Hi All, Very new to coding so please bare with me
My previous UNO died, doesn’t respond to a loop test.
New board
BN: Unknown board
VID: 1A86
PID: 7523
SN: Upload any sketch to obtain it
I obtained the drivers and can successfully upload the Blink Sketch. When I go to upload my Fastled related stuff I get this error:
Warning: platform.txt from core ‘Arduino AVR Boards’ contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} “{build.path}/{archive_file}” “{object_file}”, automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} “{archive_file_path}” “{object_file}”. Consider upgrading this core.
In file included from D:\I\Arduino projects\Arduino Backup\USETHISFORHORNS\USETHISFORHORNS.ino:1:0:
D:\I\Arduino projects\arduino-1.8.7 RUN FROM HERE\libraries\FastLED-3.1.8/FastLED.h:17:21: note: #pragma message: FastLED version 3.001.008
pragma message “FastLED version 3.001.008”
D:\I\Arduino projects\arduino-1.8.7 RUN FROM HERE\libraries\FastLED-3.1.8\FastLED.cpp: In member function ‘void CFastLED::delay(long unsigned int)’:
D:\I\Arduino projects\arduino-1.8.7 RUN FROM HERE\libraries\FastLED-3.1.8\FastLED.cpp:132:9: error: ‘yield’ was not declared in this scope
yield();
exit status 1
Error compiling for board WAVGAT UNO R3.
Quick google on the error just confused me more
I am running Arduino 1.8.7 with FastLED-3.1.8 (Also tried the latest version, same error)
Any ideas where to start?
#include "FastLED.h"
#define NUM_LEDS 3
#define LED_PIN 6
CRGB leds[NUM_LEDS];
randomSeed(analogRead(0));
FastLED.addLeds<WS2812, LED_PIN, GRB>(leds, NUM_LEDS);
int8_t H = random(0,50); //HUE
int8_t S = random(60,256); //SAT
int8_t V = random(200,256); //BRIGHT
//middle horn
leds[1] = CHSV(H,S,V);
FastLED.show();
// below for edge horns to be same
S = random(150,256); //SAT
V = random(180,230); //BRIGHT
leds[0] = CHSV(H,S,V);
leds[2] = CHSV(H,S,V);
FastLED.show();
//makes white run quicker
if ((H <= 30) && (S >= 0 && S <= 200) && (V <= 200))
// white
delay(1);
// not white
delay(70);
Thank you.
