website connect to ESP8266
Dear All
I need to connect my website to ESP8266 module
My website have a button when i pressed the button it sends HEX value ( Ex 0x21)
My website running on wamp local server
my website send data on port21
My ESP is working how can I tell it I have a client software
I insert IP address to my client software taken from ESP and set the port and connect it and it is successful
Now I need to connect my website to ESP
Please advice
Thanks in advance
How are you uploading to the ESP8266?
ESP codes please advice
/ Connect to WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  // Start the server
  server.begin();
  Serial.println("Server started");
  // Print the IP address
  Serial.print("Use this URL to connect: ");
  Serial.print(WiFi.localIP());
  // Check if a client has connected
  WiFiClient client = server.available();
  if (!client) {
    return;
  // Wait until the client sends some data
  Serial.println("new client");
  while (!client.available()) {
    delay(1);
  // Read the first line of the request
  String request = client.readStringUntil('\r');
  Serial.print("Received: ");
  Serial.println(request);
  client.flush();
You want the esp to be a client but you're using server code?
Dear Website not run on ESP
It is run on my laptop local host using wamp sever
Exactly
And where do you think this is sent? Who will press the button and where do you want "the value to go"?
DEAR JML
Thanks for the reply
my website is running on my laptop using wamp server
web button is pressed by myself
my laptop and my ESP connected to hostspot ( 4G WiFi router
my ESP connected to rs232 and my desktop
please advice
So when you press the button your server is notified - right? So where do you see your ESP in this? It does not play any role.
So you need to change the roles - either your ESP becomes the web server and presents the front end to a browser, thus when you click, the ESP is notified or You need to change the code so that when you press the button a request (HTTP or any network transport layer connexion is established ) is sent to your ESP with the data.
Makes sense?
