Weight sorter webpage not available
I'm trying to create an automated sorter by weight with ESP32, load cell and two servos. With open code, not commercial.
I'd like to operate it via web page & determine some of the key parameters there.
Issue: webpage not accessible, port 80 closed.
The code compiles & uploads to ESP32.
It connects to WIFI & obtains IP address.
The website however is not accesible, network scanner does not even show port 80 as open. Tried looking online, asked chat gpt, all this probably helped, but did not resolve the issue.
My coding skills are very limited, I've put this code together self learning & combining some codes....over nights across last week.
Any advice is much appreciated, though if this turns out complex to fix I will likely need "spoon feeding". Still dreaming it only requires a simple fix...
#include <ESP32Servo.h>
#include <ESPAsyncWebServer.h>
#include <HX711.h>
#include <WiFi.h>
#include <AsyncTCP.h>
// Define pins for HX711 and servos
#define DOUT_PIN 23
#define CLK_PIN 22
// Create an instance of the HX711 class for the load cell
HX711 scale;
// Initialize variables for weight ranges and item counts
float range1_min = 0;
float range1_max = 0;
float range2_min = 0;
float range2_max = 0;
float range3_min = 0;
float range3_max = 0;
int count_range1 = 0;
int count_range2 = 0;
int count_range3 = 0;
int sorting = 0;
int reset = 0;
unsigned long previousMillis = 0; // variable to store last update time
const long interval = 200; // update interval in milliseconds
Servo myservo1;
Servo myservo2;
const int SERVO1_PIN = 26;
const int SERVO2_PIN = 27;
//const int BUTTON_PIN = 39;
// Replace with your network credentials
const char* ssid = "your SSID";
const char* password = "your PASSWORD";
// Set initial weight ranges
  range1_min = 0;
  range1_max = 33.33;
  range2_min = 33.34;
  range2_max = 66.67;
  range3_min = 66.68;
  range3_max = 100;
  scale.begin(DOUT_PIN, CLK_PIN);
 // Connect to Wi-Fi
  WiFi.begin(ssid, password);
    Serial.println("Connecting to WiFi..");
  // Initialize servos
  myservo1.attach(SERVO1_PIN);
  myservo2.attach(SERVO2_PIN);
  // Initialize scale and set calibration factor
  scale.set_scale();
  scale.tare();
  scale.set_scale(2280.0);
// Initialize web server
AsyncWebServer server(80);
server.on("/", HTTP_GET, handleRoot);
server.begin();
void handleRoot(AsyncWebServerRequest *request) {
  String html = "<html><body><h1>Weight Sorting Machine</h1>";
  html += "<h1>Weight: %d g</h1><form method='post'>";
  html += "<p>Weight Ranges:</p>";
  html += "<form method='post' action='/ranges'>";
  html += "<label>Range 1: </label>";
  html += "<input type='text' name='range1_min' value='" + String(range1_min) + "' placeholder='min'>";
  html += "<input type='text' name='range1_max' value='" + String(range1_max) + "' placeholder='max'><br>";
  html += "<label>Range 2: </label>";
  html += "<input type='text' name='range2_min' value='" + String(range2_min) + "' placeholder='min'>";
  html += "<input type='text' name='range2_max' value='" + String(range2_max) + "' placeholder='max'><br>";
  html += "<label>Range 3: </label>";
  html += "<input type='text' name='range3_min' value='" + String(range3_min) + "' placeholder='min'>";
  html += "<input type='text' name='range3_max' value='" + String(range3_max) + "' placeholder='max'><br>";
  html += "<input type='submit' name='save_ranges' value='Save'>";
  html += "</form>";
  html += "<p>Counts:</p>";
  html += "<p>Range 1: " + String(count_range1) + "</p>";
  html += "<p>Range 2: " + String(count_range2) + "</p>";
  html += "<p>Range 3: " + String(count_range3) + "</p>";
  html += "<form method='post' action='/reset'>";
  html += "<input type='submit' name='reset' value='Reset'>";
  html += "</form>";
  html += "<form method='post' action='/calibrate'>";
  html += "<input type='submit' name='calibrate' value='Calibrate'>";
  html += "</form>";
  html += "<form method='post' action='/start'>";
  html += "<input type='submit' name='start' value='Start Sorting'>";
  html += "</form>";
  html += "<form method='post' action='/stop'>";
  html += "<input type='submit' name='stop' value='Stop Sorting'>";
  html += "</form>";
  html += "</body></html>";
  char buf[256];
  unsigned long currentMillis = millis(); // get the current time
