Webserver (Mega, W5100, include html/css)
GOAL: use a webpage to control and monitor an animatronic device. (about 60 I/O for project)
reference: ESP32 Web page creating and updating - YouTube
I want to use a Mega/w5100 shield and LAN to host a web page that can monitor numerous elements and controls that Mega will be working with. I would like to use the methods described in the "reference" youtube. Where they have the HTML in a cleaner format .h file that can be sent and XML to update the needed component statuses.
I'm not sure if this Is the best method for what I'm trying to do and I'm open for guidance. I'm not that great of a coder but I can hack things together enough to get things working.
I do not want to use wireless as I need this connection to be as stable and reliable as possible.
Even with the Mega, I will be using Shift registers to extend I/O as this is a complicated system.
Thank you for any advice and direction you can provide.
Words, words and words and no engineering information.
You can preferably use graphics, logical diagrams, to show the system.
Here's a commonly referenced link: How to get the best out of this forum - Using Arduino / Installation & Troubleshooting - Arduino Forum
Sorry, let me clarify my question.
I like the way this person uses an additional .h file with all their HTML/css in it instead of having a ton of lines in the main code body.
Is there a library for this or will the SPI/ethernet library handle the server send calls?
instead they use this
void ProcessButton_1() {
  // just a simple way to toggle a LED on/off. Much better ways to do this
  Serial.println("Button 1 press");
  SomeOutput = !SomeOutput;
  digitalWrite(PIN_OUTPUT, SomeOutput);
Serial.print("Button 1 "); Serial.println(LED0);
  // regardless if you want to send stuff back to client or not
  // you must have the send line--as it keeps the page running
  // if you don't want feedback from the MCU--or send all data via XML use this method
  // sending feeback
  server.send(200, "text/plain", ""); //Send web page
  // if you want to send feed back immediataly
  // note you must have proper code in the java script to read this data stream
    if (some_process) {
    server.send(200, "text/plain", "SUCCESS"); //Send web page
    else {
    server.send(200, "text/plain", "FAIL"); //Send web page
// code to send the main web page
// PAGE_MAIN is a large char defined in SuperMon.h
void SendWebsite() {
  Serial.println("sending web page");
  // you may have to play with this value, big pages need more porcessing time, and hence
  // a longer timeout that 200 ms
  server.send(200, "text/html", PAGE_MAIN);
// I avoid string data types at all cost hence all the char mainipulation code
void SendXML() {
  // Serial.println("sending xml");
  strcpy(XML, "<?xml version = '1.0'?>\n<Data>\n");
  // send bitsA0
  sprintf(buf, "<B0>%d</B0>\n", BitsA0);
  strcat(XML, buf);
  // send Volts0
  sprintf(buf, "<V0>%d.%d</V0>\n", (int) (VoltsA0), abs((int) (VoltsA0 * 10)  - ((int) (VoltsA0) * 10)));
  strcat(XML, buf);
  // send bits1
  sprintf(buf, "<B1>%d</B1>\n", BitsA1);
  strcat(XML, buf);
  // send Volts1
  sprintf(buf, "<V1>%d.%d</V1>\n", (int) (VoltsA1), abs((int) (VoltsA1 * 10)  - ((int) (VoltsA1) * 10)));
  strcat(XML, buf);
  // show led0 status
  if (LED0) {
    strcat(XML, "<LED>1</LED>\n");
  else {
    strcat(XML, "<LED>0</LED>\n");
  if (SomeOutput) {
    strcat(XML, "<SWITCH>1</SWITCH>\n");
  else {
    strcat(XML, "<SWITCH>0</SWITCH>\n");
  strcat(XML, "</Data>\n");
  // wanna see what the XML code looks like?
  // actually print it to the serial monitor and use some text editor to get the size
  // then pad and adjust char XML[2048]; above
  Serial.println(XML);
  server.send(200, "text/xml", XML);
Where the included.h file is this.
