Why can't my web server run?
// Import required libraries
#include <Arduino.h>
#ifdef ESP32
#include <WiFi.h>
#include <AsyncTCP.h>
#elif defined(ESP8266)
#include <ESP8266WiFi.h>
#include <ESPAsyncTCP.h>
#endif
#include <ESPAsyncWebServer.h>
#include <FS.h>
#include <ArduinoJson.h>
//Timer to run Arduino code every 5 seconds
unsigned long previousMillis = 0;
unsigned long interval = 500;
int temp, pressure, range;
float lux;
String temp1 = "";
String pressure1 = "";
String range1 = "";
String lux1 = "";
// Timer variables
unsigned long lastTime = 0;
unsigned long timerDelay = 500;
/* Put your SSID & Password */
const char* ssid = "Weather Station"; // Enter SSID here
const char* password = "12345678"; //Enter Password here
/* Put IP Address details */
IPAddress local_ip(192,168,1,1);
IPAddress gateway(192,168,1,1);
IPAddress subnet(255,255,255,0);
// Create AsyncWebServer object on port 80
AsyncWebServer server(80);
// Initialize Serial port
while (!Serial) continue;
if(SPIFFS.begin()==true) {
Serial.println("SPIFFS initialised OK");
WiFi.softAP(ssid, password);
WiFi.softAPConfig(local_ip, gateway, subnet);
delay(100);
if(millis() - previousMillis >= interval) {
previousMillis = millis();
const size_t capacity = JSON_OBJECT_SIZE(128);
DynamicJsonDocument doc(capacity);
DeserializationError error = deserializeJson(doc, Serial);
if (error) {
Serial.print(F("deserializeJson() failed: "));
Serial.println(error.c_str());
return;
//serializeJson(doc, Serial);
temp1 = doc["temperature"].as<String>();
pressure1 = doc["pressure"].as<String>();
range1 = doc["range"].as<String>();
lux1 = doc["lux"].as<String>();
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
request->send(SPIFFS, "/index.html", "text/html");
server.on("/assets/css/foundation.css", HTTP_GET, [](AsyncWebServerRequest *request){
request->send(SPIFFS, "/assets/css/foundation.css", "text/css");
server.on("/assets/js/vendor.js", HTTP_GET, [](AsyncWebServerRequest *request){
request->send(SPIFFS, "/assets/js/vendor.js", "text/js");
server.on("/assets/js/foundation.js", HTTP_GET, [](AsyncWebServerRequest *request){
request->send(SPIFFS, "/assets/js/foundation.js", "text/js");
server.on("/temp", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/plain", temp1.c_str());
server.on("/pressure", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/plain", pressure1.c_str());
server.on("/lux", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/plain", lux1.c_str());
Serial.print("Recieved Temperature: ");
temp = doc["temperature"];
Serial.println(temp);
Serial.print("Recieved Pressure: ");
pressure = doc["pressure"];
Serial.println(pressure);
Serial.print("Recieved Range: ");
range = doc["range"];
Serial.println(range);
Serial.print("Recieved Lux: ");
lux = doc["lux"];
Serial.println(lux);
Serial.println("-----------------------------------------");
server.begin();
//end
<!doctype html>
<html class="no-js" lang="en">
<head>
<meta charset="utf-8" />
<meta http-equiv="x-ua-compatible" content="ie=edge">
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<title>Welcome to ESP Server</title>
<link rel="stylesheet" href="assets/css/foundation.css">
</head>
<body>
<div class="grid-container text-center">
<div class="grid-x grid-padding-x">
<div class="large-12 cell">
<h1>Welcome to ESP Server</h1>
</div>
</div>
<div class="large-12 medium-12 small-12 cell">
<div class="callout">
<h3>TEMPERATURE</h3>
<p>SUHU UDARA<br />
<span id="temp">
%TEMP%
</span>
°C
</p>
</div>
<p>TEKANAN UDARA<br />
<span id="pressure">
%PRESSURE%
</span>
hPa
</p>
</div>
<p>KECERAHAN<br />
<span id="lux">
%LUX%
</span>
</p>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
</div>
<script>
setInterval(function () {
var xhttp = new XMLHttpRequest();
xhttp.onreadystatechange = function() {
if (this.readyState == 4 && this.status == 200) {
document.getElementById("temp").innerHTML = this.responseText;
xhttp.open("GET", "/temp", true);
xhttp.send();
}, 500) ;
document.getElementById("pressure").innerHTML = this.responseText;
xhttp.open("GET", "/pressure", true);
xhttp.send();
}, 500) ;
document.getElementById("lux").innerHTML = this.responseText;
xhttp.open("GET", "/lux", true);
xhttp.send();
}, 500) ;
</script>
<script src="assets/js/vendor.js"></script>
<script src="assets/js/foundation.js"></script>
</body>
</html>
