Hi everybody,
this is my first post here.
So please be gentile.
I "wrote" this Code by copying components from differnet sources.
Every component runs perfect by itself, but unfortunatelly the sketch uses too much RAM.
I Use a Arduino Ethernet Board. (not the ethernet shield)
Can someone please give me hints, how and where i can optmize the code for RAM usage?
Sadly I had to remove most of the comment due to the limited posting size in here.
Thanks alot so far.
#include <SD.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#include <string.h>
#include <SPI.h>
#include <Time.h>
#include <EEPROM.h>
#include <EEPROMAnything.h>
#include <avr/pgmspace.h>
/************** NTP STUFF ***************/
unsigned int localPort = 8888;
IPAddress timeServer(132, 163, 4, 101);
const int NTP_PACKET_SIZE= 48;
byte packetBuffer[ NTP_PACKET_SIZE];
EthernetUDP Udp;
/*** DATA LOGGER AND TIMER CONTROLS ****/
const int analogPin = 0;
unsigned long lastIntervalTime = 0;
#define MEASURE_INTERVAL 30000
unsigned long newFileTime;
#define FILE_INTERVAL 604800
/************ ETHERNET STUFF ************/
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 1, 125 };
EthernetServer server(80);
//A structure that stores file config variables from EEPROM
typedef struct{
char workingFilename[19];
} configuration;
configuration config; //Actually make our config struct
File root;
pinMode(4, OUTPUT);
SD.begin(4);
root = SD.open("/data/");
Serial.println("done!");
pinMode(10, OUTPUT); // set the SS pin as an output (necessary!)
digitalWrite(10, HIGH); // but turn off the W5100 chip!
Ethernet.begin(mac, ip);
server.begin();
Udp.begin(localPort);
root.close();
void printDirectory(EthernetClient client, File dir, int numTabs) {
while(true) {
File entry = dir.openNextFile();
if (! entry) {
// no more files
// return to the first file in the directory
dir.rewindDirectory();
client.print("<li><a href=\"HC.htm?file=");
client.print(entry.name());
client.print("\">");
client.print("</a></li>");
delay(100);
for (uint8_t i=0; i<numTabs; i++) {
Serial.print('\t');
Serial.print(entry.name());
entry.close();
unsigned long getTime(){
sendNTPpacket(timeServer); // send an NTP packet to a time server
if ( Udp.parsePacket() ) {
Udp.read(packetBuffer,NTP_PACKET_SIZE);
unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
unsigned long secsSince1900 = highWord << 16 | lowWord;
const unsigned long seventyYears = 2208988800UL;
unsigned long epoch = secsSince1900 - seventyYears;
return epoch;
unsigned long sendNTPpacket(IPAddress& address){
memset(packetBuffer, 0, NTP_PACKET_SIZE);
packetBuffer[0] = 0b11100011; // LI, Version, Mode
packetBuffer[1] = 0; // Stratum, or type of clock
packetBuffer[2] = 6; // Polling Interval
packetBuffer[3] = 0xEC; // Peer Clock Precision
packetBuffer[12] = 49;
packetBuffer[13] = 0x4E;
packetBuffer[14] = 49;
packetBuffer[15] = 52;
Udp.beginPacket(address, 123); //NTP requests are to port 123
Udp.write(packetBuffer,NTP_PACKET_SIZE);
Udp.endPacket();
#define BUFSIZ 40
{ if ((millis() % lastIntervalTime) >= MEASURE_INTERVAL){ //Is it time for a new measurement?
char dataString[15] = "";
int count = 0;
unsigned long rawTime;
rawTime = getTime();
while((rawTime == 39) && (count < 12)){
delay(5000);
count += 1;
if (rawTime != 39){
Serial.println("got Ntp Server Time");
if (rawTime >= config.newFileTime){
int dayInt = day(rawTime);
int monthInt = month(rawTime);
int yearInt = year(rawTime);
char newFilename[18] = "";
char dayStr[3];
char monthStr[3];
char yearStr[5];
char subYear[3];
strcat(newFilename,"/data/");
itoa(dayInt,dayStr,10);
if (dayInt < 10){
strcat(newFilename,"0");
strcat(newFilename,monthStr);
strcat(newFilename,"-");
itoa(yearInt,yearStr,10);
memcpy( subYear, &yearStr[2], 3 );
strcat(newFilename,subYear);
strcat(newFilename,".csv");
config.newFileTime += FILE_INTERVAL;
strcpy(config.workingFilename,newFilename);
EEPROM_writeAnything(0, config);
int sensor = analogRead(analogPin);
char timeStr[12];
char sensorStr[6];
ultoa(rawTime,timeStr,10);
itoa(sensor,sensorStr,10);
strcat(dataString,timeStr);
strcat(dataString,",");
strcat(dataString,sensorStr);
File dataFile = SD.open("/data/05-08-13.CSV", FILE_WRITE);
if (dataFile) {
dataFile.println(dataString);
dataFile.close();
Serial.println(dataFile);
Serial.println(dataString);
else {
Serial.println("Error opening datafile for writing");
else{
Serial.println("Couldn't resolve a time from the Ntp Server.");
lastIntervalTime = millis();
Serial.println(lastIntervalTime);
else{
File root;
char clientline[BUFSIZ];
int index = 0;
if (client) {
boolean current_line_is_blank = true;
index = 0;
while (client.connected()) {
if (client.available()) {
char c = client.read();
if (c != '\n' && c != '\r') {
clientline[index] = c;
index++;
if (index >= BUFSIZ)
index = BUFSIZ -1;
continue;
clientline[index] = 0;
Serial.println(clientline);
if (strstr(clientline, "GET / ") != 0) {
client.println("Content-Type: text/html");
client.println();
client.println("<h2>Files:</h2>");
printDirectory(client, root, 0);
PgmPrint("Free RAM: ");
Serial.println(FreeRam());
} else if (strstr(clientline, "GET /") != 0) {
char *filename;
filename = clientline + 5; // look after the "GET /" (5 chars)
(strstr(clientline, " HTTP"))[0] = 0;
Serial.println(filename);
/* if (! file.open(&root, filename, O_READ)) {
client.println("HTTP/1.1 404 Not Found");
client.println();
client.println("<h2>File Not Found!</h2>");
Serial.println("Opened!");
client.println("Content-Type: text/plain");
client.println();
int16_t c;
/* while ((c = file.read()) > 0) {
client.print((char)c);
// file.close();
client.println();
delay(1);
client.stop();
root.close();