  if (currentMillis - previousMillis >= interval) { // if the update interval has passed
    previousMillis = currentMillis; // save the current time
    int weight = scale.get_units();
    String html_with_weight = html;
    html_with_weight.replace("%d", String(weight));
    strcpy(buf, html_with_weight.c_str());
    request->send(200, "text/html", buf);
  } else { // if the update interval has not passed yet
    strcpy(buf, html.c_str()); // send the same HTML as before
    request->send(200, "text/html", buf);}
    if (request->hasParam("start")) {
     sorting = 1;
     return;
   if (request->hasParam("stop")) {
     sorting = 0;
     return;
   if (request->hasParam("reset")) {
     reset = 1;
     return;
  // Wait for button press to start sorting
  while (reset == 1) {
    delay(100);
  // Reset item counts
  count_range1 = 0;
  count_range2 = 0;
  count_range3 = 0;
  reset = 0;
  // Sort items until button is released
  while (sorting == 1) {
    // Move servo1 to load item
    myservo1.write(90);
    delay(300);
     myservo1.write(80);
    // Read weight and assign to range
    float weight = scale.get_units(5);
    Serial.print("Weight: ");
    Serial.println(weight);
    if (weight >= range1_min && weight <= range1_max) {
     myservo2.write(0);
      count_range1++;
    } else if (weight >= range2_min && weight <= range2_max) {
      myservo2.write(90);
      count_range2++;
    } else if (weight >= range3_min && weight <= range3_max) {
      myservo2.write(180);
      count_range3++;
    // Wait for item to be removed
   myservo1.write(180);
  // Move servos to starting position
  myservo1.write(0);
  myservo2.write(0);
// Handle weight range update request
void handleRanges(AsyncWebServerRequest *request) {
  range1_min = request->getParam("range1_min")->value().toFloat();
  range1_max = request->getParam("range1_max")->value().toFloat();
  range2_min = request->getParam("range2_min")->value().toFloat();
  range2_max = request->getParam("range2_max")->value().toFloat();
  range3_min = request->getParam("range3_min")->value().toFloat();
  range3_max = request->getParam("range3_max")->value().toFloat();
  request->redirect("/");
You have declared this object inside setup(), so it's local to setup() and as soon as setup() ends, the object no longer exists.
Thank you, I have moved it out of setup(). Still no luck.
#include <HX711.h>
#include <WiFi.h>
#define DOUT_PIN 23
#define CLK_PIN 22
HX711 scale;
int sorting = 0;
int reset = 0;
Servo myservo1;
Servo myservo2;
const char* ssid = "sys-kingdom";
const char* password = "Malachwieje12";
  range1_min = 0;
  range1_max = 33.33;
  range2_min = 33.34;
  range2_max = 66.67;
  range3_min = 66.68;
  range3_max = 100;
 // Connect to Wi-Fi
  scale.set_scale();
  scale.tare();
  html += "</form>";
  html += "</form>";
  html += "</form>";
  html += "</form>";
  html += "</form>";
  char buf[256];
     sorting = 1;
     return;
     sorting = 0;
     return;
     reset = 1;
     return;
server.begin();
    delay(100);
  count_range1 = 0;
  count_range2 = 0;
  count_range3 = 0;
  reset = 0;
    myservo1.write(90);
    delay(300);
     myservo1.write(80);
     myservo2.write(0);
      count_range1++;
      myservo2.write(90);
      count_range2++;
      count_range3++;
  myservo1.write(0);
  myservo2.write(0);
Stop relying on luck. Randomly moving lines of code you don't understand the purpose of, to other random places in your code, is extremely unlikely to work. I would be wasting my time trying to help you if you keep doing that.
Go back to the first version of the code you posted and make the change I suggested again. But this time don't make any other random changes!
Apologies @PaulRB, it works like a charm. I got winded up in search of the solution & have not kept versions properly.
Big thank you!
Any way I can get you a thank you bear, juice or whatever it is that you are drinking?
Good to hear that. I wasn't sure if my suggested change would be enough to fix the original problem, or if other corrections would also be needed. But when I saw the second version, I could see that you had fixed one problem and introduced another problem, which is why I might have sounded a little frustrated.
Thanks for the offer of a bear, but I find them a little too large to swallow :wink:
