WebServer Issue loading pages and commands not working
Hi to everyone,
I've got a problem with my actual project (I'm new about programming and arduino),
my hardware setup is : Arduino Nano, ethernet shield ENC28J60 (for Nano).
The problem is that i'm new about this programming world and i don't have enough knowledge about TCP and HTTP comunication. However in my actual project i've to create a webserver with two pages that controls a network configuration and the other page have to control 6 relays. The two programs works when are separated, but i've got a lot of bugs and loading problems when I combine them together.
I think that the problem is correlated with the TCP connection or HTTP requests.
Here is the code, i hope someone can help me:
#include <UIPEthernet.h>
#include <TextFinder.h>
#include <SPI.h>
#include <EEPROM.h>
#include <avr/pgmspace.h>
//PIN definition
#define RESET 9 //pin per reset manuale
const byte INDEX = 4;  //Array dimension (ip, mask, gw, dns)
const byte RELE_NUM = 6;
const PROGMEM byte rele_pin[RELE_NUM] = {2, 3, 8, 5, 6, 7};
//Reset states
int lastState = LOW;  // the previous state from the input pin
int currentState = digitalRead(RESET);
//Default Network Settings
const PROGMEM byte default_mac[RELE_NUM] = { 0x00,0x01,0x02,0x03,0x04,0x05 };
const PROGMEM byte default_ip[INDEX] = { 192,168,65,250 };
const PROGMEM byte default_subnet[INDEX] = { 255,255,255,0 };
const PROGMEM byte default_gateway[INDEX] = { 192,168,65,254 };
//Start Network Settings
byte mac[RELE_NUM] = { 0x00,0x01,0x02,0x03,0x04,0x05 };
byte ip[INDEX] = {192,168,65,250};
byte subnet[INDEX] = {255,255,255,0};
byte gateway[INDEX] = {192,168,65,254};
byte dnsserver[INDEX] = {192,168,65,2};
EthernetServer server(80);
EthernetClient client;
//Buffers
char buffer[100]; //buffer string_tables (it has to be as big as the longest character chain +1 including the " )
String Read;
const char htmla0[] PROGMEM = "<script>function hex2num (s_hex) {eval(\"var n_num=0X\" + s_hex);return n_num;}";
const char htmla1[] PROGMEM = "</script><table><form><input type=\"hidden\" name=\"SBM\" value=\"1\"><tr><td>";
const char htmla2[] PROGMEM = "<font color= #FFFFFF>MAC:<input id=\"T1\" type=\"text\" size=\"3\" maxlength=\"";
const char htmla3[] PROGMEM = "2\" name=\"DT1\" value=\"";
const char htmla4[] PROGMEM = "\">.<input id=\"T3\" type=\"text\" size=\"3\" maxlength=\"2\" name=\"DT2\" value=\"";
const char htmla5[] PROGMEM = "\">.<input id=\"T5\" type=\"text\" size=\"3\" maxlength=\"2\" name=\"DT3\" value=\"";
const char htmla6[] PROGMEM = "\">.<input id=\"T7\" type=\"text\" size=\"3\" maxlength=\"2\" name=\"DT4\" value=\"";
const char htmla7[] PROGMEM = "\">.<input id=\"T9\" type=\"text\" size=\"3\" maxlength=\"2\"name=\"DT5\" value=\"";
const char htmla8[] PROGMEM = "\">.<input id=\"T11\" type=\"text\" size=\"3\" maxlength=\"2\"name=\"DT6\" value=\"";
PGM_P const string_table1[] PROGMEM = { htmla0, htmla1, htmla2, htmla3, htmla4, htmla5, htmla6, htmla7, htmla8 };
const char htmlb0[] PROGMEM = "\"><input id=\"T2\" type=\"hidden\" name=\"DT1\"><input id=\"T4\" type=\"hidden\" name=\"DT2";
const char htmlb1[] PROGMEM = "\"><input id=\"T6\" type=\"hidden\" name=\"DT3\"><input id=\"T8\" type=\"hidden\" name=\"DT4";
const char htmlb2[] PROGMEM = "\"><input id=\"T10\" type=\"hidden\" name=\"DT5\"><input id=\"T12\" type=\"hidden\" name=\"D";
const char htmlb3[] PROGMEM = "T6\"></td></tr></font><tr><td><font color= #FFFFFF>";
const char htmlb4[] PROGMEM = "IP: <input type=\"text\" size=\"3\"maxlength=\"3\" name=\"DT7\"value=\"";
const char htmlb5[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\"name=\"DT8\" value=\"";
const char htmlb6[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT9\" value=\"";
