I just got all my parts together that I needed for my project and put everything together like said here: Arduino and Load cell « Cerulean but the serial monitor gives me all random outputs:
So I can't calibrate everything to even continue, what is wrong? I checked all my connections like 50 times and everything is wired up like shown in the tutorial.
First of all thank you for your answer Grumpy_Mike.
My guess is for 3) but without a photo of YOUR setup who can tell?
How would a photo of my setup help, it's on a breadboard, so on a photo you can only see jumper cables going to and from the IC, I would really like to submit something that would help to help me, but I don't really know what.
The tutorial is wrong
The tutorial seems like it's working, because a lot of people based their projects on it. (judging by some search results)
Your equipment is faulty
What should I check and how? (except the jumper cables)
3) You wired it up wrong
I compared it a lot of times and rebuild it from the start, so I am pretty sure that shouldn't be the problem.
Judging by the outputs, looks like the project is woking for you. The sketch (code) needs to be modified as the one posted is only a working sample. Thanks
I did, sorry if the schematic didn't show this - I wanted to not make it too unreadable, so I seperated the 5v and the GND from the arduino as seperate elements in multisim.
