Webserver on mega - problem with slider position
good afternoon
Dear, I am writing to you because I can not solve the problem with my webserver on mega.
problem is linked with the slider: when I open 192.168.1.80 on two different browsers or sheets in the same browser I can not update position of the slider after changing slider value - when I am changing value by changing slider position value from arduino is changing in all browsers like should but the position of slider is not changing in another browser, please support me because I tried milion things and without results. below you can find arduino code and page code.
thank you very much in advance for help
<!DOCTYPE html>
<html>
<head>
	<title>Arduino Ajax I/O</title>
	<script>
		cdn = "";
		var LED3_state = 0;
		var LED4_state = 0;
		function GetArduinoIO() {
			nocache = "&nocache=" + Math.random() * 1000000;
			var request = new XMLHttpRequest();
			request.onreadystatechange = function () {
				if (this.readyState == 4) {
					if (this.status == 200) {
						if (this.responseXML != null) {
							// XML file received - contains analog values, switch values and LED states
							var count;
							// get analog inputs
							var num_an = this.responseXML.getElementsByTagName('analog').length;
							for (count = 0; count < num_an; count++) {
								document.getElementsByClassName("analog")[count].innerHTML =
									this.responseXML.getElementsByTagName('analog')[count].childNodes[0].nodeValue;
							// get switch inputs
							var num_an = this.responseXML.getElementsByTagName('switch').length;
								document.getElementsByClassName("switches")[count].innerHTML =
									this.responseXML.getElementsByTagName('switch')[count].childNodes[0].nodeValue;
							// LED 1
							if (this.responseXML.getElementsByTagName('status1')[0].childNodes[0].nodeValue === "on") {
								document.LED_form.LED1.checked = true;
							else {
								document.LED_form.LED1.checked = false;
							// LED 2
							if (this.responseXML.getElementsByTagName('status2')[0].childNodes[0].nodeValue === "on") {
								document.LED_form.LED2.checked = true;
							else {
								document.LED_form.LED2.checked = false;
							// LED 3
							if (this.responseXML.getElementsByTagName('status3')[0].childNodes[0].nodeValue === "on") {
								document.getElementById("LED3").innerHTML = "MC65 is ON";
								LED3_state = 1;
							else {
								document.getElementById("LED3").innerHTML = "MC65 is OFF";
								LED3_state = 0;
							// LED 4
							if (this.responseXML.getElementsByTagName('status4')[0].childNodes[0].nodeValue === "on") {
								document.getElementById("LED4").innerHTML = "MC66 is ON";
								LED4_state = 1;
							else {
								document.getElementById("LED4").innerHTML = "MC66 is OFF";
								LED4_state = 0;
							// 63 slider
							document.getElementById("r63slider").defaultValue =
								this.responseXML.getElementsByTagName('slider')[0].childNodes[0].nodeValue;
							document.getElementById("w63sliderin").innerHTML =
								this.responseXML.getElementsByTagName('slider')[0].childNodes[0].nodeValue + " s.";
			// send HTTP GET request with LEDs to switch on/off if any
			request.open("GET", "x" + cdn + nocache, true);
			request.send(null);
			setTimeout('GetArduinoIO()', 1500);
			cdn = "";
		// service LEDs when checkbox checked/unchecked
		function GetCheck1() {
			if (LED_form.LED1.checked) {
				cdn = "&mc63s=01";
			else {
				cdn = "&mc63s=00";
		function GetCheck2() {
			if (LED_form.LED2.checked) {
				cdn = "&mc64s=01";
			else {
				cdn = "&mc64s=00";
		function GetButton1() {
			if (LED3_state === 1) {
				LED3_state = 0;
				cdn = "&mc65s=00";
			else {
				LED3_state = 1;
				cdn = "&mc65s=01";
		function GetButton2() {
			if (LED4_state === 1) {
				LED4_state = 0;
				cdn = "&mc66s=00";
			else {
				LED4_state = 1;
				cdn = "&mc66s=01";
		function f63time() {
			if (document.getElementById("r63slider").value < 10) {
				cdn = "&mc63t=0" + document.getElementById("r63slider").value;
			else if (document.getElementById("r63slider").value < 100) {
				cdn = "&mc63t=" + document.getElementById("r63slider").value;
