I created a website from my arduino and everything works fine from chrome and internet explorer.
but when i want to open the site with my ipad i receive the something like message safari cannot open page because server not responding anymore
i have a dutch message so i translated it myself.
on my arduino everything i receive or send looks the same.
when i open the site from my arduino with my laptop save the html on my inet webserver my ipad can open the page. so it's not a html issue.
i only use the ethernet library
the only command i use is server.print
example.
You can try the below meta refresh code to see if it will work with your ipad.
// zoomkat meta refresh server test code
// arduino IDE 1.0
// for W5100 ethernet shield
// the IP address will be dependent on your local network/router
// port 80 is default for HTTP, but can be changed as needed
// use IP address like http://192.168.1.102:84 in your brouser
// or http://zoomkat.no-ip.com:84 with dynamic IP service
// use the \ slash to escape the " in the html
// meta refresh set for 2 seconds
#include <SPI.h>
#include <Ethernet.h>
int x=0; //set refresh counter to 0
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,1,102); // ip in lan
EthernetServer server(84); //server is using port 84
// start the server
Ethernet.begin(mac, ip);
server.begin();
// listen for incoming clients
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
// see if HTTP request has ended with blank line
if (c == '\n') {
// send a standard http response header
client.println("Content-Type: text/html");
client.println();
//meta-refresh page every 2 seconds
x=x+1; //page upload counter
client.println("<HTML>");
client.print("<HEAD>");
client.print("<meta http-equiv=\"refresh\" content=\"2\">");
client.print("<TITLE />Zoomkat's meta-refresh test</title>");
client.print("</head>");
client.println("<BODY>");
client.print("Zoomkat's meta-refresh test IDE 1.0");
client.println("
client.print("page refresh number ");
client.println(x); //current refresh count
client.println("
client.println("
client.print("Zoomkat's arduino analog input values:");
client.println("
client.println("
// output the value of each analog input pin
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
client.print("analog input ");
client.print(analogChannel);
client.print(" is ");
client.print(analogRead(analogChannel));
client.println("
client.println("</BODY>");
client.println("</HTML>");
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
