First I want to apologize for the mess in the code. it’s a hodge pod of different snippets I’m trying to send the ina219 data to the webpage and well Im totally lost ive watched several tutorials and well I copied some code here from it and tried to edit
please let me know in the many ways I have botched this code. Thanks
I’m advanced
Rui Santos
Complete project details at ESP32 WebSocket Server: Control Outputs (Arduino IDE) | Random Nerd Tutorials
The above copyright notice and this permission notice shall be included in all
copies or substantial portions of the Software.
// Import required libraries
#include <WiFi.h>
#include <AsyncTCP.h>
#include <ESPAsyncWebServer.h>
#include <Adafruit_INA219.h>
Adafruit_INA219 ina219;
// Replace with your network credentials
const char* ssid = "waGgs";
const char* password = "wfk#r";
bool ledState = 0;
const int ledPin = 19;
// Create AsyncWebServer object on port 80
AsyncWebServer server(80);
AsyncWebSocket ws("/ws");
const char index_html[] PROGMEM = R"rawliteral(
Topward 3603D Server html { font-family: Arial, Helvetica, sans-serif; text-align: center; } h1 { font-size: 1.8rem; color: white; } h2{ font-size: 1.5rem; font-weight: bold; color: #778899; } .topnav { overflow: hidden; background-color: #143642; } body { margin: 0; } .content { padding: 30px; max-width: 600px; margin: 0 auto; } .card { background-color: #F8F7F9;; box-shadow: 2px 2px 12px 1px rgba(140,140,140,.5); padding-top:10px; padding-bottom:20px; } .button { padding: 15px 50px; font-size: 24px; text-align: center; outline: none; color: #fff; background-color: #0f8b8d; border: none; border-radius: 5px; -webkit-touch-callout: none; -webkit-user-select: none; -khtml-user-select: none; -moz-user-select: none; -ms-user-select: none; user-select: none; -webkit-tap-highlight-color: rgba(0,0,0,0); } /*.button:hover {background-color: #0f8b8d}*/ .button:active { background-color: #0f8b8d; box-shadow: 2 2px #CDCDCD; transform: translateY(2px); } .state { font-size: 1.5rem; color:#8c8c8c; font-weight: bold; } Topward 3603D ServerTopward 3603D Server
Channel 1
Voltage %VOLTAGE% &Mv;C
Current %CURRENT% &Ma;
%STATE%
Output
// Replaces placeholder with INA219 values
String processor(const String& var){
//Serial.println(var);
if(var == "voltage"){
return ina219.getBusVoltage_V();
else if(var == "current"){
return ina219.current_mA();
return String();
void notifyClients() {
ws.textAll(String(ledState));
void handleWebSocketMessage(void *arg, uint8_t data, size_t len) {
AwsFrameInfo info = (AwsFrameInfo)arg;
if (info->final && info->index == 0 && info->len == len && info->opcode == WS_TEXT) {
data[len] = 0;
if (strcmp((char)data, "toggle") == 0) {
ledState = !ledState;
notifyClients();
void onEvent(AsyncWebSocket *server, AsyncWebSocketClient *client, AwsEventType type,
void *arg, uint8_t *data, size_t len) {
switch (type) {
case WS_EVT_CONNECT:
Serial.printf("WebSocket client #%u connected from %s\n", client->id(), client->remoteIP().toString().c_str());
case WS_EVT_DISCONNECT:
Serial.printf("WebSocket client #%u disconnected\n", client->id());
case WS_EVT_DATA:
handleWebSocketMessage(arg, data, len);
case WS_EVT_PONG:
case WS_EVT_ERROR:
void initWebSocket() {
ws.onEvent(onEvent);
server.addHandler(&ws);
if(var == "STATE"){
if (ledState){
return "ON";
else{
return "OFF";
void setup(){
// Serial port for debugging purposes
IAN219.begin();
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, LOW);
// Connect to Wi-Fi
WiFi.begin(ssid, password);
Serial.println("Connecting to WiFi..");
// Print ESP Local IP Address
initWebSocket();
// Route for root / web page
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/html", index_html, processor);
server.on("/voltage", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/plain", busvoltage().c_str());
server.on("/current", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/plain", current().c_str());
// Start server
server.begin();
ws.cleanupClients();
digitalWrite(ledPin, ledState);
float parameter = 12.12; // floating number
String myStringe = ""; // empty string
myString.concat(parameter);
