Hello experts,
I am using ESP8266 01.
I am working on a project that uses 'ESP8266WebServer.h' & I had served an HTML file using this so when I opened this file, it sent current date & time data to the ESP using HTTP POST & it should Print that data on the serial monitor.
But the issue is it doesn't print the data! It is printing blank values.
00:40:31.593 -> Current fetched time n date: //-::
The code related to the output is:
webServer.on("/dtTmUpdateRTC", HTTP_POST, []() {
String yr0 = webServer.arg("yr0");
String mnt0 = webServer.arg("mnt0");
String dt0 = webServer.arg("dt0");
String hr0 = webServer.arg("hr0");
String min0 = webServer.arg("min0");
String sec0 = webServer.arg("sec0");
Serial.println("Current fetched time n date: " + yr0 + "/" + mnt0 + "/" + dt0 + "-" + hr0 + ":" + min0 + ":" + sec0);
webServer.send(200, "text/plain", "Date n Time Received!");
The complete code:
#include <ESP8266WiFi.h>
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#include <Preferences.h>
#include "html_strings.h"
const byte DNS_PORT = 53;
IPAddress apIP(192, 168, 0, 8);
DNSServer dnsServer;
ESP8266WebServer webServer(80);
Preferences preferences;
void handleAddEventPage() {
webServer.send(200, "text/html", add_editEventHtml);
WiFi.mode(WIFI_AP);
WiFi.softAPConfig(apIP, apIP, IPAddress(255, 255, 255, 0));
WiFi.softAP("Wifi", "Password");
dnsServer.start(DNS_PORT, "*", apIP);
webServer.onNotFound([]() {
webServer.send(200, "text/html", homePageHtml);
webServer.on("/add_event", HTTP_GET, handleAddEventPage); // Define the endpoint for the Add Event page
webServer.on("/manBtnHandler", HTTP_POST, []() {
String switchStateRelay = webServer.arg("switchStateRelay");
webServer.send(200, "text/plain", "Btn data recieved");
Serial.println("Button State:" + switchStateRelay);
webServer.begin();
dnsServer.processNextRequest();
webServer.handleClient();
html_strings.h:
String homePageHtml = R"(
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="UTF-8">
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<title>Toggle Button</title>
<style>
.container {
display: inline-block;
padding: 10px;
background-color: #707070;
/* Set your desired background color */
border-radius: 10px;
/* Set your desired border radius */
margin: 20px;
/* Style for the toggle button */
.toggle {
width: 60px;
height: 34px;
position: relative;
/* Style for the slider */
.slider {
position: absolute;
cursor: pointer;
top: 0;
left: 0;
right: 0;
bottom: 0;
background-color: #ccc;
transition: .4s;
border-radius: 34px;
/* Style for the circle */
.slider:before {
position: absolute;
content: "";
height: 26px;
width: 26px;
left: 4px;
bottom: 4px;
background-color: white;
transition: .4s;
border-radius: 50%;
/* Style for the toggle button when active */
input:checked+.slider {
background-color: #2196F3;
/* Style for the circle when active */
input:checked+.slider:before {
transform: translateX(26px);
</style>
</head>
<body>
<!-- Input checkbox element that acts as the toggle -->
<div class="container">
<h2>Switch</h2>
<label class="toggle">
<input type="checkbox" id="toggleButton" onchange='togglePost()' style="margin-left: 10px;">
<span class="slider"></span>
</label>
</div>
<script>
// Variable to hold the initial state of the toggle button
var initialToggleState = 1;
// Function to set the initial state of the toggle button
window.onload = function () {
var checkbox = document.getElementById('toggleButton');
checkbox.checked = initialToggleState;
//HTTP POST date & time
// Get the current date and time
var currentDate = new Date();
// Extract the components of the current date and time
var yr = currentDate.getFullYear();
var mnt = currentDate.getMonth() + 1; // Months are zero-based
var dt = currentDate.getDate();
var hr = currentDate.getHours();
var min = currentDate.getMinutes();
var sec = currentDate.getSeconds();
// Format the date and time as a string (adjust format as needed)
var formattedTime = yr + '-' + pad(mnt) + '-' + pad(dt) + ' ' + pad(hr) + ':' + pad(min) + ':' + pad(sec);
console.log(formattedTime)
// Send the current local time details via HTTP POST
fetch('dtTmUpdateRTC', {
method: 'POST',
headers: {
'Content-Type': 'application/json',
// Add any additional headers if needed
body: JSON.stringify({
yr0: yr,
mnt0: mnt,
dt0: dt,
hr0: hr,
min0: min,
sec0: sec,
function togglePost() {
// Get the checkbox element
// Check if the checkbox is checked
if (checkbox.checked) {
// Perform HTTP POST request in the background
fetch('manBtnHandler', {
method: 'POST',
headers: {
switchStateRelay: 1 // Set switchState to 1
// Add any additional data you want to send in the POST request body
method: 'POST',
headers: {
switchStateRelay: 0 // Set switchState to 1
function pad(number) {
return (number < 10 ? '0' : '') + number;
</script>
</body>
</html>
String add_editEventHtml = R"(
XYZ
Please help to find the reason behind this.
Thanks & Regards!!
--SRJ
