hi friends...i get data to websites
serial monitor is data payload=1
arduino code is
digitalWrite(2, payload);
but circuit is not working...why could it be
arduino code is
There is a bug in the code you have not posted. Please post the entire sketch, otherwise we can't tell you what the problem is.
#include <ESP8266WiFi.h>
#include <ESP8266HTTPClient.h>
const char* ssid = "Kablonet_Netmaster-FAF6-G";
const char* password = "mortMen20122111";
Serial.begin(115200); // Start the serial monitor.
pinMode(2, OUTPUT); // Set GPIO2 as an OUTPUT.
digitalWrite(2, 0); // Start off.
Serial.println("Hello Digital Craft");
Serial.println("connecting");
WiFi.begin(ssid,password);
// Show ... until connected:
Serial.print(".");
Serial.println("WiFi connected");
// Print the IP address of the device:
// Verfiy WiFi is connected:
if (WiFi.status() == WL_CONNECTED) {
HTTPClient http; // Object of the class HTTPClient.
http.begin("http://dislik.com/nodemcu//urun-lux-kasket-sapka-5"); // Request destination.
int httpCode = http.GET(); // Send the request.
if (httpCode > 0) { //Check the returning code
Serial.println("We got a repsonse!");
String payload = http.getString(); // Get the text from the destination (1 or 0).
Serial.println(payload); // Print the text.
digitalWrite(2, payload.toInt()); // Send the payload value to the pin.
}else{
Serial.println("Something baaaaaaad happened!");
http.end(); //Close connection
delay(1000); //Send a request every 30 seconds
answer is 1 but not working
The answer is NOT 1. The answer is "1".
But, all you have is a bunch of meaningless anonymous printing of something that you don't use.
Serial.print("payload: [");
Serial.print(payload);
Serial.println("]");
conveys orders of magnitude more information than
int pinState = payload.toInt();
Serial.print("pinState: ");
Serial.println(pinState);
Now, you can use pinState and KNOW what value if contains.
If the pin does not appear to change state, when you KNOW what state it is supposed to change to, then whatever means you are using to determine that is wrong.
hi Paul
there is a meaningless problem
int pinState=payload.toInt();
Serial.print("payload: ");
seial monitor
payload : 1
pinState : 0
payload and pinstate not equal
payload is "1"
pinstate=payload.toint();
pinstate= "0"
and led is not blinking
I suggested that you print payload between markers so that you could see EXACTLY what it contains. You didn't. Before I will offer more help, I need to understand why you did not follow my previous advice.
You just MIGHT have learned something interesting.
hi Paul
I've tried
digitalWrite(2, pinState);
Serial monitor
payload: [1]
pinState: 0
Did you mean that?
I understand you say that
result does not change
Did you mean that?
Yes.
Now, it is clear that payload is a String wrapping a string that contains just one character.
It is equally clear that the toInt() method of that String is failing to convert the string in the payload String to an int correctly.
Or, is it? Actually, it is not, which is why we ask that you post ALL of your code every time. I'd like to believe that the 8 lines of code in your snippet are 8 consecutive lines in you total code, but I need to be convinced that that is the case.
Serial.print(".");
http.begin("http://www.atikermuhendislik.com/urun-lux-kasket-sapka-5"); // Request destination.
}else{
this all code
yes, not working properly
The next step would be to edit the String class' toInt() method, to add some Serial.print() statements, to learn why it does not work. There is nothing in the code you posted to suggest why toInt() is failing. The input looks good. The output should be something different from what is actually output.
But, before you go there, create a simple sketch.
String payload = "1";
What does this code show? What happens to pin 2?
PaulS:
result of this code
serial monitor => pinState:1
pin2 is led blinking
So, there is something in the ESP8266xxxx libraries that is causing String::toInt() to malfunction. Start adding the header files into that code, one at a time, compiling and linking and testing in between each addition.
If it isn't just a matter of adding an otherwise unused header file, start adding bits of code back in, compiling and linking and testing in between each addition. It shouldn't take long to figure out what the problem is.
i will try Paul
Thanks for the help
