#include <WiFi.h>
#include <WiFiClient.h>
#include <WiFiAP.h>
#include <SPI.h>
#include <mcp2515.h>
#include <MCUFRIEND_kbv.h>
struct can_frame canMsg;
//char receivedChars[11];
MCP2515 mcp2515(10);
MCUFRIEND_kbv tft;
#include <Fonts/FreeSans9pt7b.h>
#include <Fonts/FreeSans12pt7b.h>
#include <Fonts/FreeSerif12pt7b.h>
#include <FreeDefaultFonts.h>
#define BLACK 0x0000 /* 0, 0, 0 */
#define NAVY 0x000F /* 0, 0, 128 */
#define DARKGREEN 0x03E0 /* 0, 128, 0 */
#define DARKCYAN 0x03EF /* 0, 128, 128 */
#define MAROON 0x7800 /* 128, 0, 0 */
#define PURPLE 0x780F /* 128, 0, 128 */
#define OLIVE 0x7BE0 /* 128, 128, 0 */
#define LIGHTGREY 0xC618 /* 192, 192, 192 */
#define DARKGREY 0x7BEF /* 128, 128, 128 */
#define BLUE 0x001F /* 0, 0, 255 */
#define GREEN 0x07E0 /* 0, 255, 0 */
#define CYAN 0x07FF /* 0, 255, 255 */
#define RED 0xF800 /* 255, 0, 0 */
#define MAGENTA 0xF81F /* 255, 0, 255 */
#define YELLOW 0xFFE0 /* 255, 255, 0 */
#define WHITE 0xFFFF /* 255, 255, 255 */
#define ORANGE 0xFDA0 /* 255, 180, 0 */
#define GREENYELLOW 0xB7E0 /* 180, 255, 0 */
#define PINK 0xFC9F
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
// Set these to your desired credentials.
const char *ssid = "canbusweb";
const char *password = "login123";
WiFiServer server(80);
String header;
mcp2515.reset();
mcp2515.setBitrate(CAN_500KBPS);
mcp2515.setNormalMode();
Serial.println("Configuring access point...");
// You can remove the password parameter if you want the AP to be open.
WiFi.softAP(ssid, password);
IPAddress myIP = WiFi.softAPIP();
Serial.print("AP IP address: ");
Serial.println(myIP);
server.begin();
Serial.println("Server started");
WiFiClient client = server.available(); // listen for incoming clients
if (mcp2515.readMessage(&canMsg) == MCP2515::ERROR_OK) {
//start of voltage meter
if (canMsg.can_id == 0x789 && canMsg.data[canMsg.can_dlc - 5] == 0x42) {
decodevolts();
//end of voltage meter
//start of SoC
if (canMsg.can_id == 0x789 && canMsg.data[canMsg.can_dlc - 5] == 0x46) {
decodesoc();
//end of SoC
//start of tyre pressure
if (canMsg.can_id == 0x72C) {
decodeTyre();
} //end of tyre pressure
//start of odometer
if (canMsg.can_id == 0x768) {
decodeOdometer();
//end of odometer
//start of doors
if (canMsg.can_id == 0x748 && canMsg.data[canMsg.can_dlc - 5] == 0x12) {
decodeDoors();
//end of doors
//start of lights
if (canMsg.can_id == 0x748 && canMsg.data[canMsg.can_dlc - 5] == 0x17) {
decodelights();
//end of lights
//start of temp
if (canMsg.can_id == 0x7EB && canMsg.data[canMsg.can_dlc - 5] == 0x1B) {
decodecharge();
//end of temp
Serial.print(canMsg.can_id, HEX); // print ID
Serial.print(" ");
Serial.print(canMsg.can_dlc, HEX); // print DLC
Serial.print(" ");
for (int i = 0; i < canMsg.can_dlc; i++) {
if (canMsg.data[i] < 0x10) Serial.print('0');
Serial.print(canMsg.data[i], HEX);
Serial.print(' ');
if (client) { // If a new client connects,
Serial.println("New Client."); // print a message out in the serial port
String currentLine = ""; // make a String to hold incoming data from the client
if (client.available()) { // if there's bytes to read from the client,
// Display the HTML web page
client.println("<!DOCTYPE html><html>");
client.println("<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">");
client.println("<link rel=\"icon\" href=\"data:,\">");
// CSS to style the table
client.println("<style>body { text-align: center; font-family: \"Trebuchet MS\", Arial;}");
client.println("table { border-collapse: collapse; width:35%; margin-left:auto; margin-right:auto; }");
client.println("th { padding: 12px; background-color: #0055af; color: white; }");
client.println("tr { border: 1px solid #ddd; padding: 12px; }");
client.println("tr:hover { background-color: #bcbcbc; }");
client.println("td { border: none; padding: 12px; }");
void decodeOdometer() {
/* decode Odometer
id = 0x0768
dlc = 7
example data[] = 06 62 B1 01 00 04 75 00
data byte values 04 75
24 bit value
uint32_t Odo = (uint32_t) canMsg.data[canMsg.can_dlc - 3] * 256 + (uint32_t) canMsg.data[canMsg.can_dlc - 2];
tft.fillRect(20, 195, 150, 40, BLACK);
tft.setCursor(30, 200);
tft.setTextSize(3);
tft.setTextColor(ORANGE, BLACK);
tft.print(Odo / 1.609344, 1);
