF_SZ - 1)
                if (req_index < (REQ_BUF_SZ - 1)) {
                    HTTP_req[req_index] = c;          // save HTTP request character
                    req_index++;
                // last line of client request is blank and ends with \n
                // respond to client only after last line received
                if (c == '\n' && currentLineIsBlank) {
                    // send a standard http response header
                    // remainder of header follows below, depending on if
                    // web page or XML page is requested
                    // Ajax request - send XML file
                    if (StrContains(HTTP_req, "ajax_inputs")) {
                        // send rest of HTTP header
                        client.println("Content-Type: text/xml");
                        client.println("Connection: keep-alive");
                        client.println();
                        // print the received text to the LCD if found
                        if (GetLcdText(lcd_buf_1, lcd_buf_2, LCD_BUF_SZ)) {
                          // lcd_buf_1 and lcd_buf_2 now contain the text from
                          // the web page
                          // write the received text to the LCD
                          lcd.clear();
                          lcd.print(lcd_buf_1);
                          lcd.print(lcd_buf_2);
                    else {  // web page request
                        client.println("Content-Type: text/html");
                        client.println();
                        // send web page
                        webFile = SD.open("index.htm");        // open web page file
                        if (webFile) {
                            while(webFile.available()) {
                                client.write(webFile.read()); // send web page to client
                            webFile.close();
                    // reset buffer index and all buffer elements to 0
                    req_index = 0;
                    StrClear(HTTP_req, REQ_BUF_SZ);
                // every line of text received from the client ends with \r\n
                if (c == '\n') {
                    // last character on line of received text
                    // starting new line with next character read
                else if (c != '\r') {
                    // a text character was received from client
                    currentLineIsBlank = false;
            } // end if (client.available())
        } // end while (client.connected())
        delay(1);      // give the web browser time to receive the data
        client.stop(); // close the connection
    } // end if (client)
// get the two strings for the LCD from the incoming HTTP GET request
boolean GetLcdText(char *line1, char *line2, int len)
  boolean got_text = false;    // text received flag
  char *str_begin;             // pointer to start of text
  char *str_end;               // pointer to end of text
  int str_len = 0;
  int txt_index = 0;
  char *current_line;
  current_line = line1;
  // get pointer to the beginning of the text
  str_begin = strstr(HTTP_req, "&L1=");
  for (int j = 0; j < 2; j++) { // do for 2 lines of text
    if (str_begin != NULL) {
      str_begin = strstr(str_begin, "=");  // skip to the =
      str_begin += 1;                      // skip over the =
      str_end = strstr(str_begin, "&");
      if (str_end != NULL) {
        str_end[0] = 0;  // terminate the string
        str_len = strlen(str_begin);
        // copy the string to the buffer and replace %20 with space ' '
        for (int i = 0; i < str_len; i++) {
          if (str_begin[i] != '%') {
            if (str_begin[i] == 0) {
              // end of string
            else {
              current_line[txt_index++] = str_begin[i];
              if (txt_index >= (len - 1)) {
                // keep the output string within bounds
          else {
            // replace %20 with a space
            if ((str_begin[i + 1] == '2') && (str_begin[i + 2] == '0')) {
              current_line[txt_index++] = ' ';
              i += 2;
        } // end for i loop
        current_line[txt_index] = 0;
        if (j == 0) {
          // got first line of text, now get second line
          str_begin = strstr(&str_end[1], "L2=");
          current_line = line2;
          txt_index = 0;
        got_text = true;
  } // end for j loop
  return got_text;
// sets every element of str to 0 (clears array)
void StrClear(char *str, char length)
    for (int i = 0; i < length; i++) {
        str[i] = 0;
// searches for the string sfind in the string str
// returns 1 if string found
// returns 0 if string not found
char StrContains(char *str, char *sfind)
    char found = 0;
    char index = 0;
    char len;
    len = strlen(str);
    if (strlen(sfind) > len) {
        return 0;
    while (index < len) {
        if (str[index] == sfind[found]) {
            found++;
            if (strlen(sfind) == found) {
                return 1;
        else {
            found = 0;
        index++;
    return 0;
The code in this example for the ESP8266 displays on the GLCD attached to the webserver whatever is typed on the PC webpage.
Ray