	</script>
	<style>
		.IO_box {
			float: left;
			margin: 0 20px 20px 0;
			border: 1px solid blue;
			padding: 0 5px 0 5px;
			width: 210px;
		h1 {
			font-size: 120%;
			color: blue;
			margin: 0 0 10px 0;
		h2 {
			font-size: 85%;
			color: #5734E6;
			margin: 5px 0 5px 0;
		p,
		form,
		button {
			font-size: 80%;
			color: #252525;
			width: 200px;
		.small_text {
			font-size: 70%;
			color: #737373;
	</style>
</head>
<body onload="GetArduinoIO()">
	<h1>Arduino Ajax I/O</h1>
	<div class="IO_box">
		<h2>Analog Inputs</h2>
		<p class="small_text">A0 used by Ethernet shield</p>
		<p class="small_text">A1 used by Ethernet shield</p>
		<p>A2: <span class="analog">...</span></p>
		<p>A3: <span class="analog">...</span></p>
		<p>A4: <span class="analog">...</span></p>
		<p>A5: <span class="analog">...</span></p>
	</div>
		<h2>Switch Inputs</h2>
		<p class="small_text">D0: used by serial RX</p>
		<p class="small_text">D1: used by serial TX</p>
		<p>Switch 1 (D2): <span class="switches">...</span></p>
		<p>Switch 2 (D3): <span class="switches">...</span></p>
		<p class="small_text">D4: used by Ethernet shield</p>
		<p>Switch 3 (D5): <span class="switches">...</span></p>
	</div>
		<h2>LEDs Using Checkboxes</h2>
		<form id="check_LEDs" name="LED_form">
			<input type="checkbox" name="LED1" value="0" onclick="GetCheck1()" />MC63 ON/OFF<br /><br />
			<input type="checkbox" name="LED2" value="0" onclick="GetCheck2()" />MC64 ON/OFF<br /><br />
		</form>
	</div>
		<h2>LEDs Using Buttons</h2>
		<button type="button" id="LED3" onclick="GetButton1()">MC65 ON/OFF</button><br /><br />
		<button type="button" id="LED4" onclick="GetButton2()">MC66 ON/OFF</button><br /><br />
		<p class="small_text">D10 to D13 used by Ethernet shield</p>
	</div>
		<h2>Set feeding time</h2>
		<label id="w63sliderout"></label>
		<input type="range" id="r63slider" min="1" max="99" oninput="f63time()">
		<label id="w63sliderin"></label>
	</div>
</body>
</html>
arduino code:
#include <SPI.h>
#include <Ethernet.h>
#include <SD.h>
// size of buffer used to capture HTTP requests
#define REQ_BUF_SZ   60
// MAC address from Ethernet shield sticker under board
byte mac[] = {0x90, 0xA2, 0xDA, 0x10, 0xB3, 0x4A};
IPAddress ip(192, 168, 1, 80);
EthernetServer server(80);  // create a server at port 80
File webFile;               // the web page file on the SD card
char HTTP_req[REQ_BUF_SZ] = {0}; // buffered HTTP request stored as null terminated string
char req_index = 0;              // index into HTTP_req buffer
boolean LED_state[4] = {0}; // stores the states of the LEDs
char *maszyny[] =  {"mc63", "mc64", "mc65", "mc66", "mc67", "mc68", "mc69", "mc70", "su01", "su02", "su03"};
int m_status[] =   {1,      1,      0,      0,      0,      1,      0,      0,      0,      0,      0     };
int m_czas[] =     {15,     16,     17,     18,     19,     20,     21,     22,     23,     24,     25    };
char m_extract[5] = {""};
char i_extract = {""};
char v_extract[3] = {""};
String sv_extract = "";
  // disable Ethernet chip
  pinMode(10, OUTPUT);
  digitalWrite(10, HIGH);
  Serial.begin(9600);       // for debugging
  // initialize SD card
  Serial.println("Initializing SD card...");
  if (!SD.begin(4)) {
    Serial.println("ERROR - SD card initialization failed!");
    return;    // init failed
  Serial.println("SUCCESS - SD card initialized.");
  // check for index.htm file
  if (!SD.exists("index.htm")) {
    Serial.println("ERROR - Can't find index.htm file!");
    return;  // can't find index file
  Serial.println("SUCCESS - Found index.htm file.");
  // switches on pins 2, 3 and 5
  pinMode(2, INPUT_PULLUP);
  pinMode(3, INPUT_PULLUP);
  pinMode(5, INPUT_PULLUP);
  // LEDs
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
  pinMode(8, OUTPUT);
  pinMode(9, OUTPUT);
  Ethernet.begin(mac, ip);  // initialize Ethernet device
  server.begin();           // start to listen for clients
  digitalWrite(6, m_status[0]);
  digitalWrite(7, m_status[1]);
  digitalWrite(8, m_status[2]);
  digitalWrite(9, m_status[3]);
  EthernetClient client = server.available();  // try to get client
  if (client) {  // got client?
