weird compiler optimization behavior / bug
this is from the french forum discussion - brought by @bidouilleelec and worth additional eyeballs looking at it for what is either a super aggressive supposedly "dead loop" / "dead code" removal optimization or a compiler bug.
(tested with 1.8.5 / avr-gcc/4.9.2-atmel3.5.4)
the conversation iterated over a few codes, and @bricoleau proposed a simplified version of the code showing the weird behavior. here it is
int n = 1;
  Serial.println(F("STARTING"));
  if ( n <= 3 ) {
    boolean r = false;
    while ( !r ) {
      if (Serial.available()) r = (Serial.read() == 'c' );
    Serial.println(n);
    n++;
  } else while (1);
you could argue that the active wait on Serial or dead loop to stop the program in the loop at the end are "ugly" but that's not the point, this is a legit programming construct.
The code as it is should basically greet you with "STARTING" and every time you enter 'c' in the Serial console display the value of n and increase it. Once n reaches 4 the code should go into the infinite else while (1); loop and be stuck there.
And guess what, when you run it and type 'c' a number of times, the code never goes into the infinite loop.
Now if you modify the code to make the boolean r volatile
int n = 1;
  if ( n <= 3 ) {
    volatile boolean r = false; // ONLY CHANGE IS r BEING VOLATILE
    while ( !r ) {
    Serial.println(n);
    n++;
  } else while (1);
then the optimizer cannot make the same assumptions and compiler behaves differently and this time the code does go and get stuck into the infinite loop as expected.
In the french discussion some members looked at the generated binary and it turns out that in the non working version the compiler seems to have removed entirely the   if ( n <= 3 ) { and } else while (1); parts, leading to the unwanted behavior.
Keeping the code the same and changing the optimizer parameter in the compilation also lead to expected behavior.
So - what do you think is going on there? why would it be legit in that case for the optimizer to get rid of part of the code?
Behavior confirmed on 1.8.5 and Arduino UNO.
Any idea why? it just does not seem to make sense to me how the optimizer could assume the test against n <=3 is useless... (or does it assume printing and user input would be useless?)
J-M-L:
The optimizer has no clue whether code is printing or fetching user input - it see the code at a MUCH lower level, and judges only based on the side-effects of running the code, or not.
Regards,
Ray L.
What happens if you make r static? Global?
RayLivingston:
Regards,
Ray L.
Yes I'm actually familiar with how this works and many of the optimization techniques - but this one makes no sense so wondering if there is a "Voodoo level" that I don't know about which reads code intents :slight_smile:
PaulS:
Subtle changes to r or elsewhere would lead to code working as expected or not. for example making it static or global
int n = 1;
boolean r;
  if ( n <= 3 ) {
    r = false;
    while ( !r ) {
    Serial.println(n);
    n++;
  } else while (1);
then code will behave as expected
but keeping it on the stack and adding another statement within the test will also make the code work as expected, for example this works
int n = 1;
  if ( n <= 3 ) {
    boolean r = false;
    Serial.println("Can a print change the world?");
    while ( !r ) {
    Serial.println(n);
    n++;
  } else while (1);
Given critical pieces of codes do disappear at assembly level, it's feels like a very aggressive optimization decision
arduino-1.8.4 ( arduino.avr-gcc=4.9.2-atmel3.5.4-arduino2 ) on linux.
Does NOT exhibit the problem. Works as expected on UNO.
STARTING
1
2
3
J-M-L:
tf68:
(emphasis added)
That makes the difference a compile / link switch. Both of you: please turn on verbose build then post the results so we can diff.
(Or the Arduino built toolset is flawed.)
Speaking of optimizer trouble, apparently the compiler is no longer optimizing bit shifts...
http://forum.arduino.cc/index.php?topic=554341.msg3780479#msg3780479
Friend, either you're closing your eyes
To a situation you do not wish to acknowledge
Or you are not aware of the caliber of disaster indicated
By the presence of a compile bug in your community . Well, ya got trouble, my friend, right here,
I say, trouble right here in Arduino City.
(apologies to Meredith Willson)
Indeed I had missed the arduino2 in my copy and paste.