const char htmlb7[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT10\" value=\"";
PGM_P const string_table2[] PROGMEM = { htmlb0, htmlb1, htmlb2, htmlb3, htmlb4, htmlb5, htmlb6, htmlb7 };
const char htmlc0[] PROGMEM = "\"></td></tr></font><tr><td><font color= #FFFFFF>MASK: <input type=\"text\"";
const char htmlc1[] PROGMEM = "size=\"3\" maxlength=\"3\" name=\"DT11\" value=\"";
const char htmlc2[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT12\" value=\"";
const char htmlc3[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT13\" value=\"";
const char htmlc4[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT14\" value=\"";
PGM_P const string_table3[]  PROGMEM = { htmlc0, htmlc1, htmlc2, htmlc3, htmlc4 };
const char htmld0[] PROGMEM = "\"></td></tr></font><tr><td><font color= #FFFFFF>GW: <input type=\"text\"";
const char htmld1[] PROGMEM = "size=\"3\" maxlength=\"3\" name=\"DT15\" value=\"";
const char htmld2[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT16\" value=\"";
const char htmld3[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT17\" value=\"";
const char htmld4[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT18\" value=\"";
const char htmld5[] PROGMEM = "\"></td></tr></font><tr><td><br></td></tr><tr><td><input class=\"button\"";
const char htmld6[] PROGMEM = "id=\"submit\" type=\"submit\"value=\"SUBMIT\"><input class=\"button\" id=\"";
const char htmld7[] PROGMEM = "reset\" type=\"reset\" value=\"RESET\"></td></tr></form></table></body></html>";
PGM_P const string_table4[] PROGMEM = { htmld0, htmld1, htmld2, htmld3, htmld4, htmld5, htmld6, htmld7 };
const char htmle0[] PROGMEM = "Onclick=\"document.getElementById('T2').value ";
const char htmle1[] PROGMEM = "= hex2num(document.getElementById('T1').value);";
const char htmle2[] PROGMEM = "document.getElementById('T4').value = hex2num(document.getElementById('T3').value);";
const char htmle3[] PROGMEM = "document.getElementById('T6').value = hex2num(document.getElementById('T5').value);";
const char htmle4[] PROGMEM = "document.getElementById('T8').value = hex2num(document.getElementById('T7').value);";
const char htmle5[] PROGMEM = "document.getElementById('T10').value = hex2num(document.getElementById('T9').value);";
const char htmle6[] PROGMEM = "document.getElementById('T12').value = hex2num(document.getElementById('T11').value);\"";
PGM_P const string_table5[] PROGMEM = { htmle0, htmle1, htmle2, htmle3, htmle4, htmle5, htmle6 };
const char buttons0[] PROGMEM = "<!DOCTYPE html><html><body><head><meta name=\"viewport\" content=\"width=device-width,";
const char buttons1[] PROGMEM = "initial-scale=1.0\"><!-- Icon library --><link rel=\"stylesheet\" href=\"https://cdnjs.";
const char buttons2[] PROGMEM = "cloudflare.com/ajax/libs/font-awesome/4.7.0/css/font-awesome.min.css\"><style> * ";
const char buttons3[] PROGMEM = "{ box-sizing: border-box;}body{ margin: 0; background-color: #000000; background-image:";
const char buttons4[] PROGMEM = "url('wallpaper.jpg'); background-size: cover;}"; // Style the header
const char buttons5[] PROGMEM = ".header{ background-image: url('logo.png'); background-repeat: no-repeat; background-size:";
const char buttons6[] PROGMEM = "contain; background-color: #000000; color: #f2f2f2; padding: 20px; text-align: center;}"; // Style the top navigation bar
const char buttons7[] PROGMEM = ".topnav { overflow: hidden; background-color: #000000;}"; // Style the topnav links
const char buttons8[] PROGMEM = ".topnav a{ float: left; display: block; color: #f2f2f2; text-align: center; padding:";
const char buttons9[] PROGMEM = "14px 16px; text-decoration: none;}"; // Change color on hover
