I have an I2C LCD and a Keyboard and was trying to make a Time input system.
It works great until I press '*' for deleting and start introducing time again. After that, it still works BUT when I press the '1' key it's detected as a '0'. This is all the code I have. And as it works until I erase Time, I'm guessing it's not a wiring problem. After all my Arduino has been connected for a while without experiencing troubles in other projects.
//INCLUDES
#include <Keypad.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x3F,16,2); // set the LCD address to 0x27 for a 16 chars and 2 line display
//La dirección de mi pantalla no es 0x27, es 0x3F
char Tiempo[9] = {'0', '0', ':', '0', '0', ':', '0', '0'};
boolean configurada = false;
const byte ROWS = 4; //four rows
const byte COLS = 4; //three columns
char keys[ROWS][COLS] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
byte colPins[COLS] = {5, 4, 3, 2}; //connect to the row pinouts of the keypad
byte rowPins[ROWS] = {9, 8, 7, 6}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
lcd.init();
lcd.blink();
lcd.backlight();
lcd.setCursor(0,0);
lcd.print("*Borrar #OK");
//Serial.println("Introduzca horas y pulse #. * para borrar");
lcd.setCursor(0,1);
lcd.print("00:00:00");
lcd.setCursor(0,1);
int cursorpos = 0;
while (configurada == false){
char key = keypad.getKey();
if ((key != NO_KEY) && (key != '*')&&(key != '#') && (key <= '9') && (key >= '0')){
Serial.println(key);
lcd.print(key);
Tiempo[cursorpos] = key;
switch(cursorpos){ //00:00:00 -> indexes 01 2 34 5 67
case 1:
cursorpos = 3;
case 4: cursorpos = 6; break;
case 7: ;break;
default: cursorpos++; break;
if ((key != NO_KEY) && (key == '*')){
Serial.println("WTF?!");
cursorpos = 0;
lcd.setCursor(0,1);
Tiempo[9] = '00:00:00';
if ((key != NO_KEY) && (key == '#')){
Serial.println(Tiempo);
lcd.setCursor(cursorpos,1);
delay(200);
