Weight Sensor
Hello everyone I am doing a project where I need to weigh 7 things at the same time and add the weights together the weight of each item will be between 0 and 600g I need the reading to be accurate to at worst + or – 0.5g
First question and the arduino do this
Second question if so can anyone tell me where can I get the sensors from
Thanks Dave
Scales like below might be hackable.
http://www.harborfreight.com/digital-pocket-scale-93543.html http://www.harborfreight.com/1000-gram-digital-scale-97920.html
maddave: I need to weigh 7 things at the same time
Why not just put all 7 things on the same scale?
That is a joke ??????
maddave:
Why would it be?
If you have 7 things weighing 50g, if you weigh them individually, you'll get 350g. If you weigh them together, you'll get.. 350g!
It'd only matter if you needed the individual weights - but then you could weigh each item individually, or have 7 scales and weigh each of them - but with 6 ADC inputs I'm not sure how you will weigh 7 items!
thay can not be put together
You can do soft analog on digital pins, look it up.
You could make your own scales ... there's a whole project on its own.
An Arduino Mega would give you 16 analog inputs with zero fuss. You only get 10 bit resolution with the analog reads so 600g +/- .5g is cutting it pretty close.
Here's a good example of interfacing an Arduino with a load cell: http://cerulean.dk/words/?page_id=42
zoomkat offered a few links to scales that could have their load cells removed and repurposed.
Thanks Chagrin that look like it
This one is useable
http://www.uxcell.com/01kg-weighing-load-cell-sensor-for-electronic-balance-p-126352.html
Sincerely -bino-
