WebServer Ethernet with Arduino PLC
Hello there,
I'm trying to get some variables value visible on a web page, using the OPTA like a WebServer.
First of all, i've tried with the Example tab using Arduino IDE, the " Ethernet WebServer" Example work very well...
But when I try to do the same with Arduino PLC the scketch compile, but seems that the WebServer never go up.
I cand get a ping response from the OPTA, but no web page are shown...
Does someaone be able to do that with Arduino PLC?
Does someone could post an example sketch?
After many thentative, still not able to get the WebServer wornking on OPTA device.
I've also update the mbed core to 4.2.0, but still not working.
// shared variables can be accessed with PLCIn.varname and PLCOut.varname
// Enable usage of EtherClass, to set static IP address and other
#include <PortentaEthernet.h>
arduino::EthernetClass eth(&m_netInterface);
EthernetServer server(80);                             //server port
String readString;
	// Configure static IP address
	IPAddress ip(192, 168, 188, 253);
	IPAddress dns(8, 8, 8, 8);
	IPAddress gateway(192, 168, 188, 1);
	IPAddress subnet(255, 255, 255, 0);
	// If cable is not connected this will block the start of PLC with about 60s of timeout!
	eth.begin(ip, dns, gateway, subnet);
	server.begin();
      if (client) {
        Serial.println("client");
        while (client.connected()) {
          Serial.println("connected");
          if (client.available()) {
            Serial.println("available");
            char c = client.read();
            //read char by char HTTP request
            if (readString.length() < 100) {
              //store characters to string
              readString += c;
              //Serial.print(c);
             //if HTTP request has ended
             if (c == '\n') {
               client.println("HTTP/1.1 200 OK"); //send new page
               client.println("Content-Type: text/html");
               client.println();
               client.println("<HTML>");
               client.println("<BODY>");
               client.println("<H1>Test</H1>");
               client.println("</BODY>");
               client.println("</HTML>");
               delay(1);
               //stopping client
               client.stop();
               //controls the Arduino if you press the buttons
               //clearing string for next read
               readString="";
On the serial console, i get some "connected" and then...nothing. It stuck.
Has anyone got this to work?
I think it has to do with PortentaEthernet.h
other Arduino examples use the Ethernet.h include, which doesn't exist in the PLC sketch.
I was trying to follow the finder example: Web Server on the Finder Opta (findernet.com)
but they don't have the includes and the zip download of the example goes to a page not found
It would be appreciated if someone could share a working example of hosting a webpage on the OPTA device.
Thanks
I have found the zip file for the demo, have not yet opened it to confirm it works but I am having the same problem as you so hopefully this will help. The zip file is in the assets folder
https://github.com/dndg/FinderOptaWebServerTutorial
Just uploaded to my Opta and it seems to work ok. Note that I had to change the static IP address at three different locations in the sketch for it to work properly. (Line 21, 248, and 264)