void decodeTyre() {
/* decode Tyre pressure
id = 0x072C
dlc = 8
example data[] = 07 62 B0 01 41 36 41 41
data byte values (last 4 bytes)
byte 3 = front left
byte 4 = front right
byte 5 = rear right
byte 6 = rear left
byte RL = canMsg.data[7];
byte RR = canMsg.data[6];
byte FR = canMsg.data[5];
byte FL = canMsg.data[4];
float pressrl = RL * 0.5823 - 0.15294;
float pressrr = RR * 0.5823 - 0.15294;
float pressfr = FR * 0.5823 - 0.15294;
float pressfl = FL * 0.5823 - 0.15294;
tft.fillRect(20, 47, 40, 70, BLACK); // tyre car
tft.fillRect(98, 47, 40, 70, BLACK); // tyre car
tft.setTextColor(BLUE, BLACK);
tft.setTextSize(2);
tft.setCursor(18, 96);
tft.print(pressrl, 1);
tft.setCursor(100, 96);
tft.print(pressrr, 1);
tft.setCursor(100, 52);
tft.print(pressfr, 1);
tft.setCursor(18, 52);
tft.print(pressfl, 1);
void decodeDoors() {
/* decode open doors
id = 0x0748
dlc = 8
example data[] = 01 62 D1 12 80 00 00 00
0x80 = no doors open
0x01 = Driver door
0x02 = passenger door
0x04 = rear left door
0x05 = rear right door
0x10 = bonnet
0x20 = boot
for ( int i = 4; i < canMsg.can_dlc; ++i ) {
switch ( canMsg.data[i] ) {
case 0x80:
tft.fillRect(345, 27, 70, 100, BLACK);
return; // nothing so no need to continue
case 0x01:
tft.drawRect(370, 47, 20, 70, WHITE); // door car
tft.setTextColor(RED, BLACK);
tft.setTextSize(3);
tft.setCursor(398, 52);
tft.print(">");
case 0x02:
tft.setTextSize(3);
tft.setCursor(342, 52);
tft.print("<");
case 0x04:
tft.setTextSize(3);
tft.setCursor(342, 96);
tft.print("<");
case 0x05:
tft.setTextSize(3);
tft.setCursor(398, 96);
tft.print(">");
case 0x10:
tft.setTextColor(RED);
tft.setTextSize(3);
tft.setCursor(372, 32);
tft.print("^");
case 0x20:
tft.setTextSize(3);
tft.setCursor(372, 105);
tft.print("^");
void decodevolts() {
/* decode Volts
id = 0x0789
dlc = 8
example data[] = 05 62 B0 42 06 8C 00 00
data byte values are 06 and 8C
24 bit value
uint32_t battvolt = (uint32_t) canMsg.data[canMsg.can_dlc - 4] * 256 + (uint32_t) canMsg.data[canMsg.can_dlc - 3];
tft.fillRect(50, 240, 140, 40, BLACK);
tft.setCursor(100, 245);
tft.setTextSize(4);
tft.print(battvolt / 4);
tft.fillRect(100, 290, 285, 30, BLACK);
tft.fillRect(100, 290, 10, 30, RED);
tft.fillRect(375, 290, 10, 30, GREEN);
tft.fillRect(240, 290, 10, 30, ORANGE);
if (battvolt >= 8 && battvolt < 1676) {
tft.fillRect(110, 300, battvolt / 8, 10, WHITE);
} else if (battvolt == 1676)
tft.fillRect(110, 300, 265, 10, WHITE);
void decodesoc() {
/* decode Volts
id = 0x0789
dlc = 8
example data[] = 05 62 B0 46 06 8C 00 00
data byte values (last 3 bytes)
24 bit value
uint32_t Soc = (uint32_t) canMsg.data[canMsg.can_dlc - 4] * 256 + (uint32_t) canMsg.data[canMsg.can_dlc - 3];
if (Soc >= 1000) {
tft.fillRect(235, 240, 125, 40, BLACK);
tft.setCursor(255, 245);
tft.setTextSize(4);
tft.print(100);
tft.setCursor(245, 245);
tft.setTextSize(4);
tft.print(" ");
tft.print(Soc / 10);
void decodelights() {
/* decode lights
id = 0x0748
dlc = 8
example data[] = 07 62 D1 17 04 20 00 00 - lights on
07 62 D1 17 00 20 00 00 - lights off
data byte values
0x04 = lights on
0x00 = lights off
switch ( canMsg.data[4] ) {
case 0x00:
tft.fillRect(200, 55, 50, 50, BLACK);
tft.drawRect(200, 55, 50, 50, WHITE);
tft.setTextColor(WHITE);
tft.setTextSize(5);
tft.setCursor(200, 61);
tft.print("=)");
case 0x04:
tft.fillRect(200, 55, 50, 50, GREEN);
tft.setTextSize(5);
tft.print("=)");
void decodecharge() {
/* decode charger
id = 0x07EB
dlc = 8
example data[] = 04 62 B7 1B 00 00 00 00 -
04 62 B7 1B 01 00 00 00 -
data byte values
0x04 = charger connected
0x00 = charger disconnected
case 0x00:
tft.fillRect(200, 110, 50, 50, BLACK);
tft.drawRect(200, 110, 50, 50, WHITE);
tft.setTextSize(5);
tft.setCursor(215, 127);
tft.print("~ ");
break; // nothing so no need to continue
case 0x01:
tft.fillRect(200, 110, 50, 50, GREEN);
tft.setTextColor(BLACK);
tft.setTextSize(5);
tft.print("~ ");
i have a working code which takes data from canbus and displays it on tft, but i want to make it sent it to a webpage that clients can access showing the charge data etc.
i have got the code to work where it creates a blank page but have no way of working out how to send the data.
can anyone help?