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {   // client data available to read
        char c = client.read(); // read 1 byte (character) from client
        // limit the size of the stored received HTTP request
        // buffer first part of HTTP request in HTTP_req array (string)
        // leave last element in array as 0 to null terminate string (REQ_BUF_SZ - 1)
        if (req_index < (REQ_BUF_SZ - 1)) {
          HTTP_req[req_index] = c;          // save HTTP request character
          req_index++;
        // last line of client request is blank and ends with \n
        // respond to client only after last line received
        if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          // remainder of header follows below, depending on if
          // web page or XML page is requested
          // Ajax request - send XML file
          if (StrContains(HTTP_req, "x")) {
            // send rest of HTTP header
            client.println("Content-Type: text/xml");
            client.println("Connection: keep-alive");
            client.println();
            SetLEDs();
            // send XML file containing input states
            XML_response(client);
          else {  // web page request
            client.println("Content-Type: text/html");
            client.println();
            // send web page
            webFile = SD.open("index.htm");        // open web page file
            if (webFile) {
              while (webFile.available()) {
                client.write(webFile.read()); // send web page to client
              webFile.close();
          // zdefiniowanie elementów requesta
          for (int i = 0; i < 4; i++) {
            m_extract[i] = HTTP_req[7 + i];
          i_extract = HTTP_req[11];
          for (int i = 0; i < 2; i++) {
            v_extract[i] = HTTP_req[13 + i];
            sv_extract = v_extract;
          Serial.println(HTTP_req);
          req_index = 0;
          StrClear(HTTP_req, REQ_BUF_SZ);
        // every line of text received from the client ends with \r\n
        if (c == '\n') {
          // last character on line of received text
          // starting new line with next character read
        else if (c != '\r') {
          // a text character was received from client
          currentLineIsBlank = false;
      } // end if (client.available())
    } // end while (client.connected())
    delay(1);      // give the web browser time to receive the data
    client.stop(); // close the connection
  } // end if (client)
void SetLEDs(void)
  // define time, status and varialbe
  for (int i = 0; i < (sizeof maszyny) / 2; i++) {
    if (StrContains(m_extract, maszyny[i]) && i_extract == 't') {
      m_czas[i] = sv_extract.toInt();
          Serial.println(m_extract);
    Serial.println(i_extract);
    Serial.println(sv_extract);
    Serial.println(m_status[i]);
    if (StrContains(m_extract, maszyny[i]) && i_extract == 's') {
      m_status[i] = sv_extract.toInt();
void XML_response(EthernetClient cl)
  int analog_val;            // stores value read from analog inputs
  int count;                 // used by 'for' loops
  int sw_arr[] = {2, 3, 5};  // pins interfaced to switches
  cl.print("<?xml version = \"1.0\" ?>");
  cl.print("<inputs>");
  // read analog inputs
  for (count = 2; count <= 5; count++) { // A2 to A5
    analog_val = analogRead(count);
    cl.print("<analog>");
    cl.print(analog_val);
    cl.println("</analog>");
  // read switches
  for (count = 0; count < 3; count++) {
    cl.print("<switch>");
    if (digitalRead(sw_arr[count])) {
      cl.print("ON");
    else {
      cl.print("OFF");
    cl.println("</switch>");
  // checkbox LED states
  // LED1
  cl.print("<status1>");
  if (m_status[0]) {
    cl.print("on");
  else {
    cl.print("off");
  cl.println("</status1>");
  // LED2
  cl.print("<status2>");
  if (m_status[1]) {
    cl.print("on");
  else {
    cl.print("off");
  cl.println("</status2>");
  // button LED states
  // LED3
  cl.print("<status3>");
  if (m_status[2]) {
    cl.print("on");
  else {
    cl.print("off");
  cl.println("</status3>");
  // LED4
  cl.print("<status4>");
  if (m_status[3]) {
    cl.print("on");
  else {
    cl.print("off");
  cl.println("</status4>");
  cl.print("<slider>");
  cl.print(m_czas[0]);
  cl.println("</slider>");
  cl.print("</inputs>");
// sets every element of str to 0 (clears array)
void StrClear(char *str, char length)
  for (int i = 0; i < length; i++) {
    str[i] = 0;
// searches for the string sfind in the string str
// returns 1 if string found
// returns 0 if string not found
char StrContains(char *str, char *sfind)
  char found = 0;
  char index = 0;
  char len;
  len = strlen(str);
  if (strlen(sfind) > len) {
    return 0;
  while (index < len) {
    if (str[index] == sfind[found]) {
      found++;
      if (strlen(sfind) == found) {
        return 1;
    else {
      found = 0;
    index++;
  return 0;
Unless you are implimenting AJAX, then the data will not automatically update on an already open page.