const char PAGE_MAIN[] PROGMEM = R"=====(
<!DOCTYPE html>
<html lang="en" class="js-focus-visible">
<title>Web Page Update Demo</title>
  <style>
    table {
      position: relative;
      width:100%;
      border-spacing: 0px;
    tr {
      border: 1px solid white;
      font-family: "Verdana", "Arial", sans-serif;
      font-size: 20px;
    th {
      height: 20px;
      padding: 3px 15px;
      background-color: #343a40;
      color: #FFFFFF !important;
    td {
      height: 20px;
       padding: 3px 15px;
    .tabledata {
      font-size: 24px;
      position: relative;
      padding-left: 5px;
      padding-top: 5px;
      height:   25px;
      border-radius: 5px;
      color: #FFFFFF;
      line-height: 20px;
      transition: all 200ms ease-in-out;
      background-color: #00AA00;
    .fanrpmslider {
      width: 30%;
      height: 55px;
      outline: none;
      height: 25px;
    .bodytext {
      font-size: 24px;
      text-align: left;
      font-weight: light;
      border-radius: 5px;
      display:inline;
    .navbar {
      width: 100%;
      height: 50px;
      margin: 0;
      padding: 10px 0px;
      background-color: #FFF;
      color: #000000;
      border-bottom: 5px solid #293578;
    .fixed-top {
      position: fixed;
      top: 0;
      right: 0;
      left: 0;
      z-index: 1030;
    .navtitle {
      float: left;
      height: 50px;
      font-size: 50px;
      font-weight: bold;
      line-height: 50px;
      padding-left: 20px;
   .navheading {
     position: fixed;
     left: 60%;
     height: 50px;
     font-size: 20px;
     font-weight: bold;
     line-height: 20px;
     padding-right: 20px;
   .navdata {
      justify-content: flex-end;
      position: fixed;
      left: 70%;
      height: 50px;
      font-size: 20px;
      font-weight: bold;
      line-height: 20px;
    .category {
      font-weight: bold;
      font-size: 32px;
      line-height: 50px;
      padding: 20px 10px 0px 10px;
      color: #000000;
    .heading {
      font-weight: normal;
      font-size: 28px;
      text-align: left;
    .btn {
      background-color: #444444;
      border: none;
      color: white;
      padding: 10px 20px;
      text-align: center;
      text-decoration: none;
      display: inline-block;
      font-size: 16px;
      margin: 4px 2px;
      cursor: pointer;
    .foot {
      font-size: 20px;
      position: relative;
      height:   30px;
      text-align: center;
      color: #AAAAAA;
      line-height: 20px;
    .container {
      max-width: 1800px;
      margin: 0 auto;
    table tr:first-child th:first-child {
      border-top-left-radius: 5px;
    table tr:first-child th:last-child {
      border-top-right-radius: 5px;
    table tr:last-child td:first-child {
      border-bottom-left-radius: 5px;
    table tr:last-child td:last-child {
      border-bottom-right-radius: 5px;
  </style>
  <body style="background-color: #efefef" onload="process()">
    <header>
      <div class="navbar fixed-top">
          <div class="container">
            <div class="navtitle">Sensor Monitor</div>
            <div class="navdata" id = "date">mm/dd/yyyy</div>
            <div class="navheading">DATE</div><br>
            <div class="navdata" id = "time">00:00:00</div>
            <div class="navheading">TIME</div>
          </div>
      </div>
    </header>
    <main class="container" style="margin-top:70px">
      <div class="category">Sensor Readings</div>
      <div style="border-radius: 10px !important;">
      <table style="width:50%">
      <colgroup>
        <col span="1" style="background-color:rgb(230,230,230); width: 20%; color:#000000 ;">
        <col span="1" style="background-color:rgb(200,200,200); width: 15%; color:#000000 ;">
        <col span="1" style="background-color:rgb(180,180,180); width: 15%; color:#000000 ;">
      </colgroup>
      <col span="2"style="background-color:rgb(0,0,0); color:#FFFFFF">
      <tr>
        <th colspan="1"><div class="heading">Pin</div></th>
        <th colspan="1"><div class="heading">Bits</div></th>
        <th colspan="1"><div class="heading">Volts</div></th>
      </tr>
      <tr>
        <td><div class="bodytext">Analog pin 34</div></td>
        <td><div class="tabledata" id = "b0"></div></td>
        <td><div class="tabledata" id = "v0"></div></td>
      </tr>
      <tr>
        <td><div class="bodytext">Analog pin 35</div></td>
        <td><div class="tabledata" id = "b1"></div></td>
        <td><div class="tabledata" id = "v1"></div></td>
      </tr>
        <tr>
        <td><div class="bodytext">Digital switch</div></td>
        <td><div class="tabledata" id = "switch"></div></td>
      </tr>
      </table>
    </div>
    <br>
    <div class="category">Sensor Controls</div>
    <br>
    <div class="bodytext">LED </div>
    <button type="button" class = "btn" id = "btn0" onclick="ButtonPress0()">Toggle</button>
    </div>
    <br>
    <div class="bodytext">Switch</div>
    <button type="button" class = "btn" id = "btn1" onclick="ButtonPress1()">Toggle</button>
    </div>
    <br>
    <br>
    <div class="bodytext">Fan Speed Control (RPM: <span id="fanrpm"></span>)</div>
    <br>
    <input type="range" class="fanrpmslider" min="0" max="255" value = "0" width = "0%" oninput="UpdateSlider(this.value)"/>
    <br>
    <br>
  </main>
  <footer div class="foot" id = "temp" >ESP32 Web Page Creation and Data Update Demo</div></footer>
  </body>
  <script type = "text/javascript">
    // global variable visible to all java functions
    var xmlHttp=createXmlHttpObject();
    // function to create XML object
