Weird characters after AT command is sent
Hello guys!
Wanted to ask you why are some random characters printed out when I send AT command via serial using this code.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(8,9); // RX, TX
  mySerial.begin(9600);
  if (mySerial.available())
    Serial.write(mySerial.read());
  if (Serial.available())
    while(Serial.available())
      mySerial.write(Serial.read());
    mySerial.println();
and this is the response after the module is up and running and I write simply AT to the monitor
What could be the issue? I got similar problems on my other project when I was sending AT commands through code.
To what device are you sending AT commands?
Is 9600 the correct baud rate?
It is BC68 TE-B from Quectel and I think it was written in the documentation that the basic baud rate is 9600.
You are only reading one character in per loop. Try...
  while (mySerial.available())
Oh this works. I am such a dumbass. Thank you for your help!