If however, the issue is the data isn't being update when reloading the page, then more than likely, the browser is serving cached data. You can use headers to prevent the browser from caching data
https://cristian.sulea.net/blog/disable-browser-caching-with-meta-html-tags/
@merinum, your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advice on) your project :wink: See About the Installation & Troubleshooting category.
I am using AJAX, value of the slider which is on right side of the slider is updating all the time, only phisical slider is not moving and staying in one place
in my opinio problem is in html, but to be honest I do not know where
I don't think your problem is related to cache as you do have a randomize "nocache" string being added to your xml file. Have you looked at the xml file being created itself to see if the slider values are being correctly passed on? To do this, you should open your page in a Chrome browser (the dev tools are better imo) go to more tools -> developer tools and then select the network tab you should see something similar to the screen shot I attached bellow, except yours will say "x&nocache=" instead of "ajax_inputs&nocache=", click on that file and you should see the contents of your xml file. Also, you may want to check the online course on using the Arduino as a webserver which can be found here: Arduino IoT WebServer Course, I learned a ton about using the Arduino for projects similar to yours taking this course...
all the time value of the slider is transferred from arduino to web correctly - I can see this because additional I put
with value on right side of slider - this display correct data in all web browsers, only one problem is that phisical position of slider is not changing :frowning_face:
Maybe i'm tired, and i'm missing something...
Just so i understand correctly.
WHen you change the value of slider in one browser tab, it doesn't get changed in the other browser tab? Correct?
But if you directly change it in the arduino, it gets changed in both browser tabs?
Seems like you aren't posting the change back to the arduino when changing from the browser, or if you are, it's not getting handled properly
I am explaing: when I changing position of the slider web send via AJAX info to Arduino, than Arduino send it to the web and new value is saved in Arduino and dispayed on web next to the slider with good slider position, problem appearing when I open additional webbrowser and when I change slider position - than an another browser update only value which is next to the slider but not update phisically slider position
Having two clients simultaneously communicating with your webserver (Arduino) should be ok, but I remember from the course I previously mentioned that the Arduino performs well when serving one client, but serving 2 or more clients is asking way too much of it and will respond to each client painfully slow...
Looking at your code, I think I may have found an issue withing your html file here:
Shouldn't your document.getElementsByClassName("switches") be ("switch") as this is what you are calling it in your xml file ?
tanks for replay, in case of "switches": this is class for place where I put data in html, "switches" is tag in my xml file - this part of program works fine, in both webbrowsers I can see the results.
problem can be there:
// 63 slider
							slider = this.responseXML.getElementsByTagName('slider')[0].childNodes[0].nodeValue
							document.getElementById("r63slider").defaultValue = slider;
last line with + "s" working in both browsers fine, but line with default value works only in one browser .... I was trying milion combinations but effect is always the same: NOK :frowning:
hello
problem finally was solved: insted defaultValue it was necessary to insert valueAsNumber - now it is working like should work :slight_smile:
// 63 slider
							document.getElementById("r63slider").valueAsNumber =
Unless i completely missed something, i only saw GET's witch only retrieve data.. I didn't see anywhere in the code shown that you used Post, or Put to send data to the arduino
