Weird damage in my 12V Plug
Hi there, hope everyone is having a nice day! I have an issue where a 12V plug exploded and I have no idea why it happened or how to prevent this. Anybody have an idea?
A couple of weeks ago I built an automated greenhouse, in which I invested a lot of time and money. It was using 2 arduinos in order measure and display soil moisture, air humity and temperature, and automatically controlled 3 fans and a water pump in order to create a good environment for the plants.
The plug that I am talking about was powering 3 fans and a waterpump, which all required 12Volt. Each of those was connected to a switch relay as well. One day (after a couple of weeks being turned on) I smelt something burned and then heard a pop, and then realized that the plug had sprung open. It looked pretty dangerous, and I am afraid to power it again which might start a fire.
The plug was connected to a multiplug, next to a normal lamp and the arduinos. I attached a screenshot of how it looks now in the inside.
Does anybody have an idea what lead to this? I would really like to continue working with stuff like this, but am too afraid that something worse happens.
How old was it?
If your fans and or pump do not have flyback diodes across the terminals, then high voltages could have been generated across the 12V output causing that capacitor to explode
Perhaps something better quality, a reputable distributor.
What's the total current requirement? Your power supply is rated for 2 Amps. (That's the maximum allowed.)
It's a good idea to have some safety margin, and motors "pull" additional current during start-up. (It's probably best if everything doesn't start-up at the same time.)
It's probably dead. It has A CE rating (if you believe it) so it shouldn't actually start a fire when/if it's overloaded and burns-out. But that's not a guarantee from me! :wink: And you can't sue a Chinese company.