const char buttons10[] PROGMEM = ".topnav a:hover{ background-color: #ddd; color: black;}"; // Buttons Style
const char buttons11[] PROGMEM = ".button{ display: inline-block; padding: 15px 25px; font-size: 24px; cursor: pointer;";
const char buttons12[] PROGMEM = "text-align: center; text-decoration: none; outline: none; color: black; background-color:";
const char buttons13[] PROGMEM = "white; border: 2px solid #555555; border-radius: 15px; box-shadow: 0 9px #999;}";
const char buttons14[] PROGMEM = ".button:hover { background-color: #555555; color: white;}.button:active{ background-color:";
const char buttons15[] PROGMEM = "#3e8e41; box-shadow: 0 5px #666; transform: translateY(4px);}"; // Center the Buttons
const char buttons16[] PROGMEM = ".center{ margin: 0; position: absolute; top: 35%; left: 50%; -ms-transform: translate(-50%,";
const char buttons17[] PROGMEM = "-50%); transform: translate(-50%, -50%);}</style></head><body marginwidth= 0 marginheight=0";
const char buttons18[] PROGMEM = "leftmargin=0 style= margin: 0; padding: 0;><div class=\"header\"><h1></h1></div><div class=";
const char buttons19[] PROGMEM = "\"topnav\"><a href=\"settings\">Settings</a><a href=\"commands\">Commands</a></div><body><tr>";
const char buttons20[] PROGMEM = "<div class=\"center\">";
const char buttons21[] PROGMEM = "<button class=\"button\"Onclick=location.href=\"/play\"><i class=\"fa fa-play\"></i> PLAY</button>";
const char buttons22[] PROGMEM = "<button class=\"button\"Onclick=location.href=\"/pause\"><i class=\"fa fa-pause\"></i> PAUSE</button>";
const char buttons23[] PROGMEM = "<button class=\"button\" Onclick=location.href=\"/stop\"><i class=\"fa fa-stop\"></i> STOP</button>";
const char buttons24[] PROGMEM = "<tr><br /><br />";
const char buttons25[] PROGMEM = "<button class=\"button\"Onclick=location.href=\"/ffd\"><i class=\"fa fa-fast-forward\">";
const char buttons26[] PROGMEM = "</i> FFD</button><button class=\"button\" Onclick=location.href=\"/reverse\">";
const char buttons27[] PROGMEM = "<i class=\"fa fa-fast-backward\"></i> REVERSE</button><button class=\"button\"";
const char buttons28[] PROGMEM = " Onclick=location.href=\"/record\"><i class=\"fa fa-circle\"></i> REC</button></body></html>";
PGM_P const string_buttons[] PROGMEM = { buttons0, buttons1, buttons2, buttons3, buttons4, buttons5, buttons6, buttons7, buttons8, buttons9, buttons10,
                                         buttons11, buttons12, buttons13, buttons14, buttons15, buttons16, buttons17, buttons18, buttons19, buttons20,
                                         buttons21, buttons22, buttons23, buttons24, buttons25, buttons26, buttons27, buttons28 };
const byte ID = 0x92; //used to identify if valid data in EEPROM the "know" bit,
// if this is written in EEPROM the sketch has ran before
// We use this, so that the very first time you'll run this sketch it will use
// the values written above.
// defining which EEPROM address we are using for what data
  //Reset button
  pinMode(RESET, INPUT);
  //Relays
  for (size_t j= 0; j < RELE_NUM; j++)
    pinMode(rele_pin[j], OUTPUT);  //setto i rele come OUTPUT
    digitalWrite((j+2), LOW);  //setto i rele LOW
  ShieldSetup (); //Setup the Ethernet shield
  server.begin(); //starting the server
  Serial.print(F("Server start at: "));
  Serial.println(Ethernet.localIP());
void ShieldSetup()
  Serial.println(F("Ethernet Shield setup..."));
  int idcheck = EEPROM.read(0);
  if (idcheck != ID)
    //ifcheck id is not the value as const byte ID,
    //it means this sketch has NOT been used to setup the shield before
    //just use the values written in the beginning of the sketch
  if (idcheck == ID)
    //if id is the same value as const byte ID,
    //it means this sketch has been used to setup the shield.
