Websocket is sending only one time
Hello,
i have a websocketserver running on a ESP32 which works perfect.
My problem is that if i send a message to the server over a website the socketserver on the ESP32 executes the .send(message) only the first time and is not sending anymore.
If i send a message from the console in chrome it works every time.
so my problem seem not to be on the server-side but on the client-side.
This is my code running inside chrome:
<!DOCTYPE html>
<head>
    <title>WH_Quiz</title>
    <style>
        body {
            background: url(Images/SET_1/A1_INTRO.png) no-repeat center center fixed;
            -webkit-background-size: cover;
    </style>
</head>
<body>
    <script>
        // clear localStorage
        window.localStorage.clear();
        // open websocket
        var url = "ws://192.168.4.1:1337";
        websocket = new WebSocket(url);
        websocket.onopen = function (event) {
            console.log('websocket is open');
            websocket.send("L");
        // Keep track of clicked keys
        var isKeyPressed = {
            'a': false, // ASCII code for 'a'
            'b': false, // ASCII code for 'b'
            // ... Other keys to check for custom key combinations
        document.onkeydown = (keyDownEvent) => {
            // Prevent default key actions, if desired
            keyDownEvent.preventDefault();
            // Track down key click
            isKeyPressed[keyDownEvent.key] = true;
            // Check described custom shortcut
            if (isKeyPressed['a']) { //for example we want to check if a is clicked
                //do something
                console.log('a has been pressed');
                    console.log('a has been pressed and wesocket is open');
                    window.location.href = '1_1.html'; // öffne Fragenkatalog 1
                    websocket.send("4G");
             if (isKeyPressed['b']) { //for example we want to check if b is clicked
                //do something
                console.log('b has been pressed');
                    window.location.href = '2_1.html'; // öffne Fragenkatalog 2
                    websocket.send("4R");
    </script>
</body>
</html>
Does anybody could explain me where the problem is?
Thanks to all.
@petemanzel, your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advice on) your project :wink: See About the Installation & Troubleshooting category.