    function createXmlHttpObject(){
      if(window.XMLHttpRequest){
        xmlHttp=new XMLHttpRequest();
      else{
        xmlHttp=new ActiveXObject("Microsoft.XMLHTTP");
      return xmlHttp;
    // function to handle button press from HTML code above
    // and send a processing string back to server
    // this processing string is use in the .on method
    function ButtonPress0() {
      var xhttp = new XMLHttpRequest();
      var message;
      // if you want to handle an immediate reply (like status from the ESP
      // handling of the button press use this code
      // since this button status from the ESP is in the main XML code
      // we don't need this
      // remember that if you want immediate processing feedbac you must send it
      // in the ESP handling function and here
      xhttp.onreadystatechange = function() {
        if (this.readyState == 4 && this.status == 200) {
          message = this.responseText;
          // update some HTML data
      xhttp.open("PUT", "BUTTON_0", false);
      xhttp.send();
    function ButtonPress1() {
          document.getElementById("button1").innerHTML = this.responseText;
      xhttp.open("PUT", "BUTTON_1", false);
      xhttp.send();
    function UpdateSlider(value) {
      // this time i want immediate feedback to the fan speed
      // yea yea yea i realize i'm computing fan speed but the point
      // is how to give immediate feedback
          // update the web based on reply from  ESP
          document.getElementById("fanrpm").innerHTML=this.responseText;
      // this syntax is really weird the ? is a delimiter
      // first arg UPDATE_SLIDER is use in the .on method
      // server.on("/UPDATE_SLIDER", UpdateSlider);
      // then the second arg VALUE is use in the processing function
      // String t_state = server.arg("VALUE");
      // then + the controls value property
      xhttp.open("PUT", "UPDATE_SLIDER?VALUE="+value, true);
      xhttp.send();
    // function to handle the response from the ESP
    function response(){
      var message;
      var barwidth;
      var currentsensor;
      var xmlResponse;
      var xmldoc;
      var dt = new Date();
      var color = "#e8e8e8";
      // get the xml stream
      xmlResponse=xmlHttp.responseXML;
      // get host date and time
      document.getElementById("time").innerHTML = dt.toLocaleTimeString();
      document.getElementById("date").innerHTML = dt.toLocaleDateString();
      // A0
      xmldoc = xmlResponse.getElementsByTagName("B0"); //bits for A0
      message = xmldoc[0].firstChild.nodeValue;
      if (message > 2048){
      color = "#aa0000";
      else {
        color = "#0000aa";
      barwidth = message / 40.95;
      document.getElementById("b0").innerHTML=message;
      document.getElementById("b0").style.width=(barwidth+"%");
      // if you want to use global color set above in <style> section
      // other wise uncomment and let the value dictate the color
      //document.getElementById("b0").style.backgroundColor=color;
      //document.getElementById("b0").style.borderRadius="5px";
      xmldoc = xmlResponse.getElementsByTagName("V0"); //volts for A0
      document.getElementById("v0").innerHTML=message;
      document.getElementById("v0").style.width=(barwidth+"%");
      // you can set color dynamically, maybe blue below a value, red above
      document.getElementById("v0").style.backgroundColor=color;
      //document.getElementById("v0").style.borderRadius="5px";
      // A1
      xmldoc = xmlResponse.getElementsByTagName("B1");
      color = "#aa0000";
      else {
        color = "#0000aa";
      document.getElementById("b1").innerHTML=message;
      document.getElementById("b1").style.width=(width+"%");
      document.getElementById("b1").style.backgroundColor=color;
      //document.getElementById("b1").style.borderRadius="5px";
      xmldoc = xmlResponse.getElementsByTagName("V1");
      document.getElementById("v1").innerHTML=message;
      document.getElementById("v1").style.width=(width+"%");
      document.getElementById("v1").style.backgroundColor=color;
      //document.getElementById("v1").style.borderRadius="5px";
      xmldoc = xmlResponse.getElementsByTagName("LED");
      if (message == 0){
        document.getElementById("btn0").innerHTML="Turn ON";
      else{
        document.getElementById("btn0").innerHTML="Turn OFF";
      xmldoc = xmlResponse.getElementsByTagName("SWITCH");
      document.getElementById("switch").style.backgroundColor="rgb(200,200,200)";
      // update the text in the table
      if (message == 0){
        document.getElementById("switch").innerHTML="Switch is OFF";
        document.getElementById("btn1").innerHTML="Turn ON";
        document.getElementById("switch").style.color="#0000AA";
      else {
        document.getElementById("switch").innerHTML="Switch is ON";
        document.getElementById("btn1").innerHTML="Turn OFF";
        document.getElementById("switch").style.color="#00AA00";
    // general processing code for the web page to ask for an XML steam
    // this is actually why you need to keep sending data to the page to
    // force this call with stuff like this
    // server.on("/xml", SendXML);
    // otherwise the page will not request XML from the ESP, and updates will not happen
    function process(){
     if(xmlHttp.readyState==0 || xmlHttp.readyState==4) {
        xmlHttp.open("PUT","xml",true);
        xmlHttp.onreadystatechange=response;
        xmlHttp.send(null);
        // a longer timeout
        setTimeout("process()",100);
  </script>
</html>
type or paste code here
