Weight Sensor switch
Hello,
I have been working with the Audrino Uno program on a project using weight sensors that triggers a relay. I can get the relay to turn on and off just fine, but I have a problem with setting the relay to trigger at a specific weight. I want to be able to adjust this specific weight if/when I choose to do so.
I have some Force Sensitive Resistors (Square) and these can handle 100g-10kg. I am new to the coding community, but I have been doing electrical work for 40+ years, so I know how to set up the board, but I think I'm having trouble with the code I wrote.
The following is my code:
pinMode(9,OUTPUT);
int sensorValue=analogRead(A0);
float voltage=sensorValue*(5.0/1023);
Serial.println(voltage);
digitalWrite(9,HIGH);
delay(sensorValue);
if (voltage>=10.00)
//digitalWrite(9,HIGH)
pinMode(9,HIGH);
else (voltage<10.00);
digitalWrite(9,LOW);
pinMode(9,LOW);
Is there a library I need, or something else to add to my code, to specify how I want my project to turn on only when the weight reaches 10.4 lbs. (5 kg) or above?
Post a link to the sensor you're using. There are many.
Post a diagram an/or picture of how you have connected this sensor
And the value of the pull-up resistor.
Why convert to voltage. Are you making a voltmeter?
Leo..
This might work (untested).
Leo..
int sensorValue;
int offset = 75; // enter here the zero weight A/D value
float weight; // final weight
  pinMode(9, OUTPUT);
  digitalWrite(9, LOW); // assuming LOW is off
  sensorValue = analogRead(A0);
  Serial.print("A/D value is ");
  Serial.print(sensorValue);
  weight = (sensorValue - offset) * 0.02345; // weight conversion
  Serial.print("  Weight is ");
  Serial.print(weight);
  Serial.print(" lbs");
  if (weight >= 10.4) {
    digitalWrite(9, HIGH);
    Serial.println("  Relay On");
  else {
    Serial.println("  Relay OFF");
WOW!!!!! You bet it does! Can't thank you more - or can I? This is going to make this project work beautifully! Where can I send a thank you gift? I cannot believe I've worked on this so long, and you fixed it in seconds! Thank you, thank you, thank you!
I am just a hobby coder. If you spend some time with the examples that come with the IDE, you can do the same in a few weeks. Thanking people is usually done by adding a karma point.
Leo..
Oh, believe me, I've done it twice already! Thanks again!
Dear
I want to make same project
"Weight Sensor switch"
(detect / show the weight, and OFF the relay when 'n' weight)
could any body please tell me about the components required for the same.
:rajpalsinghnewdelhi@gmail.com
Thanks
Please read this, and start your own thread instead of reviving a 3 year old one.
