Hello!
I have a program where I want to randomly pick a number between 0 - 11 and turn on an LED attached to that pin. Subsequently I want to pick another pin, check that isn't already picked and turn on that LED. This is repeated until 11 of 12 pins are on. If a random selection is already chosen, it keeps picking a random number until if finds one not used.
It almost works but it has a weird problem. See results file below:
TLC5974 test
7,10,8,0,11,9,6,2,7,4,5 Note: two 7s
4,11,3,10,9,7,1,0,5,8,2
9,8,2,5,1,4,7,6,3,11,10
2,7,4,1,9,8,5,0,3,6,10
0,7,4,9,6,8,11,2,5,10,1
7,6,5,4,1,10,9,2,0,11,3
5,6,2,9,10,8,1,4,3,11,0
3,9,7,11,2,4,1,8,5,6,0
2,9,7,6,8,3,1,5,11,0,4
11,5,8,0,3,1,9,6,11,10,2 Note: two 11s
5,11,3,8,1,2,7,4,10,9,6
7,8,9,11,10,3,0,6,4,2,5
8,2,4,1,7,9,11,6,5,0,10
0,1,10,6,9,7,2,5,0,11,3 Note: two 0s
Most of the text above was generated by the program; the '>' and notes are my edits to highlight the problem. Here is the code:
This program attempts to solve the call a random number multiple times problem
#include "Adafruit_TLC5947.h"
// How many boards do you have chained?
#define NUM_TLC5974 2
#define data 4
#define clock 5
#define latch 6
#define oe -1 // set to -1 to not use the enable pin (its optional)
Adafruit_TLC5947 tlc = Adafruit_TLC5947(NUM_TLC5974, clock, data, latch);
int i;
int j;
int k;
int l;
Serial.println("TLC5974 test");
tlc.begin();
if (oe >= 0) {
pinMode(oe, OUTPUT);
digitalWrite(oe, LOW);
// Set all pins to off
for(uint16_t i=0; i<12; i++) {
tlc.setLED(i,0, 0, 0);
tlc.write();
// This code section simply turns on all RGB LEDs to ensure all are white. This is to rule out an electrical problem.
tlc.setLED(0,500,500,500);
tlc.setLED(1,500,500,500);
tlc.setLED(2,500,500,500);
tlc.setLED(3,500,500,500);
tlc.setLED(4,500,500,500);
tlc.setLED(5,500,500,500);
tlc.setLED(6,500,500,500);
tlc.setLED(7,500,500,500);
tlc.setLED(8,500,500,500);
tlc.setLED(9,500,500,500);
tlc.setLED(10,500,500,500);
tlc.setLED(11,500,500,500);
tlc.write();
int sel;
int sel1;
int sel2;
int sel3;
int sel4;
int sel5;
int sel6;
int sel7;
int sel8;
int sel9;
int sel10;
int sel11;
int cond;
int tim; // delay time
tim =2000;
randomSeed(analogRead(A0));
sel = random(12);
Serial.print(sel);
Serial.print(",");
tlc.setLED(sel,0,0,1000);
tlc.write();
delay(tim);
do {
sel1 = random(12);
} while (sel1 == sel);
Serial.print(sel1);
Serial.print(",");
tlc.setLED(sel1,0,0,1000);
tlc.write();
delay(tim);
do {
sel2 = random(12);
} while ((sel2 == sel1) || (sel2 == sel));
Serial.print(sel2);
Serial.print(",");
tlc.setLED(sel2,1000,0,0);
tlc.write();
delay(tim);
do {
sel3 = random(12);
} while ((sel3 == sel2) || (sel3 == sel1) || (sel3 == sel));
Serial.print(sel3);
Serial.print(",");
tlc.setLED(sel3,1000,0,0);
tlc.write();
delay(tim);
do {
sel4 = random(12);
} while ((sel4 == sel3) || (sel4 == sel2) || (sel4 == sel1) || (sel4 == sel));
Serial.print(sel4);
Serial.print(",");
tlc.setLED(sel4,0,1000,0);
tlc.write();
delay(tim);
do {
sel5 = random(12);
} while ((sel5 == sel4) || (sel5 == sel3) || (sel5 == sel2) || (sel5 == sel1) || (sel5 == sel));
Serial.print(sel5);
Serial.print(",");
tlc.setLED(sel5,0,1000,0);
tlc.write();
delay(tim);
do {
sel6 = random(12);
} while ((sel6 == sel5) || (sel6 == sel4) || (sel6 == sel3) || (sel6 == sel2) || (sel6 == sel1) || (sel6 == sel));
Serial.print(sel6);
Serial.print(",");
tlc.setLED(sel6,1800,1000,0);
tlc.write();
delay(tim);
do {
sel7 = random(12);
} while ((sel7 == sel6) || (sel7 == sel5) || (sel7 == sel4) || (sel7 == sel3) || (sel7 == sel2) || (sel7 == sel1) || (sel7 == sel));
Serial.print(sel7);
Serial.print(",");
tlc.setLED(sel7,1800,1000,0);
tlc.write();
delay(tim);
do {
sel8 = random(12);
} while ((sel8 == sel7) || (sel8 == sel6) || (sel8 == sel5) || (sel8 == sel4) || (sel8 == sel3) || (sel8 == sel2) || (sel8 == sel1) || (sel5 == sel));
Serial.print(sel8);
Serial.print(",");
tlc.setLED(sel8,1800,1000,0);
tlc.write();
delay(tim);
do {
sel9 = random(12);
} while ((sel9 == sel8) || (sel9 == sel7) || (sel9 == sel6) || (sel9 == sel5) || (sel9 == sel4) || (sel9 == sel3) || (sel9 == sel2) || (sel9 == sel1) || (sel9 == sel));
Serial.print(sel9);
Serial.print(",");
tlc.setLED(sel9,1000,0,1000);
tlc.write();
delay(tim);
do {
sel10 = random(12);
} while ((sel10 == sel9) || (sel10 == sel8) || (sel10 == sel7) || (sel10 == sel6) || (sel10 == sel5) || (sel10 == sel4) || (sel10 == sel3) || (sel10 == sel2) || (sel10 == sel1) || (sel10 == sel));
Serial.println(sel10);
// Serial.print(",");
tlc.setLED(sel10,1000,0,1000);
tlc.write();
delay(tim);
// delay(100000000);
//do {
// sel11 = random(12);
// } while ((sel11 == sel10) || (sel11 == sel9) || (sel11 == sel8) || (sel10 == sel7) || (sel11 == sel6) || (sel11 == sel5) || (sel11 == sel4) || (sel11 == sel3) || (sel11 == sel2) || (sel11 == sel1) || (sel11 == sel));
// tlc.setLED(sel11,1000,0,1000);
// tlc.write();
// delay(tim);
// int tim; // delay time in each fade loop
// tim =2000;
// Turns pin to red; red max = 2950,0,0
// tlc.setLED(sel,0,0,1000);
// tlc.setLED(sel1,0,0,1000);
// tlc.setLED(sel2,1000,0,0);
// tlc.setLED(sel3,1000,0,0);
// tlc.setLED(sel4,0,1000,0);
// tlc.setLED(sel5,0,1000,0);
// tlc.setLED(sel6,1800,1000,0);
// tlc.setLED(sel7,1800,1000,0);
// tlc.setLED(sel8,1800,1000,0);
// tlc.setLED(sel9,1000,0,1000);
// tlc.setLED(sel10,1000,0,1000);
// tlc.write();
// delay(tim);
Does anyone have a clue what is causing this problem?
Thanks!
Peter