    //So we will read the values out of EERPOM and use them
    //to setup the shield.
    for (size_t i = 0; i < 6; i++){
      mac[i] = EEPROM.read(i+1);
    for (size_t i = 0; i < 4; i++){
      ip[i] = EEPROM.read(i+7);
      subnet[i] = EEPROM.read(i+11);
      gateway[i] = EEPROM.read(i+15);
  Ethernet.begin(mac, ip);
void web_page()
  if (client) //Indicates if the specified Ethernet client is ready.
    Serial.println(F("Settings Client"));
    TextFinder finder(client);
    while (client.connected()) //Whether or not the client is connected
      if (client.available()) //Is the amount of data that has been written to the client by the server it is connected to
        if( finder.find("GET /") ) //This part does all the text searching
         if (finder.findUntil("settings", "\n\r"))
            Serial.println(F("* Settings *"));
            // if you find the word "SBM" continue looking for more
            // if you don't find that word, stop looking and go further
            // it means the SUBMIT button hasn't been pressed an nothing has
            // been submitted. Just go to the place where the setup page is
            // been build and show it in the client's browser.
          if (finder.findUntil("SBM", "\n\r"))
            byte SET = finder.getValue();
            // Now while you are looking for the letters "DT", you'll have to remember
            // every number behind "DT" and put them in "val" and while doing so, check
            // for the according values and put those in mac, ip, subnet and gateway.
              while(finder.findUntil("DT", "\n\r"))
                int val = finder.getValue();
                // if val from "DT" is between 1 and 6 the according value must be a MAC value.
                if(val >= 1 && val <= 6)
                  mac[val - 1] = finder.getValue();
                // if val from "DT" is between 7 and 10 the according value must be a IP value.
                if(val >= 7 && val <= 10)
                  ip[val - 7] = finder.getValue();
                // if val from "DT" is between 11 and 14 the according value must be a MASK value.
                if(val >= 11 && val <= 14)
                  subnet[val - 11] = finder.getValue();
                // if val from "DT" is between 15 and 18 the according value must be a GW value.
                if(val >= 15 && val <= 18)
                  gateway[val - 15] = finder.getValue();
            // Now that we got all the data, we can save it to EEPROM
            for (size_t i = 0 ; i < 6; i++)
              EEPROM.write(i + 1,mac[i]);
            for (size_t i = 0 ; i < 4; i++)
              EEPROM.write(i + 7, ip[i]);
              EEPROM.write(i + 11, subnet[i]);
              EEPROM.write(i + 15, gateway[i]);
            // set ID to the known bit, so when you reset the Arduino is will use the EEPROM values
            EEPROM.write(0, 0x92);
            Serial.println(F("Reboot with new Network settings"));
            delay(330);
            asm volatile("jmp 0");
          // and from this point on, we can start building our setup page
          // and show it in the client's browser.