avr-gcc/4.9.2-atmel3.5.4-arduino2 on a Mac
</sub> <sub>Compiling sketch... "/Users/jeanmarc/Library/Arduino15/packages/arduino/tools/[color=red]avr-gcc/4.9.2-atmel3.5.4-arduino2[/color]/bin/avr-g++" -c -g [color=red]-Os[/color] -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-I/Users/jeanmarc/Library/Arduino15/packages/arduino/hardware/avr/1.6.21/cores/arduino" "-I/Users/jeanmarc/Library/Arduino15/packages/arduino/hardware/avr/1.6.21/variants/standard" "/var/folders/xk/mwl4yt3j5rsgdmgmgjlqsk7w0000gn/T/arduino_build_74986/sketch/sketch_jul05a.ino.cpp" -o "/var/folders/xk/mwl4yt3j5rsgdmgmgjlqsk7w0000gn/T/arduino_build_74986/sketch/sketch_jul05a.ino.cpp.o" Compiling libraries... Compiling core... Using precompiled core Linking everything together... "/Users/jeanmarc/Library/Arduino15/packages/arduino/tools/[color=red]avr-gcc/4.9.2-atmel3.5.4-arduino2[/color]/bin/avr-gcc" -Wall -Wextra [color=red]-Os[/color] -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p  -o "/var/folders/xk/mwl4yt3j5rsgdmgmgjlqsk7w0000gn/T/arduino_build_74986/sketch_jul05a.ino.elf" "/var/folders/xk/mwl4yt3j5rsgdmgmgjlqsk7w0000gn/T/arduino_build_74986/sketch/sketch_jul05a.ino.cpp.o" "/var/folders/xk/mwl4yt3j5rsgdmgmgjlqsk7w0000gn/T/arduino_build_74986/../arduino_cache_261545/core/core_arduino_avr_uno_326b060ef0db883205dbc87760fa0a68.a" "-L/var/folders/xk/mwl4yt3j5rsgdmgmgjlqsk7w0000gn/T/arduino_build_74986" -lm</sub> <sub>
All the more reason to... please turn on verbose build then post the results so we can difference.
interesting to see the bug is not there in 1.8.4 and may be not same flags?
tf68:
STARTING
1
2
3
just to be sure, you tried typing more 'c' in the Serial monitors right?
Still - it's weird that on the same platform/machine/context with same compile flags, adding a Serial.print() in the if () {...} section totally changes the behavior....
Here is an edited compiler output. And yes I used lots of cccccccccccccccc.
Compiling sketch...
"/home/terry/bin/arduino-1.8.4/hardware/tools/avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10804 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-I/home/terry/bin/arduino-1.8.4/hardware/arduino/avr/cores/arduino" "-I/home/terry/bin/arduino-1.8.4/hardware/arduino/avr/variants/standard" "/tmp/arduino_build_46171/sketch/compilerBugTest.ino.cpp" -o "/tmp/arduino_build_46171/sketch/compilerBugTest.ino.cpp.o"
Compiling core...
"/home/terry/bin/arduino-1.8.4/hardware/tools/avr/bin/avr-gcc" -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p  -o "/tmp/arduino_build_46171/compilerBugTest.ino.elf" "/tmp/arduino_build_46171/sketch/compilerBugTest.ino.cpp.o" "/tmp/arduino_build_46171/../arduino_cache_987557/core/core_arduino_avr_uno_3e8997973f924952b582441c1fc61698.a" "-L/tmp/arduino_build_46171" -lm
"/home/terry/bin/arduino-1.8.4/hardware/tools/avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0  "/tmp/arduino_build_46171/compilerBugTest.ino.elf" "/tmp/arduino_build_46171/compilerBugTest.ino.eep"
"/home/terry/bin/arduino-1.8.4/hardware/tools/avr/bin/avr-objcopy" -O ihex -R .eeprom  "/tmp/arduino_build_46171/compilerBugTest.ino.elf" "/tmp/arduino_build_46171/compilerBugTest.ino.hex"
Sketch uses 1794 bytes (5%) of program storage space. Maximum is 32256 bytes.
Global variables use 190 bytes (9%) of dynamic memory, leaving 1858 bytes for local variables. Maximum is 2048 bytes.
Do I think right if I say the toolchain on macOS and Linux are the same anyway (very similar UNIX under the hood)
So if you are with arduino.avr-gcc=4.9.2-atmel3.5.4-arduino2 (on linux) this seems the same version for OS X although not the same version of Arduino IDE and I see no meaningful difference for the compilation flags
avr-gcc/4.9.2-atmel3.5.4-arduino2/bin/avr-g++"  -c -g -Os -Wall -Wextra -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10805 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR
nor at link time
avr-gcc/4.9.2-atmel3.5.4-arduino2/bin/avr-gcc" -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p  -o
I downloaded IDE 1.8.5
arduino-1.8.5 ( arduino.avr-gcc=4.9.2-atmel3.5.4-arduino2 ) on linux.
Does exhibit the same problem that JML reported.
STARTING
1
2
3
4
5
6
7
8
9
10
Just for grins I swapped tools folders between IDE-1.8.4 and IDE-1.8.5.
Using IDE-1.8.5 with tools from IDE-1.8.4 your test program fails.
Using IDE-1.8.4 with tools from IDE-1.8.5 your test program works as expected.
Just to stir the pot, remove loop
int n = 1;
    while(1)
        if ( n <= 3 ) {
            boolean r = false;
            while ( !r ) {
            Serial.println(n);
            n++;
        } else while (1);
works fine 1.8.5/4.9.2
tf68:
LOL the plot thickens!!
Yeah, if you turn off lto ( link time optimization ) it works in 1.8.5.
Also DKWatson's sketch will only compile with lto on.
As far as I can tell the build scripts are essentially identical between 1.8.5 and 1.8.3 (presumably also between 1.8.5 and 1.8.4). Is that what everyone else is seeing?
The only notable difference was -w versus -Wall.
