I am working on a project I can use to characterise some bimetallic switches using microcontroller STM32F103C8T6 with the official STM Arduino core. Each usage of the completed project will consist of two phases where the temperature goes one way and then vice versa with the microcontroller recording the temperature when each switch changes state. I want my project to attract my attention when either phase has completed.
My code is posted at the bottom of this post with temperature-measuring parts deleted for the purpose of debugging here. The issue I'm focussed on is in the function starting at line 178 which decides when a phase has completed. It does so without any problems; however, I only seem to be able to set userInterventionRequiredFlag = true;
either on completion of phase one or on completion of phase two but not both.
If I have my code as follows
if (i == NUMBEROFBIMETALLICSWITCHES && phaseOneCompleteFlag == false) {
phaseOneCompleteFlag = true;
initialBimetallicSwitchState = bimetallicSwitchStates[0];
} else if (i == NUMBEROFBIMETALLICSWITCHES && phaseOneCompleteFlag == true) {
phaseTwoCompleteFlag = true;
the userIntervention flag is set to true as expected when phase one ends. However, when phase two ends, despite the phaseTwo flag being set to true, the userIntervention flag is left as false?! That seems quite maddening to me - one should be executed right after the other. If I remove the line userInterventionRequiredFlag = true;
from the if statement (leaving it in the else if statement), then the userIntervention flag gets set to true as expected when phase two completes but of course I then don't get my notification that phase one has completed.
Project code *without parts which aren't required to isolate this problem:
rationale
10 bimetallic switches and three thermistors will be connected to a BluePill to record the temperature at which each bimetallic switch changes state (the project will be placed in a hot or cold place to trigger the switches)
plan
check and store switch states in an array on setup
every second, check each switch state in turn and if different from the value in the array, change the value in the array and record the temperature for each thermistor in separate arrays
when all thermistors have changed state, start speaker
when button is pressed, stop speaker and store temperatures in new array positions for the next stage
when button is pressed, stop speaker and begin serial data transfer
#define DEBUG 0 // value is 1 to enable debugging serial printing
#define DEBUG2 1 // value is 1 to enable debugging serial printing
#if DEBUG == 1
#define DEBUG(x) Serial.print(x)
#define DEBUGLN(x) Serial.println(x)
#else
#define DEBUG(x)
#define DEBUGLN(x)
#endif
#if DEBUG2 == 1
#define DEBUG2(x) Serial.print(x)
#define DEBUGLN2(x) Serial.println(x)
#else
#define DEBUG2(x)
#define DEBUGLN2(x)
#endif
// how many bimetallic switches to monitor simultaneously - might not use this, actually
#define NUMBEROFBIMETALLICSWITCHES 10
// which analog pins to use with thermistors
#define THERMISTORPIN1 PA7 //
#define THERMISTORPIN2 PB0 //
#define THERMISTORPIN3 PB1 //
// which digital pins to use for BUTTONPIN to trigger sending contents of matrix to serial
#define BUTTONPIN PB2 //
// buzzer pin
#define PIEZOPIN PA6 //
// resistance at 25 degrees C
#define THERMISTORNOMINAL 10000
// temp. for nominal resistance (almost always 25 C)
#define TEMPERATURENOMINAL 25
// how many samples to take and average, more takes longer
// but is more 'smooth'
#define NUMSAMPLES 5
// The beta coefficient of the thermistor (usually 1000-4000)
#define BCOEFFICIENT 3950
// the value of the resistor used to make a potential divider with the thermistor
#define SERIESRESISTOR 10000
// an array is need to store the pins to which each bimetallic switch will be attached
unsigned char bimetallicSwitchMonitoringPins[10] = { PB12, PB13, PB14, PB15, PA8, PA9, PA10, /* PA11, PA12, */ PA15, PB3, PB4, /* PB5, PB6, PB7, PB8, PB9, /* PA13, PA14, PC13, PC14, PC15, PA0, PA1, PA2, PA3, PA4, PA5, PB10, PB11 */ }; // commented out the pins needed for serial and swd programming
bool initialBimetallicSwitchState;
// an array to store the state of each bimetallic switch
bool bimetallicSwitchStates[10];
// places to store temperatures temporarily
int temperature1;
int temperature2;
int temperature3;
// places to store temperatures after detecting change in switch state
int temperatureArray1[60];
int temperatureArray2[60];
int temperatureArray3[60];
// arrays to store thermistor readings prior to conversion to an average temperature
int samples1[NUMSAMPLES];
int samples2[NUMSAMPLES];
int samples3[NUMSAMPLES];
// how frequently to check the bimetallic switch states and act on readings
const unsigned long temperatureMeasurementInterval = 1000;
const unsigned long thermistorReadShortInterval = 10;
// how long button should be pressed
const int SHORT_PRESS_TIME = 1000; // 1000 milliseconds
const int LONG_PRESS_TIME = 1000; // 1000 milliseconds
bool bimetallicSwitchStateCheckingFlag = false;
bool thermistorSamplingFlag = false;
bool userInterventionRequiredFlag = false;
bool thermistorSamplingCompleteFlag = false;
bool phaseOneCompleteFlag = false;
bool phaseTwoCompleteFlag = false;
bool lastButtonState;
bool currentButtonState;
bool buttonIsBeingPressed;
bool shortButtonPressDetected;
bool longButtonPressDetected;
unsigned long buttonPressTimeStart;
unsigned long buttonPressTimeEnd;
pinMode(BUTTONPIN, INPUT); // have to use INPUT with an external pullup resistor, not INPUT_PULLUP because for some reason, INPUT_PULLUP stops PB2 from detecting when it has been pulled low.