          client.println(F("HTTP/1.1 200 OK"));
          client.println(F("Content-Type: text/html"));
          client.println(F("Connection: close"));
          client.println();
          client.println(F("<html><div id=\"settings\">"));
          client.println(F("<head>"));
          client.println(F("<title>Settings</title>"));
          client.println(F("<meta charset=\"utf-8\">"));
          client.println(F("<meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0\">"));
          client.println(F("<style>"));
          client.println(F("* { box-sizing: border-box;}"));
          client.println(F("body{ margin: 0; background-color: #000000; background-image: url('wallpaper.jpg'); background-size: cover;}"));
          client.println(F(".header{ background-image: url('logo.png'); background-repeat: no-repeat; background-size: contain; background-color: #000000; color: #f2f2f2; padding: 20px; text-align: center}")); // Style the header
          client.println(F(".topnav { overflow: hidden; background-color: #000000;}")); // Style the top navigation bar
          client.println(F(".topnav a{ float: left; display: block; color: #f2f2f2; text-align: center; padding: 14px 16px; text-decoration: none;}")); // Style the topnav links
          client.println(F(".topnav a:hover { background-color: #ddd; color: black;}"));// Change color on hover
          client.println(F(".center{ margin: 0; position: absolute; top: 35%; left: 50%; -ms-transform: translate(-50%, -50%); transform: translate(-50%, -50%);}"));// Center the table
          client.println(F(".button{ display: inline-block; padding: 3px 15px; font-size: 12px; cursor: pointer; text-align: center; text-decoration: none; outline: none; color: black; background-color: white; border: 2px solid #555555; border-radius: 15px; box-shadow: 0 9px #999;}"));// Buttons Style
          client.println(F(".button:hover{ background-color: #555555; color: white;}"));
          client.println(F(".button:active{ background-color: #3e8e41; box-shadow: 0 5px #666; transform: translateY(4px);}"));
          client.println(F("</style>"));
          client.println(F("</head>"));
          client.println(F("<body marginwidth= 0 marginheight=0 leftmargin=0 style= margin: 0; padding: 0;>"));
          client.println(F("<div class=\"header\">"));
          client.println(F("<h1></h1>"));
          client.println(F("</div>"));
          client.println(F("<div class=\"topnav\">"));
          client.println(F("<a href=\"settings\">Settings</a>"));
          client.println(F("<a href=\"commands\">Commands</a>"));
          client.println(F("<div class=\"center\">"));
          client.println(F("<table bgcolor= #999999 border= 0 width= 100% cellpadding= 1 style= font-family:Verdana;color:#fff; fff;font-size:12px;>"));
          client.println(F("<tr></tr>"));
          client.println(F("</table>"));
          client.println(F("<br>"));
            strcpy_P(buffer, (char*)pgm_read_word(&(string_table1[i])));
            client.print( buffer );
          client.print(mac[0],HEX);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table1[4])));
          client.print(mac[1],HEX);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table1[5])));
          client.print(mac[2],HEX);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table1[6])));
          client.print(mac[3],HEX);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table1[7])));
          client.print(mac[4],HEX);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table1[8])));
          client.print(mac[5],HEX);
          for (size_t i = 0; i < 5; i++)
            strcpy_P(buffer, (char*)pgm_read_word(&(string_table2[i])));
          client.print(ip[0],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table2[5])));
          client.print(ip[1],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table2[6])));
          client.print(ip[2],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table2[7])));
          client.print(ip[3],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table3[0])));
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table3[1])));
          client.print(subnet[0],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table3[2])));
          client.print(subnet[1],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table3[3])));
          client.print(subnet[2],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table3[4])));
          client.print(subnet[3],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[0])));
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[1])));
          client.print(gateway[0],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[2])));
          client.print(gateway[1],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[3])));
          client.print(gateway[2],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[4])));
          client.print(gateway[3],DEC);
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[5])));
          for (size_t i = 0; i < 7; i++)
            strcpy_P(buffer, (char*)pgm_read_word(&(string_table5[i])));
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[6])));
          strcpy_P(buffer, (char*)pgm_read_word(&(string_table4[7])));
       if (finder.findUntil("commands", "\n\r"))
            Serial.println(F("* Commands *"));
            char c = client.read();
            if (Read.length() < 100) //read char by char HTTP request
