How To Install Using Arduino Library Manager
Why do we need this library
Many Web services require WebSockets library , which is so far written only for ESP8266/ESP32 boards. The ESP boards rely on this Markus Sattler's WebSockets library to connect to Alexa via Sinric or SinricPro skills.
This library is based on and modified from WebSockets library to provide support to many boards such as Teensy (4.1, 4.0, 3.x, LC), Arduino SAMD21, Adafruit SAMD21/SAMD51, nRF52, STM32, etc. and enable those boards to use WebSockets services, including voice-control Alexa along with Blynk. The WebSockets can be used with ESP's WiFi, WiFiNINA, W5x00 and ENC28J60 Ethernet.
Please see illustrating examples.
New in v2.2.1
- Bump up to sync with v2.2.1 of original WebSockets library
New in v2.1.3
- Add support to nRF52 boards, such as AdaFruit Feather nRF52832, nRF52840 Express, BlueFruit Sense, Itsy-Bitsy nRF52840 Express, Metro nRF52840 Express, NINA_B30_ublox, etc..
- Add support to SAM51 (Itsy-Bitsy M4, Metro M4, Grand Central M4, Feather M4 Express, etc.).
- Add support to SAMD21 (ZERO, MKR, NANO_33_IOT, M0, M0 Pro, AdaFruit CIRCUITPLAYGROUND_EXPRESS, etc.).
- Add support to Teensy (4.1, 4.0, 3.x, LC).
- Add support to SAM DUE.
How to use
In your code, select one of the currently supported network connection from the following list:
- NETWORK_ESP8266_ASYNC for ESP8266 Async
- NETWORK_W5100 for W5x00 Ethernet
- NETWORK_ENC28J60 for ENC28J60 Ethernet
- NETWORK_ESP32 for ESP32 WiFi
- NETWORK_ESP32_ETH for ESP32 Ethernet
- NETWORK_WIFININA for WiFiNINA
then add
#define WEBSOCKETS_NETWORK_TYPE
before
#include <WebSocketsClient_Generic.h>
Example Generic_WebSocketServer_W5500
#define _WEBSOCKETS_LOGLEVEL_ 3
#define WEBSOCKETS_NETWORK_TYPE NETWORK_W5100
#include <WebSocketsServer_Generic.h>
WebSocketsServer webSocket = WebSocketsServer(81);
uint8_t mac[6] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xBE, 0x0A };
// Select the IP address according to your local network
IPAddress ip(192, 168, 2, 222);
// Only for W5100
#define SDCARD_CS 4
void webSocketEvent(uint8_t num, WStype_t type, uint8_t * payload, size_t length)
switch (type)
case WStype_DISCONNECTED:
//Serial.println( "[" + String(num) + "] Disconnected!");
case WStype_CONNECTED:
Serial.println( "[" + String(num) + "] Connected!");
//IPAddress ip = webSocket.remoteIP(num);
//Serial.printf("[%u] Connected from %d.%d.%d.%d url: %s\n", num, ip[0], ip[1], ip[2], ip[3], payload);
// send message to client
webSocket.sendTXT(num, "Connected");
case WStype_TEXT:
Serial.println( "[" + String(num) + "] get Text: " + String((char *) payload));
webSocket.sendTXT(num, "message here");
// send data to all connected clients
webSocket.broadcastTXT("message here");
case WStype_BIN:
Serial.println( "[" + String(num) + "] get binary length: " + String(length));
//hexdump(payload, length);
// webSocket.sendBIN(num, payload, length);
default:
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
// Serial.begin(921600);
while (!Serial);
Serial.println("\nStart Generic_WebSocketServer_W5500");
for (uint8_t t = 4; t > 0; t--)
Serial.println("[SETUP] BOOT WAIT " + String(t));
Serial.flush();
// start the ethernet connection and the server:
// Use Static IP
Ethernet.begin(mac, ip);
//Configure IP address via DHCP
//Ethernet.begin(mac);
// server address, port and URL
Serial.print("WebSockets Server IP address: ");
Serial.println(Ethernet.localIP());
webSocket.begin();
webSocket.onEvent(webSocketEvent);
webSocket.loop();
Debug Terminal Output when running nRF52_Blynk_W5500_Alexa
You can see the Adafruit NRF52840_FEATHER Express board, with W5500 Ethernet shield, connects to Blynk using BlynkEthernet_WM Library
It also uses WebSockets_Generic library to communicate with SINRIC skills, and Alexa, to control a relay using Alexa voice control via Amazon Alexa phone APP
Start nRF52_Blynk_W5500_Alexa using W5x00_Shield on NRF52840_FEATHER
LittleFS Flag read = 0xd0d04321
No doubleResetDetected
Saving DOUBLERESETDETECTOR_FLAG to DRD file : 0xd0d01234
Saving DRD file OK
SetFlag write = 0xd0d01234
[881] ======= Start Default Config Data =======
[881] Hdr=NonSSL,BName=Air-Control
[881] Svr=account.duckdns.org,Tok=token1
[881] Svr1=blynk-cloud.com,Tok1=<<my real Blynk auth>>
[882] Prt=8080,SIP=
[882] LoadCfgFile
[883] OK
[883] ======= Start Stored Config Data =======
[883] Hdr=W5X00,BName=Air-Control
[883] Svr=account.duckdns.org,Tok=****
[884] Svr1=blynk-cloud.com,Tok1=****
[884] Prt=8080,SIP=
[884] CCSum=0x262e,RCSum=0x262e
[886] LoadCredFile
[886] ChkCrR: Buffer allocated, sz=37
[886] ChkCrR:pdata=****,len=36
[886] ChkCrR:pdata=****,len=24
[886] OK
[887] CrCCsum=ea7,CrRCsum=ea7
[887] Buffer freed
[887] Valid Stored Dynamic Data
[889] LoadCredFile
[889] CrR:pdata=****,len=36
[889] CrR:pdata=****,len=24
[889] OK
[889] CrCCsum=ea7,CrRCsum=ea7
[890] Hdr=W5X00,BName=Air-Control
[890] Svr=account.duckdns.org,Tok=****
[890] Svr1=blynk-cloud.com,Tok1=****
[890] Prt=8080,SIP=
[890] MAC:FE-F8-E0-CB-D0-BD
_pinCS = 0
W5100 init, using SS_PIN_DEFAULT = 10, new ss_pin = 10, W5100Class::ss_pin = 10
W5100::init: W5500, SSIZE =4096
[2577] IP:192.168.2.89
[2577] bg: noConfigPortal = true
[2577] bg:ECon.TryB
[2577]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.6.1 on Arduino
[2578] BlynkArduinoClient.connect: Connecting to account.duckdns.org:8080
[2687] Ready (ping: 3ms).
[2754] Connected to Blynk Server = account.duckdns.org, Token = ****
[2754] bg:EBCon
Your stored Credentials :
SINRIC API Key = ****
Device_ID1 = ****
[WSc] Service connected to sinric.com at url: /
Waiting for commands from sinric.com ...
Stop doubleResetDetecting
Saving to DRD file : 0xd0d04321
Saving DRD file OK
ClearFlag write = 0xd0d04321
[WSc] get text: {"deviceId":"****","action":"setPowerState","value":"ON"}
Turn on for unknown device id: ****
[WSc] get text: {"deviceId":"****","action":"setPowerState","value":"OFF"}
Turn off for unknown device id: ****
[WSc] get text: {"action":"test","sender":"web"}
[WSc] received test command from sinric.com
Turn on device id: ****
Turn off Device ID: ****
