So, I have this strange led display that I scavenged from an old radio.
It has seven pins, each of which acts as both a positive and a ground. For example, whenever I put power on the first pin and ground on the second pin, it lights up the top segment of one of the 7 segment displays.
But then, I need to use the first pin as ground and the second pin as positive (aka, swapped roles) to get a different segment on one of the 7-segs.
My question is: how do I program my arduino uno to switch an output pin to ground, and vice versa? Thanks ahead of time.
digitalWrite(pin, LOW);
Do not attempt to have the pin "sink" or source more than about 20 mA, and be sure use current limiting resistors for the display segments.
is that what low does?
Im such a dummy. Ok, thanks!
(Ominous music plays) I don't have enough resisters ![]()
digitalWrite(pin, LOW) is essentially "ground" and digitalWrite (pin, HIGH) will be about 5V
I actually have a new question how do I use four resistors to separately power seven pins
You put them together for one night in the dark and next morning you check if they have any babies..
that's actually crazy Ill try that thanks a bunch