              Read += c; //store characters to string
              //Serial.print(c);
            if (c == "\n")
            //client.println(F("Connection: close"));
            client.println();
            for (size_t i = 0; i < 29; i++)
                 strcpy_P(buffer, (char*)pgm_read_word(&(string_buttons[i])));
            //delay(1);
            //client.flush();
            //client.stop();
           Serial.println(F(">>>Commands"));
           //Controlli su Arduino: Se è stato premuto il pulsante sul webserver
           if (Read.indexOf("play") >0)
              digitalWrite(rele_pin[0], HIGH);
              Serial.println(F(" R1_PLAY"));
              digitalWrite(rele_pin[0], LOW);
           if (Read.indexOf("pause") >0)
              digitalWrite(rele_pin[1], HIGH);
              Serial.println(F(" R2_PAUSE"));
              digitalWrite(rele_pin[1], LOW);
           if (Read.indexOf("reverse") >0)
              digitalWrite(rele_pin[2], HIGH);
              Serial.println(F(" R3_REVERSE"));
              digitalWrite(rele_pin[2], LOW);
           if (Read.indexOf("ffd") >0)
              digitalWrite(rele_pin[3], HIGH);
              Serial.println(F(" R4_FAST_FORWARD"));
              digitalWrite(rele_pin[3], LOW);
           if (Read.indexOf("stop") >0)
              digitalWrite(rele_pin[4], HIGH);
              Serial.println(F(" R5_STOP"));
              digitalWrite(rele_pin[4], LOW);
           if (Read.indexOf("record") >0)
              digitalWrite(rele_pin[5], HIGH);
              Serial.println(F(" R6_REC"));
              digitalWrite(rele_pin[5], LOW);
           Read="";
      delay(1);
      client.flush(); //Ensure that all data has been sent
      client.stop();
void reset()
  //Time definition
  const int PRESS_RESET = 3000;
  unsigned long pressedTime  = 0;
  unsigned long releasedTime = 0;
  //RESET button to default values
  if(lastState == LOW && currentState == HIGH)        // button is pressed
    //Serial.println(F("pressed"));
    pressedTime = millis();
  else if(lastState == HIGH && currentState == LOW)   // button is released
      //Serial.println(F("released"));
      releasedTime = millis();
      long pressDuration = releasedTime - pressedTime;
      if( pressDuration >= PRESS_RESET )
           Serial.println(F("Resetting..."));
           for (size_t i = 0 ; i < RELE_NUM; i++)
              EEPROM.write(i + 1, default_mac[i]);
           for (size_t i = 0 ; i < INDEX; i++)
              EEPROM.write(i + 7, default_ip[i]);
              EEPROM.write(i + 11, default_subnet[i]);
              EEPROM.write(i + 15, default_gateway[i]);
             lastState = currentState;          // save the the last state
             delay(330); //3.3 ms
  web_page();
  reset();
  //return 0;
You need to describe those bugs and problems in detail in order for us to help you. For each bug/problem, describe what actually happens and what you wanted or expected to happen.
I see a lot of code duplicates where only minor things are changed line by line. That makes reading your code very ....
I propose you get rid of it and use more functions where you hand over the changing parts with parameters.
Furthermore, your http request doesn't contain a content length, so it is only 1.0.
Don't use the F-Makro with client.print, it will have negative effect on the performance of your webserver (and a very long communication time to your webbrowser).
I can recommend the streamlib from Juraj or - as you are already using a temporary buffer - use the buffer more consequently.
You can get more information on that topic on my page:
[url]https://werner.rothschopf.net/microcontroller/202011_arduino_webserver_optimize_en.htm[/url]
Ok, so when the program is running i search in the browser my ip adress: 192.168.65.250/settings (to reach the setting page) and the page loads two or three times (i'll show you the serial monitor), then the page works fine it seems, but when i click to the topnav link to switch page, i've to click it a few times to reach the "commands page" and the page loading never ends, however in the serial monitor i see that the "settings page" is reloaded. I would to keep a stable connection and I'd like to make commands work, because when i click to one button nothing happends.
P.S. sorry for my bad english.
settings_page_Serial_Monitor
this is what the Serial monitor tells me when i reach the first page (* Settings *), it should be load only once.
commands_page_S_M
this is what's happen when i click to switch to the other page ((* Commands *), it reload the client and it tells me (settings) but when i click on it a few times finally i can reach the commands page. When i'm inside the other page the loading never stop, and if i try to click on one button (>>>Commands) nothing actually happens. It should tell me something like ( R1_PLAY ) when i cick to "play button".
@noiasca UIPEthernet doesn't send single bytes over network as Ethernet. (but does sent them as single bytes over SPI)
maybe try the EthernetWebServer library.
and EthernetENC library is usually better then UIPEthernet
Thanks for the advices but i only want to know how can i how can I make the two web pages coexist in the same function "web_page(void)".
For many reasons i can't change my libraries, one of those is that i've to send the project in a few days and i'm so scared, i hope someone can help
