Websockets connection Esp8266 - Esp8266 unsuccessful
I am trying the Websockets library for the first time on two Esp8266 modules but during connection the server has an exception and won't connect to the client module. Could anyone recommend any changes to make this work? I am using the example sketches from ESP8266 modified for my network.
This is the Server output from the start of the sketch:
SDK:2.2.1(cfd48f3)/Core:2.4.1/lwIP:2.0.3(STABLE-2_0_3_RELEASE/glue:arduino-2.4.1)
setup begin
[SETUP] BOOT WAIT 4...
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 2
cnt
connected with WOW!3630_ext, channel 11
dhcp client start...
ip:192.168.0.7,mask:255.255.255.0,gw:192.168.0.1
[SETUP] BOOT WAIT 3...
[SETUP] BOOT WAIT 2...
[SETUP] BOOT WAIT 1...
[WS-Server] Server Started.
[WS-Server][0] new client from 192.168.0.12
[WS-Server][0][handleHeader] RX: GET / HTTP/1.1
[WS-Server][0][handleHeader] RX: Host: 192.168.0.7:81
[WS-Server][0][handleHeader] RX: Connection: Upgrade
[WS-Server][0][handleHeader] RX: Upgrade: websocket
[WS-Server][0][handleHeader] RX: Sec-WebSocket-Version: 13
[WS-Server][0][handleHeader] RX: Sec-WebSocket-Key: 89TB/qzj5p+uAJQNnw9txw==
[WS-Server][0][handleHeader] RX: Sec-WebSocket-Protocol: arduino
[WS-Server][0][handleHeader] RX: Origin: file://
[WS-Server][0][handleHeader] RX: User-Agent: arduino-WebSocket-Client
[WS-Server][0][handleHeader] Header read fin.
[WS-Server][0][handleHeader]  - cURL: /
[WS-Server][0][handleHeader]  - cIsUpgrade: 1
[WS-Server][0][handleHeader]  - cIsWebsocket: 1
[WS-Server][0][handleHeader]  - cKey: 89TB/qzj5p+uAJQNnw9txw==
[WS-Server][0][handleHeader]  - cProtocol: arduino
Fatal exception 28(LoadProhibitedCause):
epc1=0x4020ce2c, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
This is the client output from the start of the connection:
[WS-Client] connect ws...
[WS-Client] connected to 192.168.0.7:81.
[WS-Client][sendHeader] sending header...
[WS-Client][sendHeader] handshake GET / HTTP/1.1
Connection: Upgrade
Upgrade: websocket
Sec-WebSocket-Key: T57FcCdF0oWyA7owplcUYg==
Origin: file://
[write] n: 241 t: 1241497
[WS-Client][sendHeader] sending header... Done (26788us).
[WS-Client] connection lost.
[WS-Client] client disconnected.
[WSc] Disconnected!
I attached the client and server ino files. The sketches are very simple client just tries to repeatedly connect every 10 seconds. Is there any reason why this shouldn't work?
WebSocketServer_for_forum1.ino (1.67 KB)
WebSocketClient_for_forum1.ino (1.38 KB)
why WebSocket?
there is somewhere a tool that deciphers the crash report
Thanks. I was using UDP but losing some packets. I'd like to try to stream data between ESP8266s at high rate. My test sketches are very basic, I am not a networking expert, does someone know if websockets between 2 ESPs is possible or should work?
I get an error when I try to use the ESP Exception decoder in the IDE, it won't run, I posted about this previously but didn't get a response. I attached the crash report if anyone is interested.
websockets esp8266 crash report1.txt (2.88 KB)
I installed a previous version of the decoder and got a result. This is the first time I've used this. But from what I understand, it appears it failed on a print command initiated from the webSocketsServer.cpp file. However line 158 is a commented line, should the line numbers match the line numbers in the file?
0x4020aebc: __ssputs_r at /Users/igrokhotkov/e/newlib-xtensa/xtensa-lx106-elf/newlib/libc/stdio/../../../.././newlib/libc/stdio/nano-vfprintf.c line 180
0x402073c0: _printf_i at /Users/igrokhotkov/e/newlib-xtensa/xtensa-lx106-elf/newlib/libc/stdio/../../../.././newlib/libc/stdio/nano-vfprintf_i.c line 241
0x401025ab: wDev_ProcessFiq at ?? line ?
0x4020b31c: _svfprintf_r at /Users/igrokhotkov/e/newlib-xtensa/xtensa-lx106-elf/newlib/libc/stdio/../../../.././newlib/libc/stdio/nano-vfprintf.c line 641
0x40201c0b: uart_write_char at C:\Users\perigalacticon\AppData\Local\arduino15\packages\esp8266\hardware\esp8266\2.4.1\cores\esp8266/uart.c line 464
0x402053f5: HardwareSerial::write(unsigned char) at C:\Users\perigalacticon\AppData\Local\arduino15\packages\esp8266\hardware\esp8266\2.4.1\cores\esp8266/HardwareSerial.cpp line 188
0x40208cfd: _vsnprintf_r at /Users/igrokhotkov/e/newlib-xtensa/xtensa-lx106-elf/newlib/libc/stdio/../../../.././newlib/libc/stdio/vsnprintf.c line 73
0x40100516: check_poison_block at C:\Users\perigalacticon\AppData\Local\arduino15\packages\esp8266\hardware\esp8266\2.4.1\cores\esp8266\umm_malloc/umm_malloc.c line 865
0x4010060b: check_poison_all_blocks at C:\Users\perigalacticon\AppData\Local\arduino15\packages\esp8266\hardware\esp8266\2.4.1\cores\esp8266\umm_malloc/umm_malloc.c line 886
0x40208d40: vsnprintf at /Users/igrokhotkov/e/newlib-xtensa/xtensa-lx106-elf/newlib/libc/stdio/../../../.././newlib/libc/stdio/vsnprintf.c line 42
0x40206574: Print::write(unsigned char const*, unsigned int) at C:\Users\perigalacticon\AppData\Local\arduino15\packages\esp8266\hardware\esp8266\2.4.1\cores\esp8266/Print.cpp line 107
0x40205710: Print::printf(char const*, ...) at C:\Users\perigalacticon\AppData\Local\arduino15\packages\esp8266\hardware\esp8266\2.4.1\cores\esp8266/Print.cpp line 107
0x40205b5b: String::changeBuffer(unsigned int) at C:\Users\perigalacticon\AppData\Local\arduino15\packages\esp8266\hardware\esp8266\2.4.1\cores\esp8266/WString.cpp line 746
0x40204d8b: WebSocketsServer::handleHeader(WSclient_t*, String*) at C:\Users\perigalacticon\Documents\Arduino\libraries\arduino_211564\src/WebSocketsServer.cpp line 158
0x40213e9c: mem_free at /local/users/gauchard/arduino/arduino_esp8266/origin/tools/sdk/lwip2/builder/lwip2-src/src/core/mem.c line 152
0x4020f9f9: pbuf_free_LWIP2 at /local/users/gauchard/arduino/arduino_esp8266/origin/tools/sdk/lwip2/builder/lwip2-src/src/core/pbuf.c line 1306
0x402031c5: ClientContext::_consume(unsigned int) at C:\Users\perigalacticon\AppData\Local\arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\ESP8266WiFi\src/WiFiClient.cpp line 92
0x40203226: ClientContext::read() at C:\Users\perigalacticon\AppData\Local\arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\ESP8266WiFi\src/WiFiClient.cpp line 92
:  (inlined by) WiFiClient::read() at C:\Users\perigalacticon\AppData\Local\arduino15\packages\esp8266\hardware\esp8266\2.4.1\libraries\ESP8266WiFi\src/WiFiClient.cpp line 226
0x40205977: Stream::timedRead() at C:\Users\perigalacticon\AppData\Local\arduino15\packages\esp8266\hardware\esp8266\2.4.1\cores\esp8266/Stream.cpp line 68
0x40205007: WebSocketsServer::handleClientData() at C:\Users\perigalacticon\Documents\Arduino\libraries\arduino_211564\src/WebSocketsServer.cpp line 158
0x402049c0: WebSocketsServer::handleNewClients() at C:\Users\perigalacticon\Documents\Arduino\libraries\arduino_211564\src/WebSocketsServer.cpp line 158
0x40202210: webSocketEvent(unsigned char, WStype_t, unsigned char*, unsigned int) at C:\Users\perigalacticon\AppData\Local\Temp\VMBuilds\WebSocketServer\esp8266_generic\Debug/WebSocketServer.cpp line 25
0x4020627c: std::_Function_base::_Base_manager ::_M_manager(std::_Any_data&, std::_Any_data const&, std::_Manager_operation) at c:\users\perigalacticon\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2/functional line 1934
0x4020505c: WebSocketsServer::loop() at C:\Users\perigalacticon\Documents\Arduino\libraries\arduino_211564\src/WebSocketsServer.cpp line 158
0x402023ac: loop at C:\Users\perigalacticon\AppData\Local\Temp\VMBuilds\WebSocketServer\esp8266_generic\Debug/WebSocketServer.cpp line 88
0x40205230: loop_wrapper at C:\Users\perigalacticon\AppData\Local\arduino15\packages\esp8266\hardware\esp8266\2.4.1\cores\esp8266/core_esp8266_main.cpp line 57
0x40100a2c: cont_norm at C:\Users\perigalacticon\AppData\Local\arduino15\packages\esp8266\hardware\esp8266\2.4.1\cores\esp8266/cont.S line 109
use plain sockets. WFiCient wraps TCP socket and WiFiServer wraps listening TCP socket
Thanks. Do you mean using something like this:
#include <WiFi.h>
const char* ssid = "YourNetworkName";
const char* password =  "YourNetworkPassword";
WiFiServer wifiServer(80);
  WiFi.begin(ssid, password);
    Serial.println("Connecting to WiFi..");
  Serial.println("Connected to the WiFi network");
  wifiServer.begin();
  WiFiClient client = wifiServer.available();
  if (client) {
    while (client.connected()) {
      while (client.available()>0) {
        char c = client.read();
        client.write(c);
      delay(10);
    client.stop();
    Serial.println("Client disconnected");
I read that using TCP connections to send many packets are slow compared to UDP as the connection needs to be established for each TCP packet sent, Is this correct?? It seems like the client can remain connected in the Arduino code... I am looking for about 24kB/s.
in esp8266 you can set keep-alive on client connection
