I am outputting a uint16_t var using analogWrite to pin 10
once the 16 bit variable reaches 255 , all hell breakes loose, the PWM controls a high current stage, and currents up to 80A is measured, this causes PWM to drop fast, and it may as well hit the magic number on it's way up again.
A simple workaround is to check for, and do not send 255 , going to 256 works correctly, and duty cucle of 256 is bigger than 254 (no rollover).
I also have some code to speed up the PWM, maybe there is something wrong there, but I don't see it.
If you want to do PWM at more than 8 bits you can’t use the Arduino core. Fortunately that problem came up a while back and I wrote some functions to handle it:
// Set 'TOP' for PWM resolution. Assumes 16 MHz clock.
// un-comment one of the choices
// const unsigned int TOP = 0xFFFF; // 16-bit resolution. 244 Hz PWM
// const unsigned int TOP = 0x7FFF; // 15-bit resolution. 488 Hz PWM
// const unsigned int TOP = 0x3FFF; // 14-bit resolution. 976 Hz PWM
// const unsigned int TOP = 0x1FFF; // 13-bit resolution. 1953 Hz PWM
// const unsigned int TOP = 0x0FFF; // 12-bit resolution. 3906 Hz PWM
// const unsigned int TOP = 0x07FF; // 11-bit resolution. 7812 Hz PWM
const unsigned int TOP = 0x03FF; // 10-bit resolution. 15624 Hz PWM
void PWM16Begin() {
// Stop Timer/Counter1
TCCR1A = 0; // Timer/Counter1 Control Register A
TCCR1B = 0; // Timer/Counter1 Control Register B
TIMSK1 = 0; // Timer/Counter1 Interrupt Mask Register
TIFR1 = 0; // Timer/Counter1 Interrupt Flag Register
ICR1 = TOP;
OCR1A = 0; // Default to 0% PWM
OCR1B = 0; // Default to 0% PWM
// Set clock prescale to 1 for maximum PWM frequency
TCCR1B |= (1 << CS10);
// Set to Timer/Counter1 to Waveform Generation Mode 14: Fast PWM with TOP set by ICR1
TCCR1A |= (1 << WGM11);
TCCR1B |= (1 << WGM13) | (1 << WGM12) ;
void PWM16EnableA() {
// Enable Fast PWM on Pin 9: Set OC1A at BOTTOM and clear OC1A on OCR1A compare
TCCR1A |= (1 << COM1A1);
pinMode(9, OUTPUT);
void PWM16EnableB() {
// Enable Fast PWM on Pin 10: Set OC1B at BOTTOM and clear OC1B on OCR1B compare
TCCR1A |= (1 << COM1B1);
pinMode(10, OUTPUT);
inline void PWM16A(unsigned int PWMValue) {
OCR1A = constrain(PWMValue, 0, TOP);
inline void PWM16B(unsigned int PWMValue) {
OCR1B = constrain(PWMValue, 0, TOP);
PWM16Begin();
// On the Arduino UNO T1A is Pin 9 and T1B is Pin 10
// PWM16A(0); // Set initial PWM value for Pin 9
// PWM16EnableA(); // Turn PWM on for Pin 9
PWM16B(0); // Set initial PWM value for Pin 10
PWM16EnableB(); // Turn PWM on for Pin 10
Thanks - the Ardunio source .. I don't see point of setting it high when 255
// We need to make sure the PWM output is enabled for those pins
// that support it, as we turn it off when digitally reading or
// writing with them. Also, make sure the pin is in output mode
// for consistenty with Wiring, which doesn't require a pinMode
// call for the analog output pins.
pinMode(pin, OUTPUT);
if (val == 0)
digitalWrite(pin, LOW);
else if (val == 255)
digitalWrite(pin, HIGH);
@johnwasser - thanks - I already solved it directly, like you did.