// pinMode(13, OUTPUT); // what is this for?
// set each pin in bimetallicSwitch monitoring array to INPUT_PULLUP, then fill each position in the array with the initial state of each pin
for (unsigned char i = 0; i < 10; i++) {
pinMode(bimetallicSwitchMonitoringPins[i], INPUT_PULLUP);
bimetallicSwitchStates[i] = digitalRead(bimetallicSwitchMonitoringPins[i]);
// check that all of the bimetallic switches are in the same state and if they are not, attract user intervention
for (unsigned char i = 1; i < 10; i++) {
if (bimetallicSwitchStates[0] != bimetallicSwitchStates[i]) {
return;
buttonPressDetection(BUTTONPIN, lastButtonState, currentButtonState, buttonPressTimeStart, buttonPressTimeEnd, buttonIsBeingPressed, shortButtonPressDetected, longButtonPressDetected);
userInterventionAttractionTask();
thermistorSamplingTimerTask();
thermistorSamplingTask();
thermistorSampleAveragingTask();
bimetallicSwitchStateCheckingTask();
phaseFlagSettingTask();
void userInterventionAttractionTask() {
if (userInterventionRequiredFlag == false) {
return;
static unsigned long previousMillis = 0;
if (currentMillis - previousMillis > 1200) {
tone(PIEZOPIN, 800, 600);
if (shortButtonPressDetected == true) {
noTone(PIEZOPIN);
return;
void thermistorSamplingTimerTask() {
if (currentMillis - previousMillis < temperatureMeasurementInterval) {
return;
thermistorSamplingFlag = true;
DEBUG2((String)bimetallicSwitchMonitoringPins[i] + "=" + bimetallicSwitchStates[i] + ",");
DEBUGLN2((String) "initialState:" + initialBimetallicSwitchState + ", phaseOne:" + phaseOneCompleteFlag + ", phaseTwo:" + phaseTwoCompleteFlag + ", intervention:" + userInterventionRequiredFlag + ", buttonState:" + currentButtonState + ", longButton:" + longButtonPressDetected);
return;
void bimetallicSwitchStateCheckingTask() {
if (bimetallicSwitchStateCheckingFlag == false || userInterventionRequiredFlag == true || phaseTwoCompleteFlag == true) {
return;
if (digitalRead(bimetallicSwitchMonitoringPins[i]) != bimetallicSwitchStates[i]) { // check whether the current state of each bitmetallic switch is different from its corresponding state stored in the array
bimetallicSwitchStates[i] = !bimetallicSwitchStates[i]; // set the bimetallic switch state to its new state
temperatureArray1[i + (10 * phaseOneCompleteFlag)] = temperature1; // fill the relevant arrays with the last-recorded temperatures
temperatureArray2[i + (10 * phaseOneCompleteFlag)] = temperature2;
temperatureArray3[i + (10 * phaseOneCompleteFlag)] = temperature3;
void phaseFlagSettingTask() {
while (i++ < 9 && bimetallicSwitchStates[i] == bimetallicSwitchStates[0] && bimetallicSwitchStates[0] != initialBimetallicSwitchState)
if (i == 10 && phaseOneCompleteFlag == false) {
} else if (i == 10 && phaseOneCompleteFlag == true) {
void thermistorSamplingTask() {
thermistorSamplingCompleteFlag = true; // this lets the next stage of the main loop begin
return;
void thermistorSampleAveragingTask() {
bimetallicSwitchStateCheckingFlag = true; // this flag lets the bimetallic switch checking start
void buttonPressDetection(const unsigned char BUTTON_PIN, bool &lastButtonState, bool ¤tButtonState, unsigned long &buttonPressTimeStart, unsigned long &buttonPressTimeEnd, bool &buttonIsBeingPressed, bool &shortButtonPressDetected, bool &longButtonPressDetected) {
// read the state of the switch/button:
currentButtonState = digitalRead(BUTTON_PIN);
if (lastButtonState == HIGH && currentButtonState == LOW) { // button is pressed
buttonPressTimeStart = millis();
buttonIsBeingPressed = true;
longButtonPressDetected = false;
} else if (lastButtonState == LOW && currentButtonState == HIGH) { // button is released
buttonIsBeingPressed = false;
buttonPressTimeEnd = millis();
long pressDuration = buttonPressTimeEnd - buttonPressTimeStart;
if (10 < pressDuration && pressDuration < SHORT_PRESS_TIME) {
DEBUGLN2("A short press is detected");
shortButtonPressDetected = true;
if (buttonIsBeingPressed == true && longButtonPressDetected == false) {
long pressDuration = millis() - buttonPressTimeStart;
if (pressDuration > LONG_PRESS_TIME) {
DEBUG("A long press is detected");
longButtonPressDetected = true;
// save the last state
lastButtonState = currentButtonState;
