first of all, this is my code:
#include <SoftwareSerial.h>
#include <avr/sleep.h>
# define interruptPin 2
int time_stayreading=0;
Serial.begin(19200);
wakeUp();
Serial.println("POWER ON");
int buttonstate=digitalRead(interruptPin);
bool stayreading=true;
Serial.println(buttonstate);
while(stayreading==true){
if(millis() - time_stayreading > 50){
time_stayreading = millis();
stayreading=false;
Serial.println("POWER OFF");
delay(50);
sleep();
void sleep(){
sleep_enable();
EIFR = bit (INTF0);
attachInterrupt(0, wakeUp, FALLING);
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
sleep_cpu();
void wakeUp(){
sleep_disable();
detachInterrupt(0);
On Pin 2 I got a Microswitch that puts +5V on the Pin when it is pushed, I got Pin 2connected to ground with a 120kOhm resistor to denoise it (is this the correct term?). I want to achieve a sleeping arduino that wakes up on a button push and is able to stay awake as long as the button is pushed. I tried this using a while loop that is triggered by the button state - but as you see from the output below (I kept pushing the button again and again) this is nothing but a random number generator in the best case.
11:40:55.715 -> POWER OFF
11:40:58.393 -> POWER ON
11:40:58.393 -> 0
11:40:58.393 -> 0
11:40:58.393 -> POWER OFF
11:40:59.202 -> POWER ON
11:40:59.202 -> 0
11:40:59.235 -> 0
11:40:59.235 -> POWER OFF
11:40:59.609 -> POWER ON
11:40:59.644 -> 1
11:40:59.644 -> 1
11:40:59.644 -> POWER OFF
11:41:00.017 -> POWER ON
11:41:00.017 -> 0
11:41:00.017 -> 0
11:41:00.017 -> POWER OFF
11:41:01.160 -> POWER ON
11:41:01.160 -> 0
11:41:01.160 -> 0
11:41:01.160 -> POWER OFF
11:41:01.261 -> POWER ON
11:41:01.261 -> 1
11:41:01.261 -> 1
11:41:01.261 -> 1
11:41:01.261 -> POWER OFF
11:41:01.464 -> POWER ON
11:41:01.464 -> 0
11:41:01.464 -> 0
11:41:01.464 -> 0
11:41:01.464 -> 0
11:41:01.464 -> POWER OFF
11:41:01.599 -> POWER ON
11:41:01.599 -> 0
11:41:01.633 -> 0
11:41:01.633 -> 0
11:41:01.633 -> 0
11:41:01.633 -> 0
11:41:01.633 -> POWER OFF
What did I do wrong? This seems like a very common usecase for me, but I did not really know what to search for, I'm sorry. I'm aware of the bouncing problem, I've tried using the Bounce2 Library but this changed absolutely nothing.
