Webpanel log in error!
Every thing has been fine I turned off the Yun and came back later, plugged the Yun in and I go to http://192.168.1.103/ type my password then I get this error
Bad Gateway
The process did not produce any response
I can run my sketch and it does run http://192.168.1.103/sd/TemperatureWebPanel/
But I can not log in to the webpanel!
I did do a WiFi reset and then log in to 192.168.240.1 and set my settings up again but when I saved and reboot and tried to go to http://192.168.1.103 same error! What should I do?
/etc/init.d/uhttpd restart
use browser directly access, ( change ip to yours)
http://192.168.0.101/cgi-bin/luci/webpanel/homepage
http://forum.arduino.cc/index.php?topic=221261.msg1608848#msg1608848
Did you change anything at "/etc/config/uhttpd"
backup plan: backup the the code you wrote, then re-flash the firmware.
I can see the login homepage but but when I type password in and click log in then I get the error!
I can log in by putty just fine!
I have not changed "/etc/config/uhttpd"
I guess I will re-flash the firmware!
