Weird Behaviour with BearSSL on GPIO ESP8266
I use GPIO 5 to trigger a relay, my code also connects with a secure MQTT connection for which I have to use the BearSSL certificate definitions.
Without the BearSSL certificates, when the esp restarts it does not re-trigger the relay, and the GPIO maintains its' state between reboots, but when I use the bearSSL certificates the behavior changes, and GPIO 5 goes low on restart. Any explanation why and how to mitigate it?
I am 100% sure it is because of the import, cause I removed components of my code until I could find the piece of code that causes this, and it was because of the declarations.
#include <WiFiClientSecure.h>
static const char AWS_CERT_CA[] PROGMEM = R"EOF(
aws root)EOF";
static const char AWS_CERT_CRT[] PROGMEM = R"KEY(
device cert)KEY";
static const char AWS_CERT_KEY[] PROGMEM = R"KEY(
device key )KEY";
BearSSL::X509List cert(AWS_CERT_CA);
BearSSL::X509List client_crt(AWS_CERT_CRT);
BearSSL::PrivateKey key(AWS_CERT_KEY);
WiFiClientSecure espClient;
  pinMode(5, OUTPUT);
  delay(2000);
  digitalWrite(5, HIGH);
  delay(2000);
  ESP.restart();
void loop() {}
Without the following three lines
The LED on GPIO 5 does not flicker on restarts but adding these lines makes them flicker. Any solution or suggestion towards a solution for this problem will be really helpful.
What worked for me was to move the BearSSL declaration and usage after the pinMode setting of the GPIO. So I had to make the certificate and keys local variables and wrap the entire setting up of wifi, conneting to it, setting up and connecting to the AWS core in a single function.
void setupWiFiAndConnectAWS() {
  WiFi.persistent(false);
  DEBUG_MSG("[setupWiFi] Setting host name\n");
  WiFi.hostname(deviceId);
  DEBUG_MSG("[setupWiFi] Setting station mode\n");
  WiFi.mode(WIFI_STA);
  if (WiFi.getMode() & WIFI_AP) {
    WiFi.softAPdisconnect(true);
  DEBUG_MSG("[setupWiFi] Loading certificates\n");
  net.setTrustAnchors(&cert);
  net.setClientRSACert(&client_crt, &key);
  loadCredentials();
  connectWiFi();
  attachInputInterrupts(false);
  setupNTP();
  connectAWS();
after setting up the GPIO pins.
Although this is a work around, i still don't understand the core problem, and would like to understand it, that is why I am keeping the issue open for now
