History: WebSockets_Generic. Now supporting nRF52, SAMD, Teensy, STM32, DUE, etc
Major Release v2.8.0
- Add support to WT32_ETH01 (ESP32 + LAN8720) boards
- Add examples with new features
Major Release v2.7.0
- Add support to RP2040-based boards, such as RASPBERRY_PI_PICO, ADAFRUIT_FEATHER_RP2040 and GENERIC_RP2040, using Earle Philhower's arduino-pico v1.6.2+ core.
- Add support to RP2040-based boards, such as RASPBERRY_PI_PICO, ADAFRUIT_FEATHER_RP2040 and GENERIC_RP2040, using Arduino-mbed RP2040 v2.1.0+ core.
- Update Socket.IO Test Server to demonstrate the server message broadcast
- Update examples with new features
- Verify working with new ESP8266 core v3.0.0
- Suppress all warnings possible.
Major Release v2.6.0
- Fix breaking problem with SocketIO.
- Add setExtraHeaders function to SocketIO
- Clean possible compiler's warnings
Release v2.5.1
- Default to EIO4 for Socket.IO.
- Permit changing reconnectInterval in Socket.IO. Default is 0.5s. Set in Socket.IO examples to 10s.
- Better debug settings
Major Release v2.5.0
- Add support to SAMD_MKR1000 and SAMD_MKRWIFI1010 using WiFi101. To be used with Forked WiFi101 library
- Clean compiler's warnings
- Add examples for WiFi101
Debug Terminal
1. WT32_ETH01_WebSocketClientSocketIO on WT32_ETH01
The following are debug terminal output when running example WT32_ETH01_WebSocketClientSocketIO on WT32_ETH01
1.1 Client
Starting WT32_ETH01_WebSocketClient on ESP32_DEV with ETH_PHY_LAN8720
WebServer_WT32_ETH01 v1.1.0
WebSockets_Generic v2.8.0
ETH MAC: A8:03:2A:A1:61:73, IPv4: 192.168.2.232, FULL_DUPLEX, 100Mbps
WebSockets Client started @ IP address: 192.168.2.232
Connecting to WebSockets Server @ IP address: 192.168.2.30, port: 8080
[WS] [WS-Client] Connect ws...
[IOc] Disconnected
[WS] [WS-Client][connectedCb] Connected to Host:192.168.2.30, Port:8080
[WS] [wsIOc] Connected to url:/socket.io/?EIO=4
[IOc] Connected to url: /socket.io/?EIO=4
[WS] [wsIOc] get pong
[WS] [wsIOc] connected: len = 30
[WS] [wsIOc] data: {"sid":"cxEI-kMvZ1uKiyQ-AAAB"}
["event_name",{"now":30001}]
[WS] [wsIOc] get event: len = 53
[WS] [wsIOc] get data: ["Send Message io.emit Broadcasted : ",{"now":30001}]
[IOc] Get event: ["Send Message io.emit Broadcasted : ",{"now":30001}]
[WS] [wsIOc] get event: len = 33
[WS] [wsIOc] get data: ["Send Message : ",{"now":30001}]
[IOc] Get event: ["Send Message : ",{"now":30001}]
[WS] [wsIOc] get ping send pong:3
[WS] [WS-Client] Sending HB ping
["event_name",{"now":60002}]
[WS] [wsIOc] get data: ["Send Message io.emit Broadcasted : ",{"now":60002}]
[IOc] Get event: ["Send Message io.emit Broadcasted : ",{"now":60002}]
[WS] [wsIOc] get data: ["Send Message : ",{"now":60002}]
[IOc] Get event: ["Send Message : ",{"now":60002}]
["event_name",{"now":90003}]
[WS] [wsIOc] get data: ["Send Message io.emit Broadcasted : ",{"now":90003}]
[IOc] Get event: ["Send Message io.emit Broadcasted : ",{"now":90003}]
[WS] [wsIOc] get data: ["Send Message : ",{"now":90003}]
[IOc] Get event: ["Send Message : ",{"now":90003}]
["event_name",{"now":120004}]
[WS] [wsIOc] get event: len = 54
[WS] [wsIOc] get data: ["Send Message io.emit Broadcasted : ",{"now":120004}]
[IOc] Get event: ["Send Message io.emit Broadcasted : ",{"now":120004}]
[WS] [wsIOc] get event: len = 34
[WS] [wsIOc] get data: ["Send Message : ",{"now":120004}]
[IOc] Get event: ["Send Message : ",{"now":120004}]
1.2 Server
Using the Socket.IO Server in Nodejs_SocketIO_TestServer
kh@kh-Inspiron-3593:~/Downloads/Nodejs/New_SIO$ nodejs app
Server launched on port 8080
Connected
JWT token test: { host: '192.168.2.30:8080',
connection: 'keep-alive',
authorization: '1234567890',
'user-agent': 'arduino-WebSocket-Client' }
Message from Client : { now: 30001 }
Message from Client : { now: 60002 }
Message from Client : { now: 90003 }
Message from Client : { now: 120004 }
